#1 2019-09-06 04:02:44
Migrating from Buster to Beowulf - feedback needed
Many of you have asked how you can help Devuan.  Well here's an opportunity - especially for those who keep asking when Beowulf will be released!
There have been reports that the migration process from Debian Buster to Devuan Beowulf is not as straight-forward as Wheezy/Jessie to Jessie and/or Stretch to ASCII. If we are to offer migration as an "official" option, we will need to document specific issues and provide solutions in our documentation.
So . . . please roll up your sleeves, give it a try and let us know if you were able to migrate successfully from Buster to Beowulf.  What issues did you have?  How did you work around them?  Are there any blockers?
May this be a long and productive thread!
#2 2019-09-06 08:28:23
PedroReina
Re: Migrating from Buster to Beowulf - feedback needed
I think that may be helpful an initial URL with the first basic instructions.
#3 2019-09-06 11:14:12
HevyDevy
Hi newb here sort of, well i know my way around linux ok .
I did an lxde install of buster just the LXDE not the debian desktop environment, only chose standard system utils and lxde in tasksel.
Debian Install went fine, got to desktop and tried to install sysvinit-core but apt spat out below info. I was of the thought sysvinit-core should be installed first before anything else, would that be correct?
sudo apt-get install sysvinit-core
Building dependency tree
 dconf-service : Depends: default-dbus-session-bus or
                          dbus-session-bus
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
or should i have the devuan-keyring and devuan beowulf repos setup first then apt update / upgrade, commenting out the debian repos in sources.list ?
Apart from desktop environment i was able to migrate successfully on a netinstall with no X and just standard system utils, sysvinit-core installed fine but had to "echo b > /proc/sysrq-trigger" to reboot then purge systemd.
so with a netinstall with no X,
1. install sysvinit-core
2. install devuan keyring
3. copy in beowulf sources.list and comment out debian sources.list
4. apt update and upgrade
5. echo b > /proc/sysrq-trigger (reboot)
6 .purge systemd (apt remove systemd --purge).
everyday is a beautiful day
eric the hobo
#4 2019-09-06 14:43:41
PedroReina wrote:
I think that may be helpful an initial URL with the first basic intrucctions.
Good starting point would be the ASCII migration instructions here:
https://devuan.org/os/documentation/dev … e-to-ascii
Do let us know if that approach still works or needs adjusting.
Problems are most likely to be encountered with full-blown DEs.  WMs are more likely to survive a migration.
#5 2019-09-06 20:45:35
Helpful feedback from Mark Hindley on the DNG mail list:
I have just had a go in a couple of scenarios using a VM.
The basic process is:
1) Install sysvinit-core (if you don't have it already), remove libnss-systemd
    and reboot.
2) Manually download and  install devuan-keyring (wget, dpkg -i).
3) change apt sources from buster to beowulf.
4) apt update.
4) apt full-upgrade or apt-get dist-upgrade.
The process is not too bad, particularly if you have a very basic
install. However, the main issue is step 1) if you have anything desktoppy
installed (lightdm, xfce....). Debian's libpam-systemd unhelpfully depends on
systemd-sysv which in turn conflicts with sysvinit-core. So, by installing
sysvinit-core the whole chain systemd-sysv -> libpam-systemd -> policykit ->
desktop gets more or less removed. Of course it could all be reinstalled later,
but that is understandably probably too much for most users.
I have already submitted #935304 which is being ignored and may well not be fixed in bullseye. Sigh!
In the report I point out that libpam-systemd depending on systemd-sysv doesn't mean
systemd will always be PID 1, which is (I think) the intention of it.
So, I am working on a transitional package that could help in devuan to smooth
this out and not require the whole GUI to be removed and reinstalled. The basic
idea is that the transitional package Provides systemd-sysv and Depends
sysvinit-core. Installing it temporarily will satisfy libpam-systemd whilst the
system is rebooted without having to uninstall half of the system.
Thoughts?
Mark
#6 2019-09-07 02:44:31
nixer
I have been playing with this most of the day.  The instructions mentioned here still work, for the most part on a netinst install with no X system.  There may be a slight change, but it is still workable.  Commands were entered from a ssh session into the Vbox VM as much as possible.
