#1 2021-04-16 16:32:58
nauved-rex
I had to use sudo to setup my printer
While installing Beowulf using the NetInst ISO, I chose "Standard Utilities" and "Print Server" from tasksel. After rebooting, I installed alsa-utils, xorg, wicd, lxde-core and a handful of other lxde packages. After adding a sound driver to modconf and firmware, I rebooted once more. Note: this is an Acer Chromebook 11, model C740.
Now I added system-config-printer. On the LXDE menu, I chose, under Preferences, Print Settings. The dialog was locked, and clicking unlock had no effect. So I was unable to add a printer.
So I executed
su -
The error message was, "cannot open display". I had no choice but to install sudo, add my username in /etc/group, logoff and login, then setup my printer with
sudo system-config-printer
Comments, anyone?
#2 2021-04-16 17:10:06
blackhole
Re: I had to use sudo to setup my printer
You could have tried:
su
#3 2021-04-16 17:12:13
You're running into the changes made to su in buster/beowulf. See the release notes for fixes. https://files.devuan.org/devuan_beowulf … _notes.txt  It's in the "What's new" section near the top.
The print server task includes cups. You could set up the printer by going to localhost:631 in a web browser. When you do any admin tasks, it will ask for root login.
#4 2021-04-17 22:40:30
nauved-rex
su
Thank you!
#5 2021-04-17 22:42:41
nauved-rex
Thank you once again, Admin. I used
su
