#1 2017-10-13 12:43:44
Nili
Tint2 Backport Repo?
Hello! Is there any backport for tint2 on Devuan Jessie? I really want to touch the recent changes of tint2. But Jessie prevent me.
I don't want to change jessie sources.list to (test/sid) just for tint2, If there is a chance only to update tint2 via backport, I would be very interested.
Thanks in advance!
OS Devuan | WM Openbox | TB Tint2
#2 2017-10-13 14:12:58
cynwulf
Re: Tint2 Backport Repo?
You could built it from source... i.e. create your own backport from the package source in the unstable repository.
#3 2017-10-13 15:04:43
Nili
Thanks for your suggestion cynwulf, I should have noted that i did not wish to compile because there are too many dependencies to install:
sudo apt-get install libcairo2-dev libpango1.0-dev libglib2.0-dev libimlib2-dev libgtk2.0-dev libxinerama-dev libx11-dev libxdamage-dev libxcomposite-dev libxrender-dev libxrandr-dev librsvg2-dev libstartup-notification0-dev
translated into my system
nili ~ $ sudo apt-get install -s libcairo2-dev libpango1.0-dev libglib2.0-dev libimlib2-dev libgtk2.0-dev libxinerama-dev libx11-dev libxdamage-dev libxcomposite-dev libxrender-dev libxrandr-dev librsvg2-dev libstartup-notification0-dev
[sudo] password for nili:
Building dependency tree
The following extra packages will be installed:
  gir1.2-atk-1.0 gir1.2-freedesktop gir1.2-gdkpixbuf-2.0 gir1.2-glib-2.0 gir1.2-gtk-2.0 gir1.2-pango-1.0 gir1.2-rsvg-2.0 libatk1.0-dev libbz2-dev
  libc-dev-bin libc6-dev libcairo-gobject2 libcairo-script-interpreter2 libelfg0 libexpat1-dev libfontconfig1-dev libfreetype6-dev libgdk-pixbuf2.0-dev
  libgif-dev libgirepository-1.0-1 libglib2.0-bin libglib2.0-data libharfbuzz-dev libharfbuzz-gobject0 libharfbuzz-icu0 libice-dev libicu52 libid3tag0-dev
  libjbig-dev libjpeg-dev libjpeg62-turbo-dev libltdl-dev libltdl7 liblzma-dev liblzo2-2 libpangoxft-1.0-0 libpcre3-dev libpcrecpp0 libpixman-1-dev
  libpng12-dev libpthread-stubs0-dev libsm-dev libtiff5-dev libtiffxx5 libxau-dev libxcb-render0-dev libxcb-shm0-dev libxcb1-dev libxcursor-dev libxdmcp-dev
  libxext-dev libxfixes-dev libxft-dev libxi-dev libxml2-utils linux-libc-dev pkg-config x11proto-composite-dev x11proto-core-dev x11proto-damage-dev
  x11proto-fixes-dev x11proto-input-dev x11proto-kb-dev x11proto-randr-dev x11proto-render-dev x11proto-xext-dev x11proto-xinerama-dev xorg-sgml-doctools
  xtrans-dev zlib1g-dev
Suggested packages:
  glibc-doc libcairo2-doc libglib2.0-doc libgtk2.0-doc libice-doc libtool-doc liblzma-doc imagemagick libpango1.0-doc librsvg2-doc libsm-doc libxcb-doc
  libxext-doc
Recommended packages:
  bzip2-doc manpages-dev debhelper libtool libx11-doc
  libc-dev-bin libc6-dev libcairo-gobject2 libcairo-script-interpreter2 libcairo2-dev libelfg0 libexpat1-dev libfontconfig1-dev libfreetype6-dev
  libgdk-pixbuf2.0-dev libgif-dev libgirepository-1.0-1 libglib2.0-bin libglib2.0-data libglib2.0-dev libgtk2.0-dev libharfbuzz-dev libharfbuzz-gobject0
  libharfbuzz-icu0 libice-dev libicu52 libid3tag0-dev libimlib2-dev libjbig-dev libjpeg-dev libjpeg62-turbo-dev libltdl-dev libltdl7 liblzma-dev liblzo2-2
  libpango1.0-dev libpangoxft-1.0-0 libpcre3-dev libpcrecpp0 libpixman-1-dev libpng12-dev libpthread-stubs0-dev librsvg2-dev libsm-dev
  libstartup-notification0-dev libtiff5-dev libtiffxx5 libx11-dev libxau-dev libxcb-render0-dev libxcb-shm0-dev libxcb1-dev libxcomposite-dev libxcursor-dev
  libxdamage-dev libxdmcp-dev libxext-dev libxfixes-dev libxft-dev libxi-dev libxinerama-dev libxml2-utils libxrandr-dev libxrender-dev linux-libc-dev
  pkg-config x11proto-composite-dev x11proto-core-dev x11proto-damage-dev x11proto-fixes-dev x11proto-input-dev x11proto-kb-dev x11proto-randr-dev
  x11proto-render-dev x11proto-xext-dev x11proto-xinerama-dev xorg-sgml-doctools xtrans-dev zlib1g-dev
0 upgraded, 83 newly installed, 0 to remove and 0 not upgraded.
