#1 2017-10-20 08:25:38
fungus
[]Ascii] Did repository naming change?
I tried an update and it asked me to rename some repositories (from ../merged/ to /../devuan/) and then it run ok.
When 6 updates showed up the updated files couldn't be located in the repositories.
Anyone knows what's up?  Is it just a temporary problem of updating mirrors?
#2 2017-10-20 08:42:57
FOSSuser
Re: []Ascii] Did repository naming change?
I think this may be something to do with Ampola, or some such name, it's a different repository being set up - but I could be wrong. wink
https://dev1galaxy.org/viewtopic.php?pid=5630#p5630
#3 2017-10-20 10:34:52
fungus
glancing at the repository it seems as devuan and merged have the same content (structure).
The problem appeared to be ffmpeg and some related library, it eventually got upgraded
The repo. that wanted to change name with apt was proposed-updates but appears the same in both devuan and merged
Interesting find was a |sid|
contrib/                                           20-Oct-2017 10:02                   -
main/                                              20-Oct-2017 10:02                   -
non-free/                                          20-Oct-2017 10:02                   -
InRelease                                          20-Oct-2017 10:03              128669
Release                                            20-Oct-2017 10:03              128147
Release.gpg                                        20-Oct-2017 10:03                 473
and ceres
#4 2017-10-20 13:36:12
What repository are you looking at? packages.devuan.org or pkgmaster.devuan.org?  Are you looking at jessie, ascii or ceres?
Note: I don't think there have been or will be any changes to packages.devuan.org (and consequently with auto.mirror.devuan.org) in the recent past or future.
