#1 2017-08-02 17:25:36
shamil
live-sdk - can't build image
I followed the tutorial for live-sdk here; I keep getting this run around. I don't know why I can't get it to work. I am some how missing something, or live-sdk had a change. My build environment is devuan.
livesdk@devuan  # build_iso_dist
 [D] build_iso_dist
 (*) building complete iso image
 [D] bootstrap_complete_base
 (*) bootstrapping devuan i386 base
 (*) running debootstrap stage 1
sudo: /home/test/live-sdk/lib/libdevuansdk/extra/debootstrap/debootstrap: command not found
 [E] error in: bootstrap_complete_base
 [W] called in: bootstrap_complete_base
 [W] called in: devuan blend leaded
 [W] called in: running debootstrap stage 1
 [E] error reported, operation aborted.
 (*) running debootstrap stage 2
chroot: failed to run command '/debootstrap/debootstrap': No such file or directory
 [W] called in: running debootstrap stage 2
 (*) writing system configuration
 [D] conf_print_debconf
 [D] conf_print_fstab
tee: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/etc/fstab: No such file or directory
 [D] conf_print_hostname
tee: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/etc/hostname: No such file or directory
 [D] conf_print_hosts
tee: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/etc/hosts: No such file or directory
 [D] conf_print_netifaces
tee: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/etc/network/interfaces: No such file or directory
 [D] conf_print_resolvconf
tee: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/etc/resolv.conf: No such file or directory
 [D] conf_print_sourceslist
tee: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/etc/apt/sources.list: No such file or directory
 [D] bootstrap_config_thirdstage
 (*) running debootstrap stage 3
 [D] chroot-script -d thirdstage
 [D] devprocsys mount /home/test/live-sdk/tmp/devuan-i386-build/bootstrap
mount: mount point /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/sys does not exist
 [E] error in: devprocsys mount /home/test/live-sdk/tmp/devuan-i386-build/bootstrap
 [W] called in: devprocsys mount /home/test/live-sdk/tmp/devuan-i386-build/bootstrap
 [W] called in: running debootstrap stage 3
 [D] dpkgdivert on /home/test/live-sdk/tmp/devuan-i386-build/bootstrap
 [D] chroot-script dpkgdivert
 (*) chrooting to execute dpkgdivert...
chroot: failed to run command '/dpkgdivert': No such file or directory
 [E] error in: chroot-script dpkgdivert
 [W] called in: chroot-script dpkgdivert
 [W] called in: chrooting to execute dpkgdivert...
mv: cannot stat '/home/test/live-sdk/tmp/devuan-i386-build/bootstrap/dpkgdivert.log': No such file or directory
 (*) chrooting to execute thirdstage...
chroot: failed to run command '/thirdstage': No such file or directory
 [W] called in: chrooting to execute thirdstage...
mv: cannot stat '/home/test/live-sdk/tmp/devuan-i386-build/bootstrap/thirdstage.log': No such file or directory
 [D] dpkgdivert off /home/test/live-sdk/tmp/devuan-i386-build/bootstrap
 [D] devprocsys umount /home/test/live-sdk/tmp/devuan-i386-build/bootstrap
umount: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/dev/pts: mountpoint not found
umount: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/dev: mountpoint not found
umount: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/proc: mountpoint not found
umount: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/sys: mountpoint not found
 [D] bootstrap_tar_pack
 (*) Creating boostrap tarball in /home/test/live-sdk/tmp/bootstrap-devuan-i386.tgz
 [D] silly
  .  Applying coupons...
 [D] silly
  .  good things come to those who wait
 [D] bootstrap_tar_unpack /home/test/live-sdk/tmp/devuan-i386-build/bootstrap
 [D] silly
  .  patching bugs...