Inst libcairo-gobject2 (1.14.0-2.1+deb8u2 Devuan:1.0/stable [i386])
Inst liblzo2-2 (2.08-1.2 Devuan:1.0/stable [i386])
Inst libcairo-script-interpreter2 (1.14.0-2.1+deb8u2 Devuan:1.0/stable [i386])
Inst libelfg0 (0.8.13-5 Devuan:1.0/stable [i386])
Inst libharfbuzz-gobject0 (0.9.35-2 Devuan:1.0/stable [i386])
Inst libicu52 (52.1-8+deb8u5 Devuan:1.0/stable [i386])
Inst libharfbuzz-icu0 (0.9.35-2 Devuan:1.0/stable [i386])
Inst libltdl7 (2.4.2-1.11+b1 Devuan:1.0/stable [i386])
Inst libpangoxft-1.0-0 (1.36.8-3 Devuan:1.0/stable [i386])
Inst libpcrecpp0 (2:8.35-3.3+deb8u4 Devuan:1.0/stable [i386])
Inst libtiffxx5 (4.0.3-12.3+deb8u4 Devuan:1.0/stable [i386])
Inst libgirepository-1.0-1 (1.42.0-2.2 Devuan:1.0/stable [i386])
Inst gir1.2-glib-2.0 (1.42.0-2.2 Devuan:1.0/stable [i386])
Inst gir1.2-atk-1.0 (2.14.0-1 Devuan:1.0/stable [i386])
Inst gir1.2-freedesktop (1.42.0-2.2 Devuan:1.0/stable [i386])
Inst gir1.2-gdkpixbuf-2.0 (2.31.1-2+deb8u6 Devuan:1.0/stable-security [i386])
Inst gir1.2-pango-1.0 (1.36.8-3 Devuan:1.0/stable [i386])
Inst gir1.2-gtk-2.0 (2.24.25-3+deb8u2 Devuan:1.0/stable [i386])
Inst gir1.2-rsvg-2.0 (2.40.5-1+deb8u2 Devuan:1.0/stable [i386])
Inst pkg-config (0.28-1 Devuan:1.0/stable [i386])
Inst libglib2.0-data (2.42.1-1 Devuan:1.0/stable [all])
Inst libglib2.0-bin (2.42.1-1+b1 Devuan:1.0/stable [i386])
Inst libc-dev-bin (2.19-18+deb8u10 Devuan:1.0/stable [i386])
Inst linux-libc-dev (3.16.43-2+deb8u5 Devuan:1.0/stable-security [i386])
Inst libc6-dev (2.19-18+deb8u10 Devuan:1.0/stable [i386])
Inst libpcre3-dev (2:8.35-3.3+deb8u4 Devuan:1.0/stable [i386])
Inst zlib1g-dev (1:1.2.8.dfsg-2+b1 Devuan:1.0/stable [i386])
Inst libglib2.0-dev (2.42.1-1+b1 Devuan:1.0/stable [i386])
Inst libatk1.0-dev (2.14.0-1 Devuan:1.0/stable [i386])
Inst libbz2-dev (1.0.6-7+b3 Devuan:1.0/stable [i386])
Inst libexpat1-dev (2.1.0-6+deb8u4 Devuan:1.0/stable [i386])
Inst libpng12-dev (1.2.50-2+deb8u3 Devuan:1.0/stable [i386])
Inst libfreetype6-dev (2.5.2-3+deb8u2 Devuan:1.0/stable [i386])
Inst libfontconfig1-dev (2.11.0-6.3+deb8u1 Devuan:1.0/stable [i386])
Inst xorg-sgml-doctools (1:1.11-1 Devuan:1.0/stable [all])
Inst x11proto-core-dev (7.0.26-1 Devuan:1.0/stable [all])
Inst libxau-dev (1:1.0.8-1 Devuan:1.0/stable [i386])
Inst libxdmcp-dev (1:1.1.1-1+b1 Devuan:1.0/stable [i386])
Inst x11proto-input-dev (2.3.1-1 Devuan:1.0/stable [all])
Inst x11proto-kb-dev (1.0.6-2 Devuan:1.0/stable [all])
Inst xtrans-dev (1.3.4-1 Devuan:1.0/stable [all])
