Hello guys i'm new user of devuan, and i try to install with live disc, but at the end of installation i've got one problem with grub installer. So after the reboot my system i have the the problem of grub who ask he's not the grub i386-pc normal.mod not found...
i read the var log in live, she's say a script she'not found the target "grub i386-pc normal.mod" and , target not find . I think it'a bug?
i have downloaded the x86_64-uefi for my laptop.
I've seen that happen, but I don't know what causes it. It hasn't happened in a long time. Tell me more about your setup. Is there another OS installed? Did you start with a new hard drive with nothing on it? How did you partition it?
And are you the same person who was telling me about this in irc a couple days ago?
/boot/grub/i386-pc/normal.mod (lots of files in the folder)
If you don't have the i386-pc folder you won't have the .mod file. I looked this up a while back to see if I could delete that folder since I run 64 bit, turns out you can't for several reasons, you can google it to see. But you will need the file.
Amiga sound tracker audio...weird that it still needs this stuff.
