#1 2017-08-05 01:39:18
mtbvfr
Is there a package for Skype?
Hi All,
Is there a package for Skype somewhere?
Thanks, MTB.
#2 2017-08-06 01:08:58
garyz.dev1
Re: Is there a package for Skype?
I just recently read on one of my Linux newsletters of a open-source Skype replacemtn.
It escapes me as to what it is called but the letter made it sound very recent.
If Debian doesn't have it packaged , afaik - you would have to do a manual process for installing
or even compiling - I'm no help there!!
GZ
#3 2017-08-06 08:55:55
MiyoLinux
There's also a browser version. I've read that it works in Chromium and Firefox (with some saying that the video doesn't work in Firefox). I don't use Skype, so I can't say if it works well or not.
https://web.skype.com/
#4 2017-08-06 11:14:19
Somewhat Reticent
Consider Wire - end-to-end encryption, respecting privacy; GPL3 Freed Open-Source Software.
#5 2017-08-06 14:18:09
skype.com has deb packages that should work on jessie. (They say so.) Looks like 64-bit only. If you're not using pulseaudio and don't want to use it, install apulse first. it's in devuan repos now. (in experimental)
I've used retroshare in the past. I don't know their current state. It uses gpg keys for authentication.
Are there any alternatives that can connect with people who are using skype?
#6 2017-08-07 01:46:10
mtbvfr
As per my Volume Up, Volume Down and Mute keys not working Topic there is a mixture of Alsa and pulseaudio software installed. Will this apulse package fix the problems I have noted in that topic?
Can I add the following to the /etc/apt/sources.list file
deb http://auto.mirror.devuan.org/devuan experimental main
... to point to the following location?
http://auto.mirror.devuan.org/devuan/di … ary-amd64/
Can I do this before installing rsyslog and upgrading to ascii?
Thanks, MTB.
#7 2017-08-07 01:47:32
mtbvfr
I'll look into this app later, thanks!
#8 2017-08-07 10:40:06
Thanks, MTB.
Apulse is used to satisfy dependency on pulseaudio without having pulseaudio installed. I don't know if it will help your volume key problem. Add the deb line to sources.list and then install with
apt-get update
apt-get -t experimental install apulse
I would do this before upgrading to ascii. You have a better chance of identifying the source of any problems by changing one thing at a time. My personal preference is to remove pulseaudio as soon as I notice that it's installed (or do a more controlled installation of the system and make sure it doesn't get installed in the first place.)
#9 2017-08-07 23:13:33
Sadly, it's a dependency of Mate....sucks, for a DE that forked because of the garbageware that Gnome had become, it seems ridiculous and counterintuitive (not to mention counter-productive) that it :
a: requires the pulse crap
b: continues to rely completely on dconf, more crap, what kind of trying-to-be-a-closed-source-weenie thinks it's a great idea to use binary config files in userspace?
c: is now going all gtk3, which is currently pretty crappy and looks to be getting worse
Mate is regressing instead of forking. I think it's time to fork Mate into something useable without all this Gnome/Redcrap pottyware.
