#1 2018-03-01 00:21:42
blackwhitekez
pam_limits or limits.conf different from Debian
Gidday all
I use qgis and have some projects in it that open over 1000 layers. This runs up against the file open limit usually preset to 1000 in many distros.
in Debian I can edit /etc/security/limits.conf and set * soft nofile 10000 to be able to open the projects with more than 1000 layers without seeing rejected file open requests and crashes from the software
This seems not to work in Devuan 2.0. Is there a hard limit somewhere else of less than 1000 or is a different configuration system used (even though this file is present)
contents below with my line added as the last line
# /etc/security/limits.conf
#Each line describes a limit for a user in the form:
#<domain>        <type>  <item>  <value>
#Where:
#<domain> can be:
#        - a user name
#        - a group name, with @group syntax
#        - the wildcard *, for default entry
#        - the wildcard %, can be also used with %group syntax,
#                 for maxlogin limit
#        - NOTE: group and wildcard limits are not applied to root.
#          To apply a limit to the root user, <domain> must be
#          the literal username root.
#<type> can have the two values:
#        - "soft" for enforcing the soft limits
#        - "hard" for enforcing hard limits
#<item> can be one of the following:
#        - core - limits the core file size (KB)
#        - data - max data size (KB)
#        - fsize - maximum filesize (KB)
#        - memlock - max locked-in-memory address space (KB)
#        - nofile - max number of open files
#        - rss - max resident set size (KB)
#        - stack - max stack size (KB)
#        - cpu - max CPU time (MIN)
#        - nproc - max number of processes
#        - as - address space limit (KB)
#        - maxlogins - max number of logins for this user
#        - maxsyslogins - max number of logins on the system
#        - priority - the priority to run user process with
#        - locks - max number of file locks the user can hold
#        - sigpending - max number of pending signals
#        - msgqueue - max memory used by POSIX message queues (bytes)
#        - nice - max nice priority allowed to raise to values: [-20, 19]
#        - rtprio - max realtime priority
#        - chroot - change root to directory (Debian-specific)
#*               soft    core            0
#root            hard    core            100000
#*               hard    rss             10000
#@student        hard    nproc           20
#@faculty        soft    nproc           20
#@faculty        hard    nproc           50
#ftp             hard    nproc           0
#ftp             -       chroot          /ftp
#@student        -       maxlogins       4
# End of file
*        soft    nofile        10000