 [D] chroot-script -d postunpack
  .  mounted sys
  .  mounted proc
  .  mounted dev
  .  mounted devpts
 [W] called in: mounted devpts
 (*) chrooting to execute postunpack...
chroot: failed to run command '/postunpack': No such file or directory
 [W] called in: chrooting to execute postunpack...
mv: cannot stat '/home/test/live-sdk/tmp/devuan-i386-build/bootstrap/postunpack.log': No such file or directory
  .  umounted devpts
  .  umounted dev
  .  umounted proc
  .  umounted sys
 [D] blend_preinst
 (*) executing devuan-live_ preinst
 [D] add-user devuan devuan
 (*) adding user devuan:devuan
useradd -m devuan
echo "devuan:devuan" | chpasswd
 [D] chroot-script adduser
 (*) chrooting to execute adduser...
chroot: failed to run command '/adduser': No such file or directory
 [E] error in: chroot-script adduser
 [W] called in: chroot-script adduser
 [W] called in: umounted sys
 [W] called in: chrooting to execute adduser...
mv: cannot stat '/home/test/live-sdk/tmp/devuan-i386-build/bootstrap/adduser.log': No such file or directory
 (*) copying blend-specific debs
'/home/test/live-sdk/blends/devuan-live/yad_0.27.0-1_amd64.deb' -> '/home/test/live-sdk/extra/custom-packages/yad_0.27.0-1_amd64.deb'
'/home/test/live-sdk/blends/devuan-live/yad_0.27.0-1_i386.deb' -> '/home/test/live-sdk/extra/custom-packages/yad_0.27.0-1_i386.deb'
 [D] iso_prepare_strap
 (*) preparing strapdir for livecd
 [D] chroot-script -d isoprep
  .  mounted sys
  .  mounted proc
  .  mounted dev
  .  mounted devpts
 (*) chrooting to execute isoprep...
chroot: failed to run command '/isoprep': No such file or directory
 [W] called in: chrooting to execute isoprep...
mv: cannot stat '/home/test/live-sdk/tmp/devuan-i386-build/bootstrap/isoprep.log': No such file or directory
  .  umounted devpts
  .  umounted dev
  .  umounted proc
  .  umounted sys
 [D] build_kernel_i386
 (*) installing stock kernel for i386
apt-get --yes --force-yes install linux-image-586
 [D] chroot-script -d install-linux
  .  mounted sys
  .  mounted proc
  .  mounted dev
  .  mounted devpts
 (*) chrooting to execute install-linux...
chroot: failed to run command '/install-linux': No such file or directory
 [W] called in: chrooting to execute install-linux...
mv: cannot stat '/home/test/live-sdk/tmp/devuan-i386-build/bootstrap/install-linux.log': No such file or directory
  .  umounted devpts
  .  umounted dev
  .  umounted proc
  .  umounted sys
 [D] iso_setup_isolinux
 (*) setting up isolinux
  .  copying kernel and initrd
iso_setup_isolinux:10: no matches found: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/boot/vmlinuz*
iso_setup_isolinux:11: no matches found: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/boot/initrd*
cp: cannot stat '/usr/share/live/build/bootloaders/isolinux/isolinux.bin': No such file or directory
 [E] error in: iso_setup_isolinux
 [W] called in: iso_setup_isolinux
 [W] called in: copying kernel and initrd
 [W] called in: setting up isolinux
 [D] iso_write_isolinux_cfg (override)
 (*) writing isolinux configuration
 (*) copying isolinux overlay
'/home/test/live-sdk/blends/devuan-live/isolinux-overlay/splash.png' -> '/home/test/live-sdk/tmp/devuan-i386-build/binary/isolinux/splash.png'
'/home/test/live-sdk/blends/devuan-live/hooks' -> '/home/test/live-sdk/tmp/devuan-i386-build/binary/live/hooks'
'/home/test/live-sdk/blends/devuan-live/hooks/fix-lang.sh' -> '/home/test/live-sdk/tmp/devuan-i386-build/binary/live/hooks/fix-lang.sh'
 [D] blend_postinst
 (*) executing devuan-live_ postinst
 [D] iso_make_efi
 (*) creating efi boot files
find: `/home/test/live-sdk/tmp/devuan-i386-build/bootstrap/usr/lib/grub/x86_64-efi': No such file or directory
boot/
boot/grub/
boot/grub/grub.cfg
grub-mkimage: error: cannot open `/usr/lib/grub/x86_64-efi/moddep.lst': No such file or directory.
