#1 2017-08-17 17:24:09
leloft
linux-libre kernel 4.1.43 upgrade
I would like to upgrade to the current LTS linux-libre kernel v4.9 from the old LTS 4.1, but I do not know how to load and which modules I will need to implement my current iptables ruleset which relies on conntrack.  I understand that the automatic loading of the connection tracking modules was discontinued in v4.7.   All the howtos that I have found so far are either introductory articles on iptables and netfilter or far too advanced for my current position on the linux learning curve: I can't even decide whether a stateless firewall would be lunacy or genius!  Advice and/or links would be welcome and I thank you all in advance.
#2 2017-08-19 16:06:45
garyz.dev1
Re: linux-libre kernel 4.1.43 upgrade
I too am on the 'Linux learning curve"
but AFAIK Devuan Jessie 1.0.0 uses the 3.16.4 kernel
Devuan ASCII (a testing version) uses the 4.9  kernel
I don't believe any of these are linux-libre kernel,
just Debian in the process of removing systemd as PID=1 and such
hth
#3 2017-09-05 01:07:15
Try linux-libre or linux-libre-lts from this website + instructions... jxself.org/linux-libre
Also follow his instructions especially if you use libreboot!
Which I do. smile
#4 2017-10-12 17:49:15
fog
hello,
are there linux-libre sources available or only compiled kernel. From the look at jxself.org/linux-libre does not seem as sources are available?
#5 2017-10-14 00:37:30
garyz.dev1
a little looking on his website came up with this link   https://jxself.org/git/linux-libre.git
#6 2017-10-14 22:01:09
fog
thank you, I did not notice it.