Inst libpthread-stubs0-dev (0.3-4 Devuan:1.0/stable [i386])
Inst libxcb1-dev (1.10-3+b1 Devuan:1.0/stable [i386])
Inst libx11-dev (2:1.6.2-3 Devuan:1.0/stable [i386])
Inst x11proto-render-dev (2:0.11.1-2 Devuan:1.0/stable [all])
Inst libxrender-dev (1:0.9.8-1+b1 Devuan:1.0/stable [i386])
Inst x11proto-xext-dev (7.3.0-1 Devuan:1.0/stable [all])
Inst libxext-dev (2:1.3.3-1 Devuan:1.0/stable [i386])
Inst libice-dev (2:1.0.9-1+b1 Devuan:1.0/stable [i386])
Inst libsm-dev (2:1.2.2-1+b1 Devuan:1.0/stable [i386])
Inst libpixman-1-dev (0.32.6-3 Devuan:1.0/stable [i386])
Inst libxcb-render0-dev (1.10-3+b1 Devuan:1.0/stable [i386])
Inst libxcb-shm0-dev (1.10-3+b1 Devuan:1.0/stable [i386])
Inst libcairo2-dev (1.14.0-2.1+deb8u2 Devuan:1.0/stable [i386])
Inst libgdk-pixbuf2.0-dev (2.31.1-2+deb8u6 Devuan:1.0/stable-security [i386])
Inst libgif-dev (4.1.6-11+deb8u1 Devuan:1.0/stable [i386])
Inst libharfbuzz-dev (0.9.35-2 Devuan:1.0/stable [i386])
Inst libxft-dev (2.3.2-1 Devuan:1.0/stable [i386])
Inst libpango1.0-dev (1.36.8-3 Devuan:1.0/stable [i386])
Inst x11proto-xinerama-dev (1.2.1-2 Devuan:1.0/stable [all])
Inst libxinerama-dev (2:1.1.3-1+b1 Devuan:1.0/stable [i386])
Inst x11proto-fixes-dev (1:5.0-2 Devuan:1.0/stable [all])
Inst libxfixes-dev (1:5.0.1-2+b2 Devuan:1.0/stable [i386])
Inst libxi-dev (2:1.7.4-1+b2 Devuan:1.0/stable [i386])
Inst x11proto-randr-dev (1.4.0-2 Devuan:1.0/stable [all])
Inst libxrandr-dev (2:1.4.2-1+b1 Devuan:1.0/stable [i386])
Inst libxcursor-dev (1:1.1.14-1+b1 Devuan:1.0/stable [i386])
Inst x11proto-composite-dev (1:0.4.2-2 Devuan:1.0/stable [all])
Inst libxcomposite-dev (1:0.4.4-1 Devuan:1.0/stable [i386])
Inst x11proto-damage-dev (1:1.2.1-2 Devuan:1.0/stable [all])
Inst libxdamage-dev (1:1.1.4-2+b1 Devuan:1.0/stable [i386])
Inst libxml2-utils (2.9.1+dfsg1-5+deb8u5 Devuan:1.0/stable-security [i386])
Inst libgtk2.0-dev (2.24.25-3+deb8u2 Devuan:1.0/stable [i386])
Inst libid3tag0-dev (0.15.1b-11 Devuan:1.0/stable [i386])
Inst libjpeg62-turbo-dev (1:1.3.1-12 Devuan:1.0/stable [i386])
Inst libjpeg-dev (1:1.3.1-12 Devuan:1.0/stable [all])
Inst libltdl-dev (2.4.2-1.11+b1 Devuan:1.0/stable [i386])
Inst libjbig-dev (2.1-3.1 Devuan:1.0/stable [i386])
Inst liblzma-dev (5.1.1alpha+20120614-2+b3 Devuan:1.0/stable [i386])
Inst libtiff5-dev (4.0.3-12.3+deb8u4 Devuan:1.0/stable [i386])
Inst libimlib2-dev (1.4.6-2+deb8u2 Devuan:1.0/stable [i386])
Inst librsvg2-dev (2.40.5-1+deb8u2 Devuan:1.0/stable [i386])