I just successfully completed a migration from debian buster, it was not easy to do.  Since I really didn't know what I was doing, I  went by trial and error mostly.  I am sure there are other ways to do this, but this worked for me.  Hopefully, someone who knows more about this can shorten and simplify this migration from buster to beowulf.
I started with the debian v.10 netinst cd (with firmware) and then I installed xfce4 with
apt install xfce4
And I rebooted just so I could be starting from a fresh boot.
Edit:  Just today, Sept. 7, 2019, debian updated from 10.0 to 10.1 which brought in a new kernel and 60 upgraded packages.  I did a dist-upgrade and reboot to start from a 10.1 starting point.
Boot into "debian",
apt update
apt install sysvinit-core
Do not reboot, yet.
# alter /root/.bashrc and add:
export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
# logout from this ssh session and login to a new ssh session, this loads the new PATH
Installed devuan-keyring
wget wget http://pkgmaster.devuan.org/devuan/pool/main/d/devuan-keyring/devuan-keyring_2017.10.03_all.deb
dpkg -i devuan-keyring_2017.10.03_all.deb
Alter the sources.list to devuan, and then
apt update
apt upgrade
(I do not know what made me try this, as I was just going on a hunch and trying something else.  I was having a hard time getting sysvinit-core installed, especially from the devuan repos.  Once I installed it from the debian repos, and updated it from the devuan repos, within the same boot, it worked easier.)
# first reboot
reboot
(takes a long time to boot due to starting dbus.  It hangs for ~1-2 minutes
(takes longer to login to either the physical terminal or a ssh session, to both user and root account)
(does not boot to X session, only to terminal, but this was temporary)
apt install eudev
(takes a lot longer to "Process triggers for dbus", ~4 minutes, hangs at "Progress... 96%")
("Failed to open connection to "system" message bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
# network will not work unless you change interfaces file:
# alter /etc/network/interfaces file to change enp0s3 to:
auto eth0
iface eth0 inet dhcp
# second reboot
reboot
apt install libelogind0
apt remove systemd* --purge
apt remove libnss-systemd --purge
apt remove dbus-user-session --purge
# lightdm was removed earlier, so:
apt install lightdm --no-install-recommends
# at this point, there was some kind of issue with libpolkit-agent-1-0, as it was the only package showing as upgradable:
root@localhost:/home/guest# apt list --upgradable -a
Listing... Done
libpolkit-agent-1-0/testing 0.105-25+devuan4 amd64 [upgradable from: 0.105-25]
libpolkit-agent-1-0/now 0.105-25 amd64 [installed,upgradable to: 0.105-25+devuan4]
# I noticed that policykit-1 was shown as a recommended package to lightdm, so
apt install policykit-1 --no-install-recommends
# and this updated the libpolkit-agent-1-0 package
# probably could have done this earlier, but I finally discarded the unnecessary stuff
apt autoremove
# third reboot
reboot
The end result:
root@localhost:/home/guest# apt dist-upgrade
Calculating upgrade... Done
# no systemd here!
root@localhost:/home/guest# dpkg -l | grep systemd
# At the Xfce desktop, all logout options appear available and are not greyed out.
# On the Grub boot menu, it says Debian, and an "update-grub" does not fix it.
#7 2019-09-07 17:16:36
nixer
Also, I would add that Network-Manager has not been devuanized in the Beowulf repository, yet.  If I am incorrect, then I appologize, but I was just unaware of this since I have the ascii version marked as "hold" in apt and it has not upgraded.  If you install NM from scratch, you can install it from the ascii repository and it will work.  I have been using this setup for quite some time.
If you already have it installed and working in buster, then you will probably have to remove it completely and then install it from the ascii repository, preferably after updating everything else.
NM is the only program that I use that has not been devuanized for beowulf, yet.  I do not know of any others.
#8 2019-09-08 11:19:58
You are correct that network-manager has not been devuanized in beowulf, but I'm not sure if it needs to be done. Dependencies on the buster version are libsystemd0 | libelogind0, libpam-systemd | libpam-elogind, udev | eudev. Looks like we can use it with elogind.
#9 2019-09-09 04:36:30
ToxicExMachina
I would recommend to install wicd instead of nm as a temporary solution. For WiFi and ethernet it will replace nm easily (wicd-cli, wicd-curses, wicd-gtk). I think in this case USB modem will be less easy to setup because i don't know suitable DE-agnostic GUI apps for that.
