#1 2017-11-29 19:03:18
Delay on shutdown closing luks containers
Got a Devuan Jessie encrypted working. A nuisance I have seen is a about 60s delay during the shutdown of the PC when stopping the 2 crypto disks. Here is a shortened transcript from a screenshot from a VM:
[....] Stopping remaining crypto disks...sda2_crypt (busy)..... .......
[FAILsda2_crypt (busy)...sda2_crypt (busy).....sda2_crypt (busy) failed.
sda3_crypt (busy)...sda3_crypt (busy)..... ......
[FAILsda3_crypt (busy)...sda3_crypt (busy).....sda3_crypt (busy) failed.
done.
[FAIL] Stopping early crypto disks ...sda2_crypt (busy)...failed.
[FAILcrypt (busy)...failed.
done.
[Info] Will now halt.
The first line is displayed, then it takes about one minute until the rest is shown. The same happens in a VM with a Jessie upgraded to Ascii.
I get a similar message on my Wheezy workstation, but no delay.
Anything I can do, a tweak? Or is this a bug?
Thanks, Rolf
#2 2017-12-27 18:22:33
Re: Delay on shutdown closing luks containers
After some updates the behaviour of my Devuan Jessie installation finally has changed. No idea what may have caused this.
Now I just get
INIT: Switching to runlevel: 0
INIT: Sending processes the TERM signal
rpcbind: rpcbind teminating on signal. Restart with "rpcbind -w"
After this message appears, it only takles a few seconds until the mainboard is powered off. This is how I like to see it.
The ASCII VM still behaves the same as before.
Hints/comments are welcome.
Regards, rolfie
#3 2018-02-04 14:54:50
arjan
I am seeing the same after upgrading to Ascii. But I did not have this on Devuan Jessie. I would also appreciate any clues.
#4 2018-02-08 20:40:38
arjan, does it eventually shut down, or does it hang forever? I get about a 30-second delay during shutdown. It's a known problem. I don't know if there's a fix.
https://bugs.debian.org/cgi-bin/bugrepo … bug=792552
Someone on that thread also mentioned this one:
https://bugs.debian.org/cgi-bin/bugrepo … bug=791944
#5 2018-02-08 23:53:49
arjan
I no longer see the messages about sda2_crypt like mentioned above, instead a terminal login prompt appears, then after about 20-30 seconds it shuts down.
#6 2019-04-07 20:01:22
kuleszdl
I have the same issue as the OP using both ascii and beowolf on two different machines, but both with the same layout:
- /boot
- encrypted (with / on it)
It still shuts down, but the task says it "failed". Happens with sysvinit as well as with openrc.
Any ideas?
#7 2019-04-08 18:30:17