Inst libstartup-notification0-dev (0.12-4 Devuan:1.0/stable [i386])
Conf libcairo-gobject2 (1.14.0-2.1+deb8u2 Devuan:1.0/stable [i386])
Conf liblzo2-2 (2.08-1.2 Devuan:1.0/stable [i386])
Conf libcairo-script-interpreter2 (1.14.0-2.1+deb8u2 Devuan:1.0/stable [i386])
Conf libelfg0 (0.8.13-5 Devuan:1.0/stable [i386])
Conf libharfbuzz-gobject0 (0.9.35-2 Devuan:1.0/stable [i386])
Conf libicu52 (52.1-8+deb8u5 Devuan:1.0/stable [i386])
Conf libharfbuzz-icu0 (0.9.35-2 Devuan:1.0/stable [i386])
Conf libltdl7 (2.4.2-1.11+b1 Devuan:1.0/stable [i386])
Conf libpangoxft-1.0-0 (1.36.8-3 Devuan:1.0/stable [i386])
Conf libpcrecpp0 (2:8.35-3.3+deb8u4 Devuan:1.0/stable [i386])
Conf libtiffxx5 (4.0.3-12.3+deb8u4 Devuan:1.0/stable [i386])
Conf libgirepository-1.0-1 (1.42.0-2.2 Devuan:1.0/stable [i386])
Conf gir1.2-glib-2.0 (1.42.0-2.2 Devuan:1.0/stable [i386])
Conf gir1.2-atk-1.0 (2.14.0-1 Devuan:1.0/stable [i386])
Conf gir1.2-freedesktop (1.42.0-2.2 Devuan:1.0/stable [i386])
Conf gir1.2-gdkpixbuf-2.0 (2.31.1-2+deb8u6 Devuan:1.0/stable-security [i386])
Conf gir1.2-pango-1.0 (1.36.8-3 Devuan:1.0/stable [i386])
Conf gir1.2-gtk-2.0 (2.24.25-3+deb8u2 Devuan:1.0/stable [i386])
Conf gir1.2-rsvg-2.0 (2.40.5-1+deb8u2 Devuan:1.0/stable [i386])
Conf pkg-config (0.28-1 Devuan:1.0/stable [i386])
Conf libglib2.0-data (2.42.1-1 Devuan:1.0/stable [all])
Conf libglib2.0-bin (2.42.1-1+b1 Devuan:1.0/stable [i386])
Conf libc-dev-bin (2.19-18+deb8u10 Devuan:1.0/stable [i386])
Conf linux-libc-dev (3.16.43-2+deb8u5 Devuan:1.0/stable-security [i386])
Conf libc6-dev (2.19-18+deb8u10 Devuan:1.0/stable [i386])
Conf libpcre3-dev (2:8.35-3.3+deb8u4 Devuan:1.0/stable [i386])
Conf zlib1g-dev (1:1.2.8.dfsg-2+b1 Devuan:1.0/stable [i386])
Conf libglib2.0-dev (2.42.1-1+b1 Devuan:1.0/stable [i386])
Conf libatk1.0-dev (2.14.0-1 Devuan:1.0/stable [i386])
Conf libbz2-dev (1.0.6-7+b3 Devuan:1.0/stable [i386])
Conf libexpat1-dev (2.1.0-6+deb8u4 Devuan:1.0/stable [i386])
Conf libpng12-dev (1.2.50-2+deb8u3 Devuan:1.0/stable [i386])
Conf libfreetype6-dev (2.5.2-3+deb8u2 Devuan:1.0/stable [i386])
Conf libfontconfig1-dev (2.11.0-6.3+deb8u1 Devuan:1.0/stable [i386])
Conf xorg-sgml-doctools (1:1.11-1 Devuan:1.0/stable [all])
Conf x11proto-core-dev (7.0.26-1 Devuan:1.0/stable [all])
Conf libxau-dev (1:1.0.8-1 Devuan:1.0/stable [i386])
Conf libxdmcp-dev (1:1.1.1-1+b1 Devuan:1.0/stable [i386])
Conf x11proto-input-dev (2.3.1-1 Devuan:1.0/stable [all])