1440+0 records in
1440+0 records out
1474560 bytes (1.5 MB) copied, 0.00188521 s, 782 MB/s
mkfs.fat 3.0.27 (2014-11-12)
iso_make_efi:75: no matches found: /home/test/live-sdk/tmp/devuan-i386-build/bootstrap/usr/lib/grub/x86_64-efi/*
cp: cannot stat '/home/test/live-sdk/tmp/devuan-i386-build/bootstrap/usr/share/grub/unicode.pf2': No such file or directory
'/home/test/live-sdk/blends/devuan-live/isolinux-overlay/splash.png' -> 'boot/grub/splash.png'
sending incremental file list
boot/
boot/grub/
boot/grub/efiboot.img
boot/grub/x86_64-efi/
boot/grub/x86_64-efi/grub.cfg
sent 1,488,883 bytes  received 89 bytes  2,977,944.00 bytes/sec
total size is 1,488,194  speedup is 1.00
efi/
efi/boot/
efi/boot/bootx64.efi
sent 156 bytes  received 47 bytes  406.00 bytes/sec
total size is 0  speedup is 0.00
 [D] iso_write_grub_cfg (override)
 (*) writing grub configuration
if loadfont /font.pf2 ; then
  set gfxmode=640x480
  insmod efi_gop
  insmod efi_uga
  insmod video_bochs
  insmod video_cirrus
  insmod gfxterm
  insmod jpeg
  insmod png
  terminal_output gfxterm
fi
background_image /boot/grub/splash.png
set menu_color_normal=white/black
set menu_color_highlight=dark-gray/white
set timeout=6
menuentry "devuan-live (i386)" {
    set gfxpayload=keep
    linux   /live/vmlinuz boot=live username=devuan
    initrd  /live/initrd.img
menuentry "Other language" {
	set gfxpayload=keep
	linux /live/vmlinuz boot=live username=devuan hooks=file:///lib/live/mount/medium/live/hooks/fix-lang.sh locales=it_IT.UTF-8
menuentry "devuan-live (load to RAM)" {
    set gfxpayload=keep
    linux   /live/vmlinuz boot=live username=devuan toram
menuentry "devuan-live (failsafe)" {
    set gfxpayload=keep
    linux   /live/vmlinuz boot=live username=devuan noapic noapm nodma nomce nolapic nosmp vga=normal
menuentry "Memory test" {
	linux /live/memtest
 [D] install-custdebs
 [D] chroot-script install-debs
 (*) chrooting to execute install-debs...
chroot: failed to run command '/install-debs': No such file or directory
 [E] error in: chroot-script install-debs
 [W] called in: chroot-script install-debs
 [W] called in: chrooting to execute install-debs...
mv: cannot stat '/home/test/live-sdk/tmp/devuan-i386-build/bootstrap/install-debs.log': No such file or directory
efibootmgr_0.11.0-3_amd64.deb
grub-efi-amd64-bin_2.02~beta2-22+deb8u1_amd64.deb
grub-efi-amd64_2.02~beta2-22+deb8u1_amd64.deb
grub-pc-bin_2.02~beta2-22+deb8u1_amd64.deb
grub-pc_2.02~beta2-22+deb8u1_amd64.deb
libefivar0_0.15-3_amd64.deb
firmware/
firmware/00_README.wireless_packages
firmware/b43-fwcutter_1%3a019-2_amd64.deb
firmware/b43-fwcutter_1%3a019-2_i386.deb
firmware/firmware-atheros_0.43_all.deb
firmware/firmware-b43-installer_1%3a019-2_all.deb
firmware/firmware-b43legacy-installer_1%3a019-2_all.deb
firmware/firmware-bnx2_0.43_all.deb
firmware/firmware-bnx2x_0.43_all.deb
firmware/firmware-brcm80211_0.43_all.deb
firmware/firmware-intelwimax_0.43_all.deb
firmware/firmware-ipw2x00_0.43_all.deb
firmware/firmware-iwlwifi_0.43_all.deb
firmware/firmware-libertas_0.43_all.deb
firmware/firmware-linux-nonfree_0.43_all.deb
firmware/firmware-myricom_0.43_all.deb
firmware/firmware-netxen_0.43_all.deb
firmware/firmware-qlogic_0.43_all.deb
firmware/firmware-ralink_0.43_all.deb
firmware/firmware-realtek_0.43_all.deb
firmware/firmware-ti-connectivity_0.43_all.deb
firmware/firmware-zd1211_3.0.0.56-3_all.deb
home/
home/devuan/
home/devuan/.xscreensaver
home/devuan/Desktop/
home/devuan/Desktop/LARGER_FONTS.desktop
home/devuan/Desktop/SMALLER_FONTS.desktop
home/devuan/Desktop/_RELEASE_NOTES
home/devuan/Desktop/refractainstaller.desktop
usr/
usr/bin/
usr/bin/refractainstaller-yad
usr/lib/
usr/lib/refractainstaller/
usr/lib/refractainstaller/pre-install/
usr/lib/refractainstaller/pre-install/loc-timezn.sh
usr/local/
usr/local/bin/
usr/local/bin/adjfontsize
usr/local/bin/remove-non-free-firmware
sent 16,099,809 bytes  received 756 bytes  32,201,130.00 bytes/sec
total size is 16,092,728  speedup is 1.00
 [D] blend_finalize
 [D] chroot-script -d finalize
  .  mounted sys
  .  mounted proc
  .  mounted dev
  .  mounted devpts
 (*) chrooting to execute finalize...