Anyway wicd is much better. Unlike nm, wicd doesn't screw serial i/o on random port, so if someone will use device with UART connection wicd won't cause any trouble.
#10 2019-09-09 12:33:11
nixer
Not to get too far off topic about migrating from buster to beowulf...
FSR >
You are correct.  I just removed the "hold" in apt and did an update.  It worked fine.  I did have one instance where an important file in NetworkManager was removed because it was "obsolete".  I replaced it and it works fine, so, for anyone reading this, backup the contents of /etc/NetworkManager before updating.  Better safe than sorry!
The NM update worked fine in going from Beowulf to Ceres also.
Toxic >
I agree about Wicd, but I like using NetworkManager for the VPN gui.  It makes the vpn so easy to switch on and off.
Now back on topic...
#11 2019-09-17 12:20:01
hugoac
Hello!
I built myself a couple of VMs running Debian Buster, one with a "server" configuration (most of the stuff I use at work: VPN/SSH/FTP/DNS/Samba/NFS/Proxy/WWW/others) and one with a "client" configuration (Xorg, MATE as DE, Libreoffice, some web browsers, audio and video stuff...). Then I tried to upgrade to Beowulf, as in Stretch to Ascii
My results:
* Boot time after first installing sysvinit is VERY long, but it gets faster later on.
* I cannot install devuan-keyring through apt, must be done with dpkg
* On my "client" VM, apt-get autoremove uninstalled almost everything X-related: out went MATE, libreoffice, all web browsers... Had to reinstall it all, but it was just a minor hassle.
* It seems Buster doesn't have systemd-shim
* Both my "server" and "client" VMs booted and worked just fine (other than having to reinstall DE and stuff on "client").
#12 2019-09-17 14:49:51
There hasn't been systemd-shim ever in Devuan.
#13 2019-09-17 15:42:33
hugoac
And after that (although maybe it isn't the purpose of this thread...) I tried a Beowulf install from an existing Ascii install, using Installing Debian GNU/Linux from a Unix/Linux System as a guide.
It worked fine, barring some fiddling to get GRUB working.
#14 2019-09-23 18:37:12
xinomilo
since buster is still "fresh", same instructions apply for debian testing/sid -> devuan ceres migration. tried it yesterday, minor hickups mostly in DE packages.
#15 2019-11-05 22:09:26
Nixer's method still works. I just tried it today on a buster standard-system (no X).
First time, I rebooted before trying to install eudev, and I got the long hang on dbus.
Second time, I instlalled eudev before the reboot, the install failed, I rebooted and did not get the delay. I then installed eudev again, and it succeeded.
On both installs, when I tried to install elogind and libelogind0 it wants to install a bunch of desktop apps. I haven't figured out why that is.
Short version:
- boot buster, install sysvinit-core
- download and install devuan-keyring
- change sources to devuan, update, upgrade
- (optional) install eudev and let it fail. This might save some time on the first reboot.
- reboot and install eudev, remove or purge systemd if it doesn't get removed automatically. (possibly libnss-systemd also)
- (optional) install libelogind0 if you want to replace libsystemd0. Without elogind, it's not pulling in the desktop apps.
#16 2019-11-06 04:17:58
bimon
Hello,
As for me I have found it very convenient to stay at Devuan Ascii on the host and run both Beowulf and Ceres in KVM virtual machines.
I am connecting to beowulf and ceres virtual hosts via ssh -X
and then start graphical application in VMs while displaying their output on Devian Ascii + Trinity, very nice, even browsers work fine anf fast enough to refresh screen.  May be later I will have a dedicated X server in OpenBSD while continuing to use Devuan Ascii for hosting VMs and keep them in ZFS pools.