Conf x11proto-kb-dev (1.0.6-2 Devuan:1.0/stable [all])
Conf xtrans-dev (1.3.4-1 Devuan:1.0/stable [all])
Conf libpthread-stubs0-dev (0.3-4 Devuan:1.0/stable [i386])
Conf libxcb1-dev (1.10-3+b1 Devuan:1.0/stable [i386])
Conf libx11-dev (2:1.6.2-3 Devuan:1.0/stable [i386])
Conf x11proto-render-dev (2:0.11.1-2 Devuan:1.0/stable [all])
Conf libxrender-dev (1:0.9.8-1+b1 Devuan:1.0/stable [i386])
Conf x11proto-xext-dev (7.3.0-1 Devuan:1.0/stable [all])
Conf libxext-dev (2:1.3.3-1 Devuan:1.0/stable [i386])
Conf libice-dev (2:1.0.9-1+b1 Devuan:1.0/stable [i386])
Conf libsm-dev (2:1.2.2-1+b1 Devuan:1.0/stable [i386])
Conf libpixman-1-dev (0.32.6-3 Devuan:1.0/stable [i386])
Conf libxcb-render0-dev (1.10-3+b1 Devuan:1.0/stable [i386])
Conf libxcb-shm0-dev (1.10-3+b1 Devuan:1.0/stable [i386])
Conf libcairo2-dev (1.14.0-2.1+deb8u2 Devuan:1.0/stable [i386])
Conf libgdk-pixbuf2.0-dev (2.31.1-2+deb8u6 Devuan:1.0/stable-security [i386])
Conf libgif-dev (4.1.6-11+deb8u1 Devuan:1.0/stable [i386])
Conf libharfbuzz-dev (0.9.35-2 Devuan:1.0/stable [i386])
Conf libxft-dev (2.3.2-1 Devuan:1.0/stable [i386])
Conf libpango1.0-dev (1.36.8-3 Devuan:1.0/stable [i386])
Conf x11proto-xinerama-dev (1.2.1-2 Devuan:1.0/stable [all])
Conf libxinerama-dev (2:1.1.3-1+b1 Devuan:1.0/stable [i386])
Conf x11proto-fixes-dev (1:5.0-2 Devuan:1.0/stable [all])
Conf libxfixes-dev (1:5.0.1-2+b2 Devuan:1.0/stable [i386])
Conf libxi-dev (2:1.7.4-1+b2 Devuan:1.0/stable [i386])
Conf x11proto-randr-dev (1.4.0-2 Devuan:1.0/stable [all])
Conf libxrandr-dev (2:1.4.2-1+b1 Devuan:1.0/stable [i386])
Conf libxcursor-dev (1:1.1.14-1+b1 Devuan:1.0/stable [i386])
Conf x11proto-composite-dev (1:0.4.2-2 Devuan:1.0/stable [all])
Conf libxcomposite-dev (1:0.4.4-1 Devuan:1.0/stable [i386])
Conf x11proto-damage-dev (1:1.2.1-2 Devuan:1.0/stable [all])
Conf libxdamage-dev (1:1.1.4-2+b1 Devuan:1.0/stable [i386])
Conf libxml2-utils (2.9.1+dfsg1-5+deb8u5 Devuan:1.0/stable-security [i386])
Conf libgtk2.0-dev (2.24.25-3+deb8u2 Devuan:1.0/stable [i386])
Conf libid3tag0-dev (0.15.1b-11 Devuan:1.0/stable [i386])
Conf libjpeg62-turbo-dev (1:1.3.1-12 Devuan:1.0/stable [i386])
Conf libjpeg-dev (1:1.3.1-12 Devuan:1.0/stable [all])
Conf libltdl-dev (2.4.2-1.11+b1 Devuan:1.0/stable [i386])
Conf libjbig-dev (2.1-3.1 Devuan:1.0/stable [i386])
Conf liblzma-dev (5.1.1alpha+20120614-2+b3 Devuan:1.0/stable [i386])
Conf libtiff5-dev (4.0.3-12.3+deb8u4 Devuan:1.0/stable [i386])