chroot: failed to run command '/finalize': No such file or directory
 [W] called in: chrooting to execute finalize...
mv: cannot stat '/home/test/live-sdk/tmp/devuan-i386-build/bootstrap/finalize.log': No such file or directory
  .  umounted devpts
  .  umounted dev
  .  umounted proc
  .  umounted sys
 [D] fill_apt_cache
 [D] iso_squash_strap
 (*) creating squashfs out of strapdir
mksquashfs: Unrecognised compressor option -Xbcj
mksquashfs: Did you forget to specify -comp, or specify it after the compressor specific option?
 [E] error in: iso_squash_strap
 [W] called in: iso_squash_strap
 [W] called in: creating squashfs out of strapdir
 [D] iso_xorriso_build
 (*) building iso...
xorriso 1.3.2 : RockRidge filesystem manipulator, libburnia project.
Drive current: -outdev 'stdio:/home/test/live-sdk/dist/devuan_jessie_1.0.0_i386_uefi_desktop-live.iso'
Media current: stdio file, overwriteable
Media status : is blank
Media summary: 0 sessions, 0 data blocks, 0 data, 8649m free
Added to ISO image: directory '/'='/home/test/live-sdk/tmp/devuan-i386-build/binary'
xorriso : UPDATE : 23 files added in 1 seconds
xorriso : FAILURE : Given path does not exist on disk: -boot_image system_area='/usr/lib/ISOLINUX/isohdpfx.bin'
xorriso : FAILURE : Cannot find in ISO image: -boot_image ... bin_path='/isolinux/isolinux.bin'
xorriso : aborting : -abort_on 'FAILURE' encountered 'FAILURE'
 [E] error in: iso_xorriso_build
 [W] called in: iso_xorriso_build
 [W] called in: building iso...
livesdk@devuan  #
#2 2017-08-02 20:14:00
Re: live-sdk - can't build image
Looks like you need to install debootstrap.
#3 2017-08-03 04:33:43
shamil
I have git zsh debootstrap sudo  xz-utils xorriso squashfs-tools live-boot syslinux-common live-build live-config live-config-sysvinit kpartx cgpt.
I installed all of that stuff to be more than compliant.
#4 2017-08-03 13:13:08
I was afraid you would say that. Are you trying to build a basic system without a blend? There should be some logs in live-sdk/log/. Anything useful there?
This is a really weird place for it to be trying to find debootstrap.
I don't have a lib/libdevuansdk/extra in any of my build trees. There is a live-sdk/extra, and it contains a folder named 'custom-packages' which gets populated with all the deb packages I added.
Oh yeah, something has changed in libdevuansdk. Line 42 of zlibs/bootstrap:
sudo -E "$LIBPATH/extra/debootstrap/debootstrap" \
		--keyring="$LIBPATH/extra/devuan-keyring/keyrings/devuan-archive-keyring.gpg" \
		--foreign \
--arch $arch $release $strapdir $mirror || zerr
That's right from parazyd's github. And there is a dir named extra, and it contains debootstrap and the keyring. I'm not sure what to do with that. I've got a question for parazyd in irc right now (in freenode/#devuan-dev). He'll answer eventually. If you know git commands well enough to pull an earlier commit, that might work.
