Pages: 1
one recent for
Devuan GNU/Linux 7 (freia/ceres)
https://www.passmark.com/baselines/V11/ … 2609603226
Search Baselines Matching:
OS: NA
cool!
@GlennW , thanks , yours got to be the new benchmark!
Found out i am still bit afraid of heights
https://www.cpubenchmark.net/common_cpus.html
@chomwitt you can use this shortcut
sudo ln -s /usr/lib/x86_64-linux-gnu/libncurses.so.6 /usr/lib/x86_64-linux-gnu/libncurses.so.5Last edited by kapqa (2026-09-23 07:49:45)
@ my PassMark PerfomanceTest (11.0.1004) Results for Excalibur.
So : AMD Ryzen 9 5900X performance seems close to AMD Ryzen 7 9700X.
Also some hardinfo2 benchmarks:
AMD Ryzen 9 5900X 12-Core 24x 4951.00 MHz
CPU Blowfish (Single-thread) 35.57
CPU Blowfish (Multi-thread) 469.43
CPU Blowfish (Multi-core) 400.66
CPU Zlib 308.51
CPU CryptoHash 105.80
CPU Fibonacci 9928.79
CPU N-Queens 6261.64
FPU FFT 662.61
FPU Raytracing (Single-thread) 3695.20
SysBench CPU (Single-thread) 5461.55
SysBench CPU (Multi-thread) 68252.09
SysBench Memory (Single-thread) 8834.38
SysBench Memory (Multi-thread)11986.74
Running PassMark PerfomanceTest raises the challange of installing a package (libncurses5) not available at my Devuan Release.
finally i added daedalus to my sources . libncurses5 depends on libtinfo5 which depends on multiarch-support
(out of linear thread's timeline addition) :
The kapka's proposed solution is:
sudo ln -s /usr/lib/x86_64-linux-gnu/libncurses.so.6 /usr/lib/x86_64-linux-gnu/libncurses.so.5and tried it again in a different Devuan 6 it worked .
But i think that is accidental. Since Passmark's utility asks for libncurse5 it may be they are lazy to recompile and just be a naming issue but could be sth more. On the other hand my proposal to add in my system's apt source an older release could it be to much for a change . But it the depedency was more 'hard' i think it would be better.
@chomwitt
the shortcut proposed should suffice for the task at hand;
here are some hardinfo2 result for comparision
hardinfo2
(result not so relevant for Devuan)
CPU Blowfish (Single-thread) 16x 5582.00 MHz 58.44|
CPU Blowfish (Multi-thread) 16x 5582.00 MHz 556.95 |
CPU Blowfish (Multi-core) 16x 5582.00 MHz 441.33
SysBench CPU (Single-thread) 16x 5582.00 MHz 6342.99
SysBench CPU (Multi-thread) 16x 5582.00 MHz 50505.06
(these probably more influenced by OpenSource Drivers)
funnily GPU drawing got values for RX 7600 in the realms of NV 4070TI
GPU Drawing
(AMD Radeon RX 7600 2454.93) < (NVIDIA GeForce RTX 4070 Ti SUPER/PCIe/SSE2 2513.84)
and for GPU OpenGL Drawing came out one top?
(AMD Radeon RX 7600 4595.50) > (Radeon RX 7900 XTX 3512.29)
GPU Vulkan drawing not so fast
(AMD Radeon RX 7600 26607.16 ) < (AMD Radeon 8060S 43247.77)
Cache Memory
AMD Ryzen 7 9700X 163008.08|16x 5582.00 MHz
---------------- hardinfo 2 ------------------
System: Devuan 6 , Xfce
CPU:i7-4790
CPU Blowfish (Single-thread) 12.89
CPU Blowfish (Multi-thread) 75
CPU Blowfish (Multi-core) 50
CPU Zlib 73
CPU CryptoHash 32
CPU Fibonacci 2270
CPU N-Queens 1562
FPU FFT 148
FPU Raytracing (Single-thread) 2481
SysBench CPU (Single-thread) 1128 (*1)
SysBench CPU (Multi-thread) 7849(*1)
SysBench Memory (Single-thread) 7115(*1)
SysBench Memory (Multi-thread)18556(*1)
(*1) At the bottom is displayed: Alexey Kopytov's sysbench is required . But i see that sysbench is installed!
------------- Performance test (license:propr) --------------
CPU:i7-4790
@Benchmark/PassMark PerfomanceTest (11.0.1004) Results for Excalibur/i7-4790 CPU @ 3.60GHz (x86_64)
4 cores @ 7 MHz | 31.3 GiB RAM
ps:
This post was created in Excalibur/Netsurf where there was no cursor while editing and neither toolbar but hey .. its worked without js!
Also indeed the command proposed by @kapqa in this thread previously, in order to run the propriatory benchmark utiliy PerforanceTest in Devuan releases without libnurses 5 ,worked for me in Excalibur.
sudo ln -s /usr/lib/x86_64-linux-gnu/libncurses.so.6 /usr/lib/x86_64-linux-gnu/libncurses.so.5Last edited by chomwitt (2026-09-24 06:29:42)
Hardinfo2 has a 'Synchronize' command where our computing node and benchmark info are sent to a database.
@Their privacy policy.
When using the Synchronize feature in Hardinfo2, some information may be stored indefinitely in our servers.
I would like a foss to have an downloadable database in a form easily processed by foss .
The site has its gathered info organized nicely. I did a 'Sync' but the program gives no feedback neither about giving me a chance to see what info collected neither a link to the updated database.
So in that regard Passmark is better in giving you asap a link to your published data.
Thinking lately about the proliferation of rampant aggressive webcrawlers that feed their mama's big LLM with training data i think we should exercise extremely caution about our data and surely a foss license is not enough to cover that issues.
@ fwiw
Devuan 6 Excalibur Benchmark
https://www.passmark.com/baselines/V11/ … 2639353735
Hardinfo2 results - 9700X Generic System
Devuan 6 Excalibur - KDE on X11 -
https://sudden-bronze-ugdw17r5.edgeone.dev/
sorry for the interruption.
I managed to install v:2.3 in Excalibur from backports and executed a Syncronize command.
Sync do both benchmarks and it updates the hardinfo2 data.
Giving a usernote ( i gave nogroup:enouswater270926) i can access these benchmarks:
@. (in the first blank field drop the menu).
It seems that full report data are not uploaded.
After an Q&A with the programmer he says that tha db is freely downloadable.
Pages: 1