.ssh/config:
Host beowulf ice ceres
        User ice
        Ciphers aes128-ctr
        Compression yes
        CompressionLevel 9
        ForwardX11 yes
        IdentityFile /xxx/client_key
#       ForwardAgent yes
Host beowulf ice
        Port YYY-1
Host ceres
        Port YYY
And names: beowulf ice ceres
are specified as 127.0.0.1 in /etc/hosts
#17 2019-11-06 04:22:50
bimon
kvm.sh:
#/bin/sh
set -x;
Name=$1;
QEMUOptions=${@:2};
#exit;
VENDOR1='68:5d:43' # Intel
VENDOR2='00:17:A5' # Ralink
RANGE=256;
rangen()
        NUM=$RANDOM;
        let "NUM %= $RANGE";
        OCT=$(echo "obase=16;$NUM" | bc);
        # Single (low) values prepended with '0'
        if [ ${#OCT} == 1 ]; then
                OCT='0'$OCT;
        fi;
        echo $OCT;
gen_random_mac()
#       perl -e 'for ($i=0;$i<6;$i++){@m[$i]=int(rand(256));} printf "%X:%X:%X:%X:%X:%X\n",@m;';
#       dd if=/dev/urandom bs=1024 count=1 2>/dev/null|md5sum|sed 's/^\(..\)\(..\)\(..\)\(..\)\(..\)\(..\).*$/\1:\2:\3:\4:\5:\6/';
        A=$(rangen); B=$(rangen); C=$(rangen); D=$(rangen); E=$(rangen); F=$(rangen);
        echo ${VENDOR2}:${D}:${E}:${F};
chmod 777 /dev/kvm;
MAC=`gen_random_mac`;
modprobe kvm;
modprobe kvm_intel;
#KernelOptions=" console1=ttyS0,115200 ";
KernelOptions=" root=LABEL=$Name MY_LOCATION=$MY_LOCATION ";
KernelDir="/XXX/Security/Devuan/Kernel";
#echo \
nice -n 7 ionice -c 2 -n 7 /usr/bin/qemu-system-x86_64 \
    -smp 2 \
    -k en-us \
    -machine accel=kvm \
    -no-fd-bootchk \
    -virtfs local,id=shared_folder_dev_0,path=/download,security_model=none,mount_tag=shared0 \
    -kernel $KernelDir/$Name/vmlinuz \
    -initrd $KernelDir/$Name/initrd.img \
    -append "verbose net.ifnames=0 ipv6.disable=1 ro  quiet  framebuffer=false selinux=0  console=ttyS0        zswap.enabled=1 zswap.max_pool_percent=25 zswap.compressor=lz4 $KernelOptions " \
    -rtc base=utc \
    -name "$Name" \
    -net nic,macaddr=$MAC,model=virtio \
    -usb \
    -device usb-ehci,id=ehci \
    $QEMUOptions \
    -serial mon:stdio -nographic;
#18 2019-11-06 04:26:39
bimon
ceres.sh:
set -x;
SystemDev=/dev/zvol/XXX/ceres_vol;
chmod 777 $SystemDev
MemSize=4096;
#Modem=" -device usb-host,vendorid=0x0abc,productid=0x1234 ";
Network=" -net user,hostfwd=tcp:127.0.0.1:YYY-:22 ";
Drives=" -drive format=raw,if=virtio,aio=native,cache.direct=on,file=$SystemDev ";
Options=" -m $MemSize $Modem $Network $Drives ";
sleep 1s;
/xxx/kvm.sh "CERES64" $Options;
#19 2019-11-06 04:31:45
bimon
For example a brave browser can run in a beowulf VM and still render its GUI on Ascii host by the following command:
ssh ice "brave-browser &";
Then you will have super stable ascii host with its Xorg server
and beowulf and ceres simultaneously running in different KVM vms for experiments with fresher GUI programs while they are still not released as stable.
Btw, this config has defended me from Ganstalkers' EMI and browser plugin attacks even on a slow HDD as ZFS vdev without any SSD caching:
https://archive.is/ggHIK
https://web.archive.org/web/20191106043 … ssues/9518
VM specific datasets are:
zfs set sync=disabled
for performance, having regular snapshots of course to rollback if a dataset gets any corruption due to unexpected reset, power loss, etc.
With a SSD it would work even faster which would be noticeable at least during computer power on when ZFS caches are cold yet, but after an hour of work HDDs become fast too after ZFS ARC gets already hot enough.
And a high IO attack from browser plugins becomes useless. Computer cannot be hung anymore by this method.
#20 2020-01-30 06:48:40
little
I tested Nixer's instructions with Raspbian Buster on an RPI3 and had no issues today. Everything is working well.
