#1 2018-02-13 21:41:08
MiyoLinux
Lightdm background/theme fix for Miyo-XTRA 2018
Another desktop-base package came through today, and this time, it changed the login screen of Miyo (must be the one fsmithred had mentioned in another thread).
Again, as with the fix for the grub screen, this isn't needed and is completely voluntary...if you would prefer to use the new login screen with the Devuan Dark Purpy background and light theme, then please do so. smile
For anyone who would like the MiyoLinux background and dark theme back, here's all you need to do...
Step 1:  Open your terminal, and enter the following command (substitute leafpad with your text editor if you're using a different one)...
sudo leafpad /etc/lightdm/lightdm-gtk-greeter.conf
When the file opens, scroll down to the bottom to line #47 (if you have line numbers on), and you will see...
[greeter]
The items below [greeter] are what we will change (lines 48-61). Just remove everything underneath [greeter], because we're going to replace it anyway.
STEP 2:  Copy and paste the following underneath [greeter]...
background=/usr/share/miyolinux/miyolinux-lightdm.png
theme-name=Adwaita-dark
icon-theme-name=Faba-Mono
font-name=Ubuntu
xft-antialias=true
xft-dpi=96
xft-hintstyle=slight
xft-rgba=rgb
show-indicators=~language;~session;~power
show-clock=true
clock-format=%A ~ %l:%M %P
#keyboard=
#position=
#screensaver-timeout=
So, that portion of the file should now look like this...
[greeter]
font-name=Ubuntu
xft-antialias=true
xft-dpi=96
xft-rgba=rgb
show-clock=true
#keyboard=
#position=
STEP 3:  Save and close the file.
The next time you log out/in, you'll have the MiyoLinux background and dark theme again. smile
Whew...I'm thinkin' of locking desktop-base for awhile! LOLOLOL!!! tongue
#2 2018-02-13 21:54:18
Re: Lightdm background/theme fix for Miyo-XTRA 2018
I threw the whole package outta Vuu-do, lol, just so I wouldn't have to deal with this stuff. wink
Not that I don't like purpy and all....:D
