#1 2017-09-24 08:11:37
macondo123
[SOLVED]I cannot make "locate" work
It seems "lib6c" is missing and cannot install it, any ideas? It gives me this error:
E: Unable to locate package lib6c
My bad! Apologies!
I forgot to updatedb as ROOT.
#2 2017-09-24 10:59:56
Re: [SOLVED]I cannot make "locate" work
Thank you, and welcome. Good practice for another time, when you run into something harder. cool
