#1 2017-12-05 11:37:15
ghp
Jessie & Huge Dirty Cow
Is Jessie's kernel vulnerable for Huge Dirty Cow?
It looks as if we're not using Transparent Huge Pages.
# cat /proc/meminfo | grep -i huge
returns nothing.
But, in case I'm mistaken: https://github.com/torvalds/linux/commi … 0b5740b1f0
Kind regards,
Gerard
Linux Registered User #94362
#2 2017-12-05 13:17:39
Re: Jessie & Huge Dirty Cow
#3 2017-12-06 13:43:56
ghp
No, that was Dirty Cow, and the fix contained a vulnerability in case Transparent Huge Pages were enabled, therefore the "Huge Dirty Cow".
https://security-tracker.debian.org/tra … 7-1000405/
#4 2017-12-06 14:41:28
Your link shows that so far, it's only fixed in sid. That means it's also fixed in ceres. It's only been about a week, so I guess the fix will be moving down to testing and stable soon. Whenever that happens in debian, it will happen in devuan a minute or two later. I hope they fix it in oldstable, too.
aptitude -t sid search linux-image-4.14
p   linux-image-4.14.0-1-amd64                           - Linux 4.14 for 64-bit PCs
aptitude show linux-image-4.14.0-1-amd64
Package: linux-image-4.14.0-1-amd64
New: yes
State: not installed
Version: 4.14.2-1
apt-cache policy linux-image-4.14.0-1-amd64
linux-image-4.14.0-1-amd64:
  Installed: (none)
  Candidate: 4.14.2-1
  Version table:
     4.14.2-1 0
        100 http://pkgmaster.devuan.org/merged/ ceres/main amd64 Packages
         10 http://debian.csail.mit.edu/debian/ sid/main amd64 Packages