Conf libimlib2-dev (1.4.6-2+deb8u2 Devuan:1.0/stable [i386])
Conf librsvg2-dev (2.40.5-1+deb8u2 Devuan:1.0/stable [i386])
Conf libstartup-notification0-dev (0.12-4 Devuan:1.0/stable [i386])
I'm honestly not interested throwing inside all these packages on my bare-bone system, I look backport as a practical way for me.
Perhaps I'm asking too much, but i saw on BunsenLabs they've made a repo for tint2 and a few other packages.
I thought if there was such thing here too. My research for tint2 backport didn't find much.
Once again thank you for your suggestion.
Nili
#4 2017-10-13 15:39:46
cynwulf
Well generally, one would:
# apt-get build-dep tint2
Make a "build" directory in your /home/your_user
$ apt-get source tint2
Then build the deb package from the source in the usual way (dpkg-buildpackage in a fakeroot environment).
Once the package is built, the build dependencies (dev packages) can be removed.
#5 2017-10-13 16:06:09
Nili
OK! I will do it! Very acceptable suggestion. I should have thought of this possibility early.
I'll make this work a go now...
Regards!
Nili
#6 2017-10-13 22:00:48
cynwulf
It's called "backporting".  It's generally what you have to do if something you want isn't available.  It's actually more or less how the Debian backports started out.  Originally they weren't official repositories but as time went on, got absorbed by the project.
It's far better and more rewarding to learn to do it yourself, than hanging on in the vain hope that someone else will do it for you...
Good luck and stick with it.
#7 2017-10-14 05:29:12
yeti
You can build it in a chroot or VM which you completely trash afterwards.
"They may have computers, and other weapons of mass destruction." — Janet Reno
"Isch ahbe fertisch!" — Sisyphos
"Logic, my dear Zoe, merely enables one to be wrong with authority." — The 2nd Doctor
"No Source — No Go!" — yeti.
#8 2017-10-14 12:50:44
Nili
I do not have much experience compiling or making a .deb package. I have done once or twice (successfully) but not much,
Everything for my needs got it from Debian/Devuan repo.
Now that want something outside official repositories, I must do myself some tasks.
Indeed DYI is way better and rewarding in the end is worthy.
Good suggestion, but I dared without it. tint2 is not a big deal, i can go without VM.
Thanks for your suggestions.
I'd not give up doing install from source, even though the first time did not go that well. I'll make this with all my modest strength smile
