#1 2018-01-21 09:36:03
onekk
[Solved] [MiYoLinux] Error updating Ascii version: libeudev1 conflict
I have posted the relevant information also in
https://dev1galaxy.org/viewtopic.php?pid=7194#p7194
I will post the relevant code for the error.
Doing apt dist-upgrade
  libeudev1
  colord libcolord2 libcolorhug2
Get:1 http://pkgmaster.devuan.org/merged ascii/main amd64 libeudev1 amd64 3.2.2-9 [92,3 kB]
Get:2 http://pkgmaster.devuan.org/merged ascii/main amd64 libcolord2 amd64 1.3.3-1+devuan1 [253 kB]
Get:3 http://pkgmaster.devuan.org/merged ascii/main amd64 libcolorhug2 amd64 1.3.3-1+devuan1 [184 kB]
Get:4 http://pkgmaster.devuan.org/merged ascii/main amd64 colord amd64 1.3.3-1+devuan1 [338 kB
Unpacking libeudev1:amd64 (3.2.2-9) ...
dpkg: error processing archive /var/cache/apt/archives/libeudev1_3.2.2-9_amd64.deb (--unpack):
 trying to overwrite '/lib/x86_64-linux-gnu/libudev.so.1.6.3', which is also in package libudev1:amd64 220:3.2.2-devuan2.3
It seems that libeudev1 have a conflicting file with libudev1.
Maybe there are some conflict in the package base.
apt-cache policy libudev1
libudev1:
  Installed: 220:3.2.2-devuan2.3
  Candidate: 220:3.2.2-devuan2.3
  Version table:
 *** 220:3.2.2-devuan2.3 100
        100 /var/lib/dpkg/status
     1:3.2.2+devuan2.10 500
        500 http://pkgmaster.devuan.org/merged ascii/main amd64 Packages
     236-3~bpo9+1 100
        100 http://pkgmaster.devuan.org/merged ascii-backports/main amd64 Packages
Hope it can help in solving the problem
#2 2018-01-21 11:04:44
Re: [Solved] [MiYoLinux] Error updating Ascii version: libeudev1 conflict
apt-get install eudev=3.2.2-9 libeudev1=3.2.2-9
You may get a warning that you are downgrading. Proceed. You are "downgrading" to a newer version that has a smaller version number.
#3 2018-01-21 17:10:13
onekk
No luck
sudo apt-get install eudev=3.2.2-9 libeudev1=3.2.2-9
Building dependency tree
eudev is already the newest version (3.2.2-9).
  python-collada
Use 'sudo apt autoremove' to remove it.
  libeudev1
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
Need to get 0 B/92,3 kB of archives.
After this operation, 208 kB of additional disk space will be used.
(Reading database ... 186955 files and directories currently installed.)
Preparing to unpack .../libeudev1_3.2.2-9_amd64.deb ...
dpkg-deb: error: subprocess paste was killed by signal (Pipe interrotta)
#4 2018-01-21 19:07:25
With this in /etc/apt/sources.list
deb http://pkgmaster.devuan.org/merged ascii main
deb http://pkgmaster.devuan.org/merged ascii-security main
deb http://pkgmaster.devuan.org/merged ascii-updates main
I think this was missing, so you couldn't see the version. I had the same problem when I tried to download it today. I got it after updating the package cache.
apt-get update
You might be able to install them with apt-get. If not, download the packages and install with dpkg --force-downgrade -i *.deb.
apt-cache policy libeudev1 libudev1
libeudev1:
  Installed: 3.2.2-9
  Candidate: 3.2.2-9
  Version table:
 *** 3.2.2-9 500
libudev1:
  Installed: 1:3.2.2+devuan2.10
  Candidate: 1:3.2.2+devuan2.10
  Version table:
 *** 1:3.2.2+devuan2.10 500
     215-17+deb8u7 500
        500 http://pkgmaster.devuan.org/merged jessie/main amd64 Packages
user@snapshot-ascii:~$ apt-get download libeudev1 libudev1
Get:1 http://pkgmaster.devuan.org/merged ascii/main amd64 libeudev1 amd64 3.2.2-9 [92.3 kB]
Get:2 http://pkgmaster.devuan.org/merged ascii/main amd64 libudev1 amd64 1:3.2.2+devuan2.10 [2,092 B]
Fetched 94.4 kB in 0s (110 kB/s)
user@snapshot-ascii:~$ ls lib*
libeudev1_3.2.2-9_amd64.deb  libudev1_1%3a3.2.2+devuan2.10_amd64.deb
#5 2018-01-21 20:00:20
onekk
It was an error of conflicting libraries, solved
1) comment out ascii-backports
2) reinstalling the libraries
3)with this little workaround for eudev (Some bug was filed so maybe it will be not necessary in the near future).
cd /etc/init.d
ln -s eudev udev
#6 2018-01-21 20:10:03
@miyolinux
The Miyo-XTRA-ascii isos from October have an older version of eudev which has a higher epoch number than the current version. This causes problems on upgrade. You should make new isos when you get a chance.
#7 2018-01-22 15:34:34
MiyoLinux
I just saw this. My apologies for the problem. I didn't foresee there being this future conflict when I made the .isos.
#8 2018-01-23 14:15:51
fungus
#9 2018-01-24 23:43:49
MiyoLinux
fsmithred wrote:
@miyolinux
Yea! I've been working on it, and I'm now writing this from the new 32 bit version of Miyo-XTRA Ascii. smile
I was VERY pleased to see that there was no pause during the boot process while it was searching to connect to a network...makes me want to hurry up and start on the 64 bit! LOLOL!!! Hopefully, that will start tomorrow or the day after...wish I could start right now.
Again, I apologize to anyone who tried the older Ascii .isos and ran into the eudev problem.
