#1 2018-02-03 03:15:22
stanz
[Solved] Quod Libet plays, but no sound.
Hi All,
Laptop install. Any help be appreciated!
VLC sound works, increase/decrease level.
Palemoon plays videos with sound.
Hotkeys for laptop do not work.
Sound Icon on Panel has no effect.
Quod Libet has no sound.
I don't know about sound issues/config's or ?
smile
His Laptop - Acer Aspire E5-521, amd64 Multi-boot: Miyo-XTRA Ascii - Vuu-do latest - StanzSec testing.
Her Laptop - Toshiba - Miyo-XTRA Ascii
All the other pc's - muuhahahaha... tongue
#2 2018-02-03 15:09:42
MiyoLinux
Re: [Solved] Quod Libet plays, but no sound.
I installed it, tried an online radio station, and it wouldn't play like you said...well...it was playing, but there was no sound.
You need to install...
gstreamer1.0-plugins-bad
After I installed that, I had sound. smile
Had a similar situation getting Pragha to play (Pragha isn't in the repositories)...
Can't help with the hotkeys...sorry.
#3 2018-02-04 01:20:42
stanz
Me2! ;0
Thx much, for the fix...!
Now back to learning your Devaun with LxQt, I thought to use Slim
instead of Lightdm...arg!
#4 2018-02-04 02:14:41
MiyoLinux
Hooray! Glad that worked for you! smile
#5 2018-02-04 06:51:55
Geoff 42
In my investigation of LXDE and LxQT on Ascii
https://dev1galaxy.org/viewtopic.php?id=94
I found that LXDM worked quite nicely.
Geoff
#6 2018-02-05 16:51:31
stanz
I'm gonna venture into Miyo's ascii release, right after I set up disk for dual boot!
#7 2018-02-05 21:21:56
MiyoLinux
Prepare yourself to be amazed and to  "ooh" and "ahh" as you experience Miyoification first-hand... big_smile
...or not. roll tongue
LOLOLOL!!!
Sorry stanz...you don't know me very well, but I think the folks here have come to accept my quirky sense of humor...or lack thereof. tongue
If you try it, I hope you enjoy it. smile
#8 2018-02-06 19:02:14
stanz
Wo~hooo! yikes
I mean...
ooouhh...&....ahhhh....
typing from xtra-ascii atm...
wow - really forgot about using www browser!! never really did honestly..
palemoon isn't easy to apt-get (wget i guess) - took it off usb to include here.
it's not tooo tuff for a new -point&click- user, that learnt afew terminal commands!
not enough for me tho, but a good learning tool.
never knew or used - openbox, conky, compton, etc.. so i'll probly brake many things
and re-install many times... lol
your release notes are awesome & thx for taking the time to put em there!
good writers learn others!
i'm gonna grab xchat or the likes, not to hijack posts here...you might have use for
your own forum! smile
Don't stop... we all can use more humor! rock on` smile
type ya laterzzz.....
#9 2018-02-06 21:24:46
MiyoLinux
Good deal! Once you get the hang of Openbox, it becomes second nature...but I warn you...you'll hate yourself for not using it sooner! LOLOLOL! big_smile tongue
As to having my own forum...to be honest, I don't have the time. I work 6 days a week and work crazy hours at that. Between work and trying to have a family life, there's not much time for much else. That's also why Miyo only includes Devuan repositories...if anything ever happened to me, users wouldn't lose a thing, and they could keep using it. I try to pop in here as I'm able, but sometimes others have had to answer questions about Miyo for me when I haven't checked in...for which I'm extremely grateful.
There is a "Derivatives" section here on the forum that you could use if you have any questions about Miyo or any of the other Devuan derivatives.
Have fun and make it your own! wink