For comparison (and maybe worth a test) mine looks like this (but I did not compare the entire files, so there may be more changes)
        sudo -E debootstrap \
                --foreign \
I'll post here when I get an answer.
#5 2017-08-04 03:41:08
shamil
I was doing the devuan-live blend unmodified just to see it work before i got into anything else. I'll try pulling an earlier live-sdk (such as april).
#6 2017-08-13 21:48:37
shamil
Sorry for the wait. I did a build from april 1st, and got this.
+ exec
Adding 'local diversion of /usr/sbin/invoke-rc.d to /usr/sbin/invoke-rc.d.chroot'
+ exec
Adding user devuan to group cdrom
Adding user devuan to group floppy
Adding user devuan to group audio
Adding user devuan to group dip
Adding user devuan to group video
Adding user devuan to group plugdev
Adding user devuan to group netdev
+ exec
Removing 'local diversion of /usr/sbin/invoke-rc.d to /usr/sbin/invoke-rc.d.chroot'
  .  umounted devpts
  .  umounted dev
  .  umounted proc
  .  umounted sys
Parallel mksquashfs: Using 1 processor
Creating 4.0 filesystem on binary/live/filesystem.squashfs, block size 131072.
[===========================================================/] 24487/24487 100%
Exportable Squashfs 4.0 filesystem, xz compressed, data block size 131072
	compressed data, compressed metadata, compressed fragments, compressed xattrs
	duplicates are removed
Filesystem size 245748.01 Kbytes (239.99 Mbytes)
	41.49% of uncompressed filesystem size (592280.97 Kbytes)
Inode table size 234372 bytes (228.88 Kbytes)
	24.76% of uncompressed inode table size (946409 bytes)
Directory table size 235248 bytes (229.73 Kbytes)
	41.47% of uncompressed directory table size (567324 bytes)
Number of duplicate files found 679
Number of inodes 28029
Number of files 21701
Number of fragments 1791
Number of symbolic links  3602
Number of device nodes 6
Number of fifo nodes 0
Number of socket nodes 0
Number of directories 2720
Number of ids (unique uids + gids) 13
Number of uids 4
	root (0)
	test (1000)
	avahi (101)
	man (6)
Number of gids 12
	root (0)
	shadow (42)
	test (1000)
	netdev (102)
	utmp (43)
	tty (5)
	crontab (101)
	avahi (105)
	staff (50)
	scanner (106)
	adm (4)
	mail (8)
 (*) building iso...
Drive current: -outdev 'stdio:/home/test/live-sdk/dist/devuan_jessie_1.0.0-RC_i386-live.iso'
Media summary: 0 sessions, 0 data blocks, 0 data, 7587m free
xorriso : UPDATE : 14 files added in 1 seconds
Ultimately, dpkgdivert is some what funky/may not matter to anything. But, i have a failure of live-sdk creating the iso as being the most significant problem. At least april 1st commit was much more satisfying succeeding at everything else.
I ran live-sdk with the current commit with your recommended change to bootstrap configuration file and this happened.
+ exec
  .  umounted devpts
  .  umounted dev
  .  umounted proc
  .  umounted sys
 [D] fill_apt_cache
 (*) building iso...
Media summary: 0 sessions, 0 data blocks, 0 data, 5536m free
xorriso : UPDATE : 286 files added in 1 seconds
Squashfs fails, and then as usual, iso creation fails. Other than that, your live-sdk bootstrap modification made the current commit almost work all of the way.
#7 2017-08-13 23:43:57
Parazyd explained to me that debootstrap is now in extra so that it's available for other distros. I haven't tried that new version yet.
I think this is your problem here:
It's not finding isohdpfx.bin. If it's not in /usr/lib/ISOLINUX/isohdpfx.bin then install live-build. More likely, the /usr part of the path got lost from the xorriso command, which is probably in the blend file. (if not, it's in lib/libdevuansdk/zlibs/iso  line 109 or so, but you really shouldn't change it there.)
#8 2017-10-23 21:48:41
cyteen
For completeness:
As mentioned here https://dev1galaxy.org/viewtopic.php?pid=2641#p2641  /usr/lib/ISOLINUX/sohdpfx.bin is found in the isolinux package. Install that and the build of the iso completes.
