#1 2017-07-10 17:46:39
Will there be support for the eoma68-a20? for devuan ascii/ceres?
https://www.crowdsupply.com/eoma68/micro-desktop
I am hoping to use that for the purpose of learning more about devuan and gnu/linux as a whole.
Whenever I get it anyways...
Can you perhaps tell me if this will be feasible in the future?
Also, is it possible to remove the 4,9 kernel and install linux libre 4.1 in its place and remove 4.9 so that when it reboots,
the 4.9 kernel doesn't cause any problems...
I was told 4.9 kernel + arm a20 do not mix well...
Any thoughts about this?
Edit: can devuan unstable run on 3.16? it seems linux libre 4.1 will be gone by the end of september...
#2 2017-07-18 18:24:30
Count_Cucaracha
Re: Will there be support for the eoma68-a20? for devuan ascii/ceres?
I am guessing that it would be hard to answer this question since the hardware is not released yet.
But they sell a card with Devuan pre-installed so it sounds like the answer is "yes".
