If you use Let's Encrypt certificates and the automatic certificate management utility called Certbot (https://certbot.eff.org/), now you can select in the dropdown menu Devuan and it will guide you to use the right program.
For the curious , here's the history of how it went:
https://github.com/certbot/website/pull/267
https://github.com/certbot/certbot/pull/4903
Cheers
maurorappa,
Thanks for sharing this information. I just tried LE and certbot for the first time and and pleasantly surprised how easy it is. Now, I will wait three months and see if the cert gets updated with the cron job.
Wooo
