#1 2017-08-15 14:37:38
pedropt
Install Metasploit-Framework From Git on Devuan
I am creating this thread also for me to consult in future in case i need .
STEP 1
Install ruby 2.4.2
- Dependencies for Rudy & Metaploit-Framework
sudo apt-get install git-core curl zlib1g-dev build-essential libpq5 libpq-dev libssl-dev libreadline-dev libreadline5 libyaml-dev libsqlite3-dev sqlite3 libxml2-dev libpcap-dev git-core autoconf postgresql pgadmin3 curl zlib1g-dev libyaml-dev curl libxslt1-dev libcurl4-openssl-dev python-software-properties libffi-dev git
Install Rubyenv
git clone git://github.com/sstephenson/rbenv.git ~/.rbenv
echo 'export PATH="$HOME/.rbenv/bin:$PATH"' >> ~/.bashrc
echo 'eval "$(rbenv init -)"' >> ~/.bashrc
git clone git://github.com/sstephenson/ruby-build.git ~/.rbenv/plugins/ruby-build
echo 'export PATH="$HOME/.rbenv/plugins/ruby-build/bin:$PATH"' >> ~/.bashrc
source ~/.bashrc
- Close your terminals and open one terminal again so bashrc can be reloaded with the new config
rbenv install -v 2.4.2
rbenv global 2.4.2
echo "gem: --no-document" > ~/.gemrc
gem install bundler
gem install rails
rbenv rehash
STEP 2 - Clone metasploit from git and configure it
(This example will install metasploit on /opt directory , but you can choose any directory you want)
mkdir /opt
cd /opt
git clone https://github.com/rapid7/metasploit-framework.git
cd metasploit-framework
bundle install
service postgresql start
Configure metasploit Databases on Postgresql , so it could be faster the search inside metasploit framework
cat <<EOF> $HOME/pg-utf8.sql
update pg_database set datallowconn = TRUE where datname = 'template0';
\c template0
update pg_database set datistemplate = FALSE where datname = 'template1';
drop database template1;
create database template1 with template = template0 encoding = 'UTF8';
update pg_database set datistemplate = TRUE where datname = 'template1';
\c template1
update pg_database set datallowconn = FALSE where datname = 'template0';
\q
EOF
sudo -u postgres psql -f $HOME/pg-utf8.sql
sudo -u postgres createuser msfdev -dRS
"ALTER USER msfdev with ENCRYPTED PASSWORD 'msf';"
Press Enter
Press CTRL+D
- Create metasploit databases in Postgresql
sudo -u postgres createdb --owner msfdev msf_dev_db
sudo -u postgres createdb --owner msfdev msf_test_db
./msfconsole
Metasploit will start and will create its directory on your Home folder .
write "exit" inside metasploit framework to quit .
- Set database configuration on metasploit home folder to access its database in postgresql
cat <<EOF> $HOME/.msf4/database.yml
# Development Database
  development: pgsql
  adapter: postgresql
  database: msf_dev_db
  username: msfdev
  password: msf
  host: localhost
  port: 5432
  pool: 5
  timeout: 5
# Production database -- same as dev
production: &production
  <<: *pgsql
# Test database -- not the same, since it gets dropped all the time
 test:
  <<: *pgsql
  database: msf_test_db
EOF
Press CTRL+D to Exit
sudo -sE su postgres
psql
\c template0
\c template1
\q
Press CTRL+D to exit
- Setting up Metasploit database Password on postgresql
\password msfdev
Write "msf" and press ENTER key ,
Then confirm again by writing "msf" and pressing ENTER key again .
Press CTRL+D to exit .
service postgresql restart
- STEP 3
Create symlinks to metasploit executables on your sbin folder (so you can run metasploit anywhere)
ln -s /opt/metasploit-framework/msfconsole /usr/local/sbin/msfconsole
ln -s /opt/metasploit-framework/msfupdate /usr/local/sbin/msfupdate
ln -s /opt/metasploit-framework/msfvenom /usr/local/sbin/msfvenom
Everything is installed , now you can run metasploit by writing in your terminal "msfconsole" .
You can update your metasploit by writing in terminal "msfupdate"
