#1 2017-09-28 16:42:14
devur
[SOLVED]terminal command
is the command
export
not accessible?
if i execute it white sudo, it is not recognized, if i execute it white out sudo then it not working
export PATH="$PATH:~/scripts"
#2 2017-09-28 17:48:38
Re: [SOLVED]terminal command
Use the full path. (without sudo)
export PATH="$PATH:/home/devur/scripts"
#3 2017-09-29 09:33:10
devur
yes that works! wink
