#1 2017-12-07 18:49:28
chillfan
Upgrading to ASCII instructions
For those who want to upgrade to ASCII, I have made the instructions available on my wiki here. The instructions are only for upgrading from Devuan Jessie to Devuan ASCII. I expect this to be straight forward except for non-standard installs, but please open an issue if you experience any problems.
#2 2017-12-08 13:24:54
Re: Upgrading to ASCII instructions
A couple of additional notes:
If you don't have the kernel metapackage installed (e.g. linux-image-amd64) then you won't get the new kernel automatically on dist-upgrade and will need to install linux-image-4.9.0-4-<arch> or install the metapackage and dist-upgrade again. After installing the new kernel, you should reboot, so you're running the new kernel.
You might lose policykit-1 on the dist-upgrade. Unless you're a stoic minimalist, you'll want to reinstall it.
If you're upgrading from debian jessie or stretch, you'll need to remove systemd and systemd-shim after the upgrade. You might need to reinstall some other packages, too.
If you're upgrading from debian with gnome, you are a glutton for punishment, and you are heading for a big adventure. It can be done, but a fresh install would be easier and faster.
#3 2017-12-09 04:11:38
chillfan
[Updated post]
Instructions to migrate from Debian are now available here.
#4 2018-03-27 20:59:07
keb
i tried the upgrade instructions and it got an error and wont go any further.  currently not sure whether it is safe to reboot or i can do something to get it moving again.  transcript of apt-get dist-upgrade is at
https://pastebin.com/jaZb27ap
where is the place to "open an issue"?
#5 2018-03-27 21:15:10
It's a known issue.
https://dev1galaxy.org/viewtopic.php?id=1950
https://lists.dyne.org/lurker/message/2 … 27.en.html
TL;DR:
rm /etc/init.d/udev
Then repeat the upgrade.
#6 2018-04-01 10:32:40
Geoff 42
I have just upgraded my desktop machine from Jessie to Ascii, following Chillfan's write-up.
https://git.devuan.org/dev1fanboy/Upgra … e-to-ascii
I am using lxde.
I prepared the sources.list, the keyring upgrade and the update from within X. I then used <ctrl><alt><F1> to get the console before I did the dist-upgrade. This took about an hour and a half, although I do have quite a lot of stuff installed! The upgrade of flightgear-base-data was over 1GB on its own...
I have the kernel metapackage installed, so 4.9 got pulled in. I also have Xen installed, but I don't use it very often and have grub set-up to default to not using Xen. I noticed that the upgrade fiddled with this. When I rebooted, the grub menu theme had been changed a bit and was quite hard to read, but I managed to select the 4.9 kernel, although it hung. I then rebooted and tried the 3.16 kernel and that was ok. I have since booted ok with 4.9 and it is fine, although it seems to take a bit longer to boot.
I was able to do the eudev stuff as above
rm /etc/init.d/udev
the only problem is that in the ps uaxf listing, eudev shows up as udevd. I'm trying to remember how it appeared in Jessie, was it systemd-udevd?
I also did the elogind stuff
apt-get install libpolkit-backend-1-0-elogind libpolkit-gobject-1-0-elogind
so that I can still shutdown from lxpanel, although there is a warning, it is displayed very briefly but I think it is org.freedesktop.DBus.Error.Noreply.
I also installed lxdm, which replaced slim.
By this point it was basically working and I can log in and have an lxde session.
There are some programs which need a bit of investigation and I will go into details elsewhere, but include :-
Postfix is running in compatability mode :- https://dev1galaxy.org/viewtopic.php?id=1971
PostgreSQL has gone from 9.4 to 9.6 and needs attention :- https://dev1galaxy.org/viewtopic.php?id=1968
runit as a process supervisor was not started, see :- https://dev1galaxy.org/viewtopic.php?pid=8190#p8190
Apache2 seems ok
Claws-mail works and but HTML needs attention :- https://dev1galaxy.org/viewtopic.php?id=1895
Raleigh theme not working :- https://dev1galaxy.org/viewtopic.php?id=1945
Several updates to config files were offered, but generally I kept the current ones and am now going through them. The new configs tend to be in /etc and are suffixed .dpkg-dist so can be found with
find /etc -name '*.dpkg-dist'
The other place to look is in /var/log/apt/ term.log seems to have the info that may have scrolled off your screen during the upgrade and history.log lists the packages installed.
Geoff
#7 2018-04-01 15:00:49
Geoff 42
One thing which I forgot to mention was that at the start of the dist-upgrade, it complained that it would run out of space on /var and refused to run. After running apt-get clean, there was still not much space left on /var. It was then that I spotted a large .iso file which I had left in /var/tmp. Removing this enabled the upgrade to proceed!
Geoff
