#1 2017-09-27 22:46:07
Qvv
Dell Core 2 Duo Wifi Drivers
I'm on Devuan jessie 1.0 and I can only connect via Ethernet, my chip ID is BCM4311. I installed b34 through Synaptic and reboot and it still doesn't detect wifi networks. I also tried installing broadcom-sta-dkms and it couldn't find the package. Anyone know a solution?
#2 2017-09-27 23:02:29
MiyoLinux
Re: Dell Core 2 Duo Wifi Drivers
This is just a guess, because I don't use Broadcom; however, are the following packages installed?
b43-fwcutter
firmware-b43-installer
firmware-b43legacy-installer
firmware-bnx2
firmware-bnx2x
firmware-brcm80211
I installed all of those in MiyoLinux, and I do know that they worked for the Broadcom users that I heard back from. big_smile You may not need all of them...I don't know. Wish I could be of more help. Good luck!
#3 2017-09-30 01:59:19
mckaygerhard
can be install firmware twice.. be sure what version do you have it
#4 2017-09-30 22:04:38
Racoton
Hi.
Wha'ts the vendor's code and device's code?
#5 2017-10-01 01:38:13
darry1966
mckaygerhard is correct for Jessie.
https://packages.debian.org/jessie/firm … -installer
