#1 2017-09-07 02:20:19
mckaygerhard
new golang 1.8 backported for Devuan jessie (soon gogs packaged)
https://groups.google.com/forum/m/?hl=e … tBM5kCm0-I
If We must use updated version of golang go compiler and project manager:, currently devuan jessie stable only has 1.7 if backports are enabled..
For next devuan stable release:
echo 'deb http://download.opensuse.org/repositories/home:/vegnuli:/golang/Debian_9.0/ /' > /etc/apt/sources.list.d/home:vegnuli:golang.list
wget -nv https://download.opensuse.org/repositories/home:vegnuli:golang/Debian_9.0/Release.key -O Release.key
apt-key add - < Release.key
apt-get update
apt-get install golang
For devuan jeesie:
echo 'deb http://download.opensuse.org/repositories/home:/vegnuli:/golang/Debian_8.0/ /' > /etc/apt/sources.list.d/home:vegnuli:golang.list
wget -nv https://download.opensuse.org/repositories/home:vegnuli:golang/Debian_8.0/Release.key -O Release.key
apt-get update
IMPORTANT NOTE we have golan 1.4 and 1.8 for each from wheeze to stretch
No matter where repository you choose, the golang depends are very lowest and works inclusively in debian etch, lenny, squeeze!
For Debian 8+, Devuan 1+ or VenenuX 1.X, the default golang will be enough:
cat <<EOF > /etc/apt/preferences.d/prioritybackports
Package: golang*
Pin: release a=jessie-backports
Pin-Priority: 900
EOF
apg-get install golang-1.7 golang
in that repository there also gogs and gitea packaged
