#1 2017-08-29 20:56:15
mckaygerhard
New minetest and mods for non-systemd debian systems
I have backported the minetest packages (also provide builds for i386 and amd64)
He backportado paquetes minetest (y adicional provisto de algunos builds) aqui:
https://groups.google.com/forum/m/#!top … Lmew2FGl9A en el penultimo mensage
* available for debian: wheeze
* available for DEVUAN: jessie or superior o venenuX 1.0
FUETNES Y MODS
uploaded due debian wheeze does not have it!
INSTRUCTIONS:
    download all files to a directorio
    open a console inside that directory
    dpkg -i *minetes_all.deb
    find ./ -iname "*$(dpkg-architecture -qDEB_BUILD_ARCH)*.deb" -exec ls {} \;|xargs dpkg -i
    dpkg -i *_all.deb
    get ready for blocks
many mods in debian seems have proxy'ed in devuan and ovbiously got their bugs.. that's why i made my own packages..
non-sense that non-gamers made that packages!
NOTE: no! i not use the "georgeous" dh1 system for packagin.. its very complicated..
i just download the dsc, extract, remove systemd depends and repackages to buil.. more easy that so many setups!  and i not have network connection..
este segundo comando se asegura solo instalen el paquete de su arquitectura.. el repo experimental se puede agregar a sources.list pero no todos los paquetes se pueden isntalar, asiq ue solo agregen los que sepan...
recordar es experimental y por eso no lo tengo organizado
#2 2017-08-29 21:13:02
γραφω λογον
Re: New minetest and mods for non-systemd debian systems
Thank you. Much appreciated!
My English is still a work in progress; no offense was intended.
#3 2017-09-30 02:11:08
mckaygerhard
new version build for minetest wil be but some mods are still incompatilbe or have issues.. when be solved i'll upload
#4 2018-03-30 22:07:28
mckaygerhard
new repository relocation and 98 mods will be uploaded.. please stay alert at the vegnuli forum..
also a devuan live disk will be released soon
#5 2018-03-30 22:12:33
mckaygerhard
a debian live disk with minetest 0.4.16 will be released soon stay tuned: https://groups.google.com/d/msg/venenux … 9RzS1_BwAJ
new backported minetest 0.4.16 backported for devuan (WIP) here:
echo 'deb https://download.opensuse.org/repositories/home:/vegnuli:/minetest/Debian_8.0/ /' > /etc/apt/sources.list.d/home:vegnuli:golang.list
wget -nv https://download.opensuse.org/repositories/home:/vegnuli:/minetest/Debian_8.0/Release.key -O Release.key
apt-key add - < Release.key
apt-get update
apt-get install minetest minetest-server
more packages wil be backported for wheeze and others soon.. the package are in beta testing and some mods maybe not work due newer features, soo a live disk will be released for, win all included
