#1 2017-09-26 00:16:40
luzemario
ZFS missing init scripts
Hello folks!
As far as I know, bug #14 (http://bugs.devuan.org//cgi/bugreport.cgi?bug=14) is a work in progress. There is any Devuan edition where this patch is already applied (i.e. Ceres)?
I am desperately wanting this to apply on my customer's Devuan server. Any ideas about?
Thanks in advance
Luzemario
#2 2017-10-02 00:12:59
garyz.dev1
Re: ZFS missing init scripts
I think you would get an earlier answer if you went to
the irc channel #devuan-dev(s) ??
or just #devuan
HTH -gz
#3 2017-11-17 19:30:58
luzemario
Thanks @garyz.dev1, I solved the issue myself using bare ZFS commands on rc.d scripts. It is not as good as having the original scripts, but my customer is using without issues. ZFS is solid enough to self-heal if needed.