I did notice that when /etc/network/interfaces was changed, the DHCP ip also changed. Quite minor.
There was an error with avahi-daemon. I'll copy it below:
? avahi-daemon.service - Avahi mDNS/DNS-SD Stack
   Loaded: loaded (/lib/systemd/system/avahi-daemon.service; enabled; vendor preset: enabled)
   Active: active (running) since Thu 2020-01-30 04:58:10 GMT; 1h 17min ago
 Main PID: 312 (avahi-daemon)
   Status: "avahi-daemon 0.7 starting up."
    Tasks: 2 (limit: 1164)
   Memory: 1016.0K
   CGroup: /system.slice/avahi-daemon.service
           ??312 avahi-daemon: running [raspberrypi.local]
           ??342 avahi-daemon: chroot helper
Jan 30 04:58:15 raspberrypi avahi-daemon[312]: New relevant interface eth0.IPv4 for mDNS.
Jan 30 04:58:15 raspberrypi avahi-daemon[312]: Registering new address record for 192.168.1.240 on eth0.IPv4.
Jan 30 06:08:55 raspberrypi avahi-daemon[312]: Files changed, reloading.
Jan 30 06:08:55 raspberrypi avahi-daemon[312]: No service file found in /etc/avahi/services.
Jan 30 06:15:20 raspberrypi avahi-daemon[312]: Files changed, reloading.
Jan 30 06:15:20 raspberrypi avahi-daemon[312]: No service file found in /etc/avahi/services.
dpkg: error processing package avahi-daemon (--configure):
 installed avahi-daemon package post-installation script subprocess returned error exit status 1
Setting up tasksel (3.54+devuan3) ...
Setting up libdevmapper1.02.1:armhf (2:1.02.155-3) ...
Setting up libparted2:armhf (3.2-25) ...
Setting up tasksel-data (3.54+devuan3) ...
Setting up dmsetup (2:1.02.155-3) ...
update-initramfs: deferring update (trigger activated)
Setting up libcryptsetup12:armhf (2:2.1.0-5+deb10u2) ...
Setting up parted (3.2-25) ...
Setting up nfs-common (1:1.3.4-2.5) ...
nfs-utils.service is a disabled or a static unit not running, not starting it.
insserv: warning: current start runlevel(s) (empty) of script `nfs-common' overrides LSB defaults (S).
insserv: warning: current stop runlevel(s) (0 1 6 S) of script `nfs-common' overrides LSB defaults (0 1 6).
Processing triggers for install-info (6.5.0.dfsg.1-4+b1) ...
Processing triggers for mime-support (3.62) ...
Processing triggers for initramfs-tools (0.133+deb10u1) ...
Processing triggers for libc-bin (2.28-10+rpi1) ...
Processing triggers for systemd (241-7~deb10u2+rpi1) ...
 avahi-daemon
root@raspberrypi:/etc/apt#
This was after 1. devuan repos were added, and then 2. apt upgrade was run. I simply did an apt remove avahi-daemon, as I don't need it.
After that, there was no problem.
give a man an init, he takes an os
#21 2020-02-05 03:17:43
dgrif
Hello,
I am new to Devuan, but not to Debian (started pre-Sarge). I have been avoiding systemd through Debian Stretch, but I upgraded to Buster after the "systemd-shim" was removed. This caused LXDE to be removed because systemd was strictly prevented from being installed. The Devuan web page had instructions for migrating from Debian Stretch to ASCII. Since I was at Buster already I figured that migrating to Beowulf was appropriate even though there was no explicit recipe available.
I was successful at migrating from Debian Buster to Devuan Beowulf and then installed LXDE and everything is right with the world. Here is a synopsis of my process that I typed immediately after the task was completed.
Dan Griffin
  Migration to Devuan Beowulf (testing) from Debian Buster.
Buster system is bare-bones using SysVinit and wicd. Not much else because I did the Stretch to Buster upgrade after "systemd-shim" was removed from Debian.
  The Devuan instructions start with Debian Jessie or Stretch to Devuan Ascii (stable) but I'm betting that I can do this trick. Please take a look at
for the process that I am basing this migration upon. The early steps for removing systemd were not necessary since it was already gone.
