#1 2017-09-27 19:59:11
boycottsystemd
Can't run WarThunder
[D]  glversion = 3.3 (Core Profile) Mesa 10.3.2 -> 00030003 : 10.3.2(10.3.2.0)
[E]  intel version driver is not ok! reinstall driver!
Intel HD 4000 + NVIDIA GeForce GTX 660M
Xorg.0.log:
[    25.619] (II) intel(0): [DRI2] Setup complete
[    25.619] (II) intel(0): [DRI2]   DRI driver: i965
[    25.619] (II) intel(0): Allocated new frame buffer 1920x1080 stride 7680, tiled
[    25.637] (II) UXA(0): Driver registered support for the following operations:
[    25.637] (II)         solid
[    25.637] (II)         copy
[    25.637] (II)         composite (RENDER acceleration)
[    25.637] (II)         put_image
[    25.637] (II)         get_image
[    25.637] (==) intel(0): Backing store enabled
[    25.637] (==) intel(0): Silken mouse enabled
[    25.643] (II) intel(0): Initializing HW Cursor
[    25.643] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    25.651] (==) intel(0): DPMS enabled
[    25.651] (==) intel(0): Intel XvMC decoder enabled
[    25.651] (II) intel(0): Set up textured video
[    25.651] (II) intel(0): [XvMC] xvmc_vld driver initialized.
[    25.651] (II) intel(0): direct rendering: DRI2 Enabled
[    25.651] (==) intel(0): hotplug detection: "enabled"
What is the best way to make Devuan to run WT ?
#2 2017-09-28 05:32:45
boycottsystemd
Re: Can't run WarThunder
Another configuration, same result:
[    22.461] (II) intel(0): Creating default Display subsection in Screen section
[    22.461] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[    22.461] (==) intel(0): RGB weight 888
[    22.461] (==) intel(0): Default visual is TrueColor
[    22.461] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 4000
[    22.461] (**) intel(0): Relaxed fencing enabled
[    22.461] (**) intel(0): Wait on SwapBuffers? enabled
[    22.461] (**) intel(0): Triple buffering? enabled
[    22.461] (**) intel(0): Framebuffer tiled
[    22.461] (**) intel(0): Pixmaps tiled
[    22.461] (**) intel(0): 3D buffers tiled
[    22.461] (**) intel(0): SwapBuffers wait enabled
[    22.461] (==) intel(0): video overlay key set to 0x101fe
[    22.461] (II) intel(0): Output LVDS1 has no monitor section
[    22.465] (--) intel(0): found backlight control interface /sys/class/backlight/acpi_video1
[    22.467] (II) intel(0): Output VGA1 has no monitor section
[    22.468] (II) intel(0): Output HDMI1 has no monitor section
[    22.468] (II) intel(0): Output DP1 has no monitor section
