I tried because of https://dev1galaxy.org/viewtopic.php?id=1709 :
update-initramfs -v -u
reboot
update-grub2
reboot
grub-install /dev/sda
sleep mode
start Devuan, reboot
and openSUSE can't boot:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
Other distros can boot. Reinstalling grub from other distros didn't help.
Hi
It was better if you posted on OpenSuse forum.
But if you check the menu.cfg file, and play a little options with 40_custom, most probably it will work.
I got the similar problem, and had to add an additional entry for Arch linux. But it was resolved later in stretch update.
Thankyou
HP Probook 440 G2: Arch, Debian Stable
Others: Debian, Devuan Centos, Ubuntu, Opensuse
GUI: Openbox, Cinnamon, Xfce
Chroot: Debian, Ubuntu, Fedora
Where is suse installed, and what does the grub.cfg entry for suse look like? Did you try what I suggested in my last post on that other thread? (i.e. try booting suse from grub command-line.)
Thank all, it was caused by changes in /etc/grub.d/10_linux according to
