#1 2017-11-11 11:01:36
leloft
Jessie to Ascii upgrade: Chromium 62.0.3202.75 vs. 62.0.3202.89-1
Upgrading from Jessie to Ascii on a remote machine.
# apt-cache policy chromium
chromium:
  Installed: 57.0.2987.98-1~deb8u1
  Candidate: 62.0.3202.89-1~deb9u1
  Version table:
     62.0.3202.89-1~deb9u1 500
        500 http://pkgmaster.devuan.org/merged ascii-security/main amd64 Packages
     61.0.3163.100-1~deb9u1 500
        500 http://pkgmaster.devuan.org/merged ascii/main amd64 Packages
        500 http://packages.devuan.org/merged ascii/main amd64 Packages
*** 57.0.2987.98-1~deb8u1 100
        100 /var/lib/dpkg/status
# apt-get upgrade chromium
Building dependency tree
Calculating upgrade... Done
libgnutls-deb0-28 : Depends: libnettle4 (>= 2.7) but it is not going to be installed
libhogweed2 : Depends: libnettle4 (= 2.7.1-5+deb8u2) but it is not going to be installed
E: Broken packages
# cat /etc/apt/sources.list
deb http://linux-libre.fsfla.org/pub/linux-libre/freesh freesh main
deb http://pkgmaster.devuan.org/merged/ ascii main
deb http://pkgmaster.devuan.org/merged/ ascii-updates main
deb http://pkgmaster.devuan.org/merged/ ascii-security main
deb http://pkgmaster.devuan.org/merged/ ascii-proposed-security main
deb http://pkgmaster.devuan.org/merged/ ascii-proposed main
deb http://pkgmaster.devuan.org/merged/ ascii-backports main
deb http://pkgmaster.devuan.org/merged/ ascii-proposed-updates main
#Devuan JESSIE repositories
#deb http://packages.devuan.org/merged/  jessie main
#deb http://packages.devuan.org/merged/ jessie-security main
# Devuan repositories
deb http://packages.devuan.org/merged ascii main
deb-src http://packages.devuan.org/merged ascii main
Could anyone explain the unmet dependency (libnettle 2.7.1.5)? is it a systemd thing? I'm running Chromium 62.0.3202.75 on ascii on another machine (this one); the sources.list is the same on both machines but this machine has no libnettle4.
Thanks for your time.
#2 2017-11-11 11:34:48
Re: Jessie to Ascii upgrade: Chromium 62.0.3202.75 vs. 62.0.3202.89-1
Those libraries are only jessie. Find out why they are there.
aptitude why libgnutls-deb0-28
Maybe apt can fix the breakage...
apt-get -f install
or re-run the dist-upgrade. (I had to do that on a couple of jessie to ascii upgrades.)
Maybe tell apt which chromium you want.
apt-get install chromium=62.0.3202.89-1~deb9u1
#3 2017-11-11 12:09:08
leloft
For completeness:
# aptitude why libgnutls-deb0-28
Manually installed, current version 3.3.8-6+deb8u7, priority standard
No dependencies require to install libgnutls-deb0-28
# apt-get install chromium=62.0.3202.89-1~deb9u1
  libwebp5 libwebpdemux1
Use 'apt autoremove' to remove them.
  libminizip1 libre2-3
Suggested packages:
  chromium-l10n chromium-shell chromium-driver chromium-widevine
  libgnutls-deb0-28 libhogweed2 libnettle4
  chromium
1 upgraded, 2 newly installed, 3 to remove and 2 not upgraded.
Need to get 51.3 MB/51.5 MB of archives.
After this operation, 5122 kB of additional disk space will be used.
Many Thanks
#4 2017-11-11 21:52:59
fungus
Shouldn't the bottom two lines on your source.list be commented out?
I don't know what you get from linux-libre, compiling your own kernels?  But if the repository only has source files and no binaries shouldn't you change deb to deb-src for that one?
The only chrome I know about is on motorcycle fenders and headlights.  And that is what I trust.
#5 2017-11-11 21:56:32
fungus
Your pkgmaster repositories are not right, not all are merged, some should be devuan instead of merged
Read this:  https://sysdfree.wordpress.com/151/
