#1 2018-01-30 10:07:24
devuan_dk_fan
Recommended installation method for newer version of HPLIP - Jessie.
What is the recommended method of installing a newer version of HPLIP on Devuan Jessie? I need to be able to get my HP DeskJet 3632 printer to work with Devuan Jessie. I have tried backports and the driver is still AWOL. With the experimental repo, I ran into a problem with the necessary HPLIP dependencies going unmet as the required dependencies were older than what apt could pull in from the experimental repo. I have also tried downloading the latest HPLIP from the HP developers site, but the script/installer doesn't recognize Devuan and when I choose "Debian" as the distro, it prompts me for the following:
11    8.0 ("Jessie", Released 04/05/2015)
12    8.1 ("Jessie", Released 04/05/2015)
13    8.2 ("Jessie", Released 04/05/2015)
14    8.3 ("Jessie", Released 04/05/2015)
15    8.4 ("Jessie", Released 04/05/2016)
16    8.5 ("Jessie", Released 27/08/2016)
17    8.6 ("Jessie", Released 22/10/2016)
18    8.7 ("Jessie", Released 22/10/2016)
19    8.8 ("Jessie", Released 31/05/2017)
and I am not sure what I should answer as I don't which release Devuan is most compatible with.
Help would be appreciated.
I’ve had a perfectly wonderful evening, but this wasn’t it. - Groucho Marx
#2 2018-01-30 10:20:01
Geoff 42
Re: Recommended installation method for newer version of HPLIP - Jessie.
I have an HP DeskJet 3630 and I am using printer-driver-hpcups 3.14.6-1+deb8u1 and it all seems to work nicely, including scanning.
This is running under Jessie.
Geoff
#3 2018-01-30 11:26:26
devuan_dk_fan
Thanks for that Geoff. Hmmm. Unfortunately, apt seems to be hungover from trying to install hplip from experimental:
$ sudo apt-get install hplip
Building dependency tree
 hplip : Depends: libhpmud0 (= 3.14.6-1+deb8u1) but 3.16.11+repack0-1~bpo8+1 is to be installed
         Depends: libsane-hpaio (= 3.14.6-1+deb8u1) but 3.16.11+repack0-1~bpo8+1 is to be installed
         Depends: printer-driver-hpcups (= 3.14.6-1+deb8u1) but 3.16.11+repack0-1~bpo8+1 is to be installed
         Recommends: printer-driver-postscript-hp but it is not going to be installed
Except that I don't:
$ dpkg -l | grep "^hi"
returns nothing. I have also tried:
sudo apt-get update
sudo apt-get install -f
sudo apt-get dist-upgrade
sudo apt-get update
but apt still gives me the above unmet dependencies message.
#4 2018-01-30 11:43:22
devuan_dk_fan
OK, I found the problem. I went into Synaptic and used the "mark all upgrades" command. I was told that a couple of packages needed to be downgraded. Everything works now, and I installed printer-driver-hpcups.
#5 2018-01-30 11:53:50
devuan_dk_fan
What model did you use when you setup your 3630? I don't see any model number that even approximates. I tried Deskjet/deskjet, but nothing prints...
Interesting. I went into the CUPS web interface <http://localhost:631/admin/> and was able to set up the printer without any problem, after I installed the backports version of hplip. I am using the Trinity desktop environment, and for some reason, the newer printer drivers aren't listed in the GUI setup.
#6 2018-01-30 16:45:45
Geoff 42
I don't recall doing anything clever. However, as I look around my own src directory for clues, I have spotted an HP subdirectory which contains hplip-3.16.8.
I have now spotted the HP web pages at :-
https://developers.hp.com/hp-linux-imaging-and-printing
which show which versions are needed to support recent models. You can then download the latest version, if necessary.
Geoff
#7 2020-01-26 19:57:17
berghsg
Unfortunately I tried installing hplip-3.16.8. for Devuan Jessie 1.0.0. I need to get my HP6500A Officejet scanner to work!
I also tried hplip-3.14.8, hplip 3.17.11, hplip 3.19.12
Installation > custom
Distro/OS Name - Debian
Distro/OS Version - 8.5 ("Jessie", Released 27/08/2016)
Would you like to install Custom Discrete Drivers or Class Drivers - Discrete
Network/JetDirect I/O - Y
Graphical User Interfaces (Qt4) - Y
Scanning support - Y
(i said N to rest of options)
Would you like to have this installer install the hplip specific policy/profile? Yes
Do you want to install these missing dependencies? Yes
warning: Missing REQUIRED dependency: libusb (libusb - USB library)
warning: This installer cannot install 'libusb' for your distro/OS and/or version.
When i try to manually install this dependency i get referred to various package names on line that i am unsure of > should i install or not > libgusb-dev.
I go to https://packages.debian.org/jessie/amd6 … 0/download > As Root: dpkg -i libusb-1.0-0_1.0.19-1_amd64.deb > cannot access archive: No such file or directory.
Synaptic Package Manager shows libusb-1.0.0. This is correct for Devuan Jessie but some how the hplip installer is looking to install another libusb for 'my distro'.
I spent hours on the internet trying to get hplip to work with my Devuan installation, but no success.
As root: apt install libusb
E: Unable to locate package libusb
Can anyone assist??
#8 2020-01-26 20:09:07
libusb-1.0-0 1.0.19-1 is available in Jessie. Refer to https://pkginfo.devuan.org/. You have to specify the complete name in your apt install command.
#9 2020-01-26 20:20:14
berghsg
Hi Rolfie
I managed to successfully install libusb-1.0-0_1.0.19-1_amd64.deb, It was in the Downloads folder > cd Downloads > dpkg -i libusb-1.0-0_1.0.19-1_amd64.deb. Sorry I have been over 6 hrs at this..
BUT I still have no success with hplip.
#10 2020-01-28 23:15:51
berghsg
Setting up for local network!
I did a fresh install of Devuan Jessie 1.0.0. It does come with hplip version 3.14.6-1+deb8u1, Kernel: 3.16.0-4-amd64
These are my steps:             (no other changes were made to the OS at this time)
As Root: verify that hplip exists - via synaptic package manager OR type in terminal: apt search hplip
As Root: ping the ip address of the network device e.g. 192.168.0.XXX. If i get a reply the scanner is seen on local network.
As Root: apt-get install simple-scan
connect scanner via usb cable
open simple-scan - can the device be picked up -yes, or no? yes!
disconnect usb cable
As Root: synaptic package manager
As Root: install hplip-gui
with dependencies
As Root: sudo hp-setup
Gui window pops up: Network/Ethernet/Wireless network.....Next > Select (in my case HP Officejet 6500 .......) > Next > Add Printer
Now try simple scan again!!! (This time it sees the scanner via Network and i can scan)
