#1 2017-12-24 05:50:17
alluredbit
inode, storage and perfomance
I started selecting 'news' when I know my VM is going to run off SSD instead of HDD.
Then, I am wondering if doing the same on HDD would also be a reasonable choice - especially when the HDD is a RAID-10.
The VM manager, whatever that is, going to submit low-level operations to the host so it should make no practical difference what allocation you chose.
This COULD be comparative when you are thinking about using WD Blue for high-performance VMs. If you RAID them up large blocks of writes might not be as bad as suspected.
Any thoughts?
start.webtechbazaar.com
Describe whats important, what seldom or never change - then give it away!
