#1 2017-07-17 18:24:02
nathg
Devuan packages explorer
Hi all,
There was a thread of same topic in dng mailing list for interested persons here.
Here is the ref. http://devuanpackages.viralds.it/
This uses a DB to explore the package repo. and have very good design for new style/format.
I found this very helpful for any package searching with details of version & suite.
In my wish list that, it would be better to have a toggle/button to move from one suite to another for given package.
Now this can be changed from the url. and thus serve my purpose.
Search options may be package name or in description, not both. Now search for "base" gives result of "lsb".
Regards,
#2 2017-07-18 18:13:11
Count_Cucaracha
Re: Devuan packages explorer
Is this only for installed packages? Or all packages?  New to Devuan (and debian).
#3 2017-07-19 16:01:29
nathg
This is for all available packages of three releases of devuan but not for -update, -proposed, -backport & -security.
They are on development.
This may help you in your way or topic like " [SOLVED]Package updates in ascii? ".
Happy explore & cheers,
#4 2018-05-03 03:38:33
AlexLikeRock
nice  work !!!
i suggest 2 point :
1.- Filter by distro
2-- Make a NEW SEARCH at same page
attach the photo:
FluxBB bbcode test
http://www.devuan-mx.org/cosas/buscador3.png
#5 2018-05-03 10:04:14
Panopticon
Its good but does it do the same thing as using "apt search" from command line?
Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