  First step, changing the sources.list file needs the entry
[trusted=yes] on the line
    deb [trusted=yes] http://deb.devuan.org/merged buster main contrib non-free
because my Buster version of apt-get would not create the proper data base without it.
  Then I could "apt-get install devuan-keyring" without errors.
  Also the "beowulf-security" doesn't yet exist (because it's "testing"?) so I commented it out from sources.list. Once the keyring was installed, I removed the "[trusted=yes]" from sources.list.
  Once the update is happy, then I did
apt-get upgrade
apt-get upgrade --with-new-pkgs
  Now for the big test. Reboot the system!
  Hooray, it does boot. And the X server comes up (/usr/lib/xorg/Xorg) along with lightdm. These two items were working before.
  Now to install my choice, LXDE,  which I couldn't do in Buster because of stupid dependencies that required all of systemd.
  Trying first "apt-get install lxde-core" and it doesn't go because of dependencies not scheduled for installation. I tracked this down to "policykit-1". So I installed "policykit-1" and then "apt-get install lxde-core" worked without requiring any systemd stuff.
  Now for another reboot to see what might be working.
  Lo and behold a miracle. The LXDE desktop appears, complete with my appropriate icons on the desktop and behavior settings. Firefox works, Thunderbird works, LXTerminal works, and I have yet to find a command line program that doesn't work. But then I haven't tried everything.
  Threw in an "update-initramfs" followed by "update-grub" for good measure. Probably not necessary, but shouldn't hurt.
  So now I am going to move data and stuff from my old laptop with a broken hinge and very slow processor onto this system and let it sit on the desk in my basement.
  Hopefully you will find my experience useful.
  Dan
#22 2020-02-05 07:03:58
mknoop
Congratulations Dan,
It looks to me like you did a good job.  I hope it all works for you.  Just a note:
  "Also the "beowulf-security" doesn't yet exist (because it's "testing"?) so I commented it out from sources.list. Once the keyring was installed, I removed the "[trusted=yes]" from sources.list."
Actually, if you check http://deb.devuan.org/merged/dists/, beowulf-security, beowulf-updates, beowulf-backports, and beowulf-proposed-updates all exist now.
Michael
#23 2020-02-12 03:50:11
dgrif
>Michael
  I will check the above repositories when I return home. I did the actual migration a couple of weeks before posting, and promptly went on an out-of-town trip after making the post. Overall I am pleased with the system and the fact that SysVinit is still viable. (I'm probably a "stick in the mud" type having been around Unix since before SysV was licensed commercially.)
  Dan
#24 2020-02-12 12:25:28
Andre4freedom
Dear Admins, dear Members,
as requested, here my experience with Beowulf.
I always use the Cinnamon desktop and OpenRC. Starting with a fresh install of ASCII 2.1.
Of course, that installs NetworkManager, Lightdm and all, which I'm happy with.
I have Beowulf running on PCs, laptops and servers and couldn't be happier. Updates never broke my systems.
Here the steps I used to update from ASCII 2.1 to Beowulf:
1. Install Devuan Ascii (2.1)
   (install all updates and upgrades: sudo apt update; sudo apt upgrade; reboot)
2. sudo vi /etc/pam.d/lightdm-greeter
   --> # Setup session
   --> session   required pam_unix.so
   --> #session   optional pam_systemd.so
   --> session   optional pam_elogind.so
3. sudo vi /etc/apt/sources.list
   --> # comment the "deb cdrom:...= - line
   --> # Replace every word ascii with the word beowulf
4. sudo apt udate
5. sudo apt upgrade
6. sudo apt dist-upgrade
7. sudo apt autoremove
8. reboot
9. vi sudo vi /etc/pulse/client.conf.d/00-disable-autospawn.conf
   --> # On linux systems, disable autospawn by default
   --> # If you are not using systemd, comment out this line
   --> #autospawn=no
10. logout - login --> ok
The only wish I have is to get the cinnamon tool to install and configure languages. I'm quite happy with English, but some users prefer French or German when they log in.
A big thank to the Devuan Team - a real high-light in this increasingly "complex" world.
#25 2020-05-19 07:17:21
the_edge123
The migration went well from https://beta.devuan.org/os/documentatio … to-beowulf.
Fabien
