#1 2017-08-04 07:29:29
devur
[CLOSED]Configure "send to"
Configure file  "send to"
From the right click drop-down menu in the file-system, Is it possible to configure "send to" file so it moves to " instead, and adding a large part of the file system to the drop-down menu?
#2 2017-08-04 11:43:27
Re: [CLOSED]Configure "send to"
I think you would need to edit the source and recompile the package to change the action of 'Send to'. Instead, you could add an item to the right-click menu that does what you want. Take a look at this discussion about creating custom actions in thunar:
http://forums.debian.net/viewtopic.php? … 4d29642aa8
