#1 2026-09-15 03:35:13
alin
An interesting attempt to modify init->openrc-init
# Using OpenRC-init  as pid=1
Inspired by this [https://laskarnix.org/devuan-migrate-fr … enrc-init/], I tried the following approach on Devuan.
## 1. Create an empty package to replace `sysvinit-core`
I created an empty package named `openrc-init` with the following control information:
```text
Conflicts: sysvinit-core
Replaces: sysvinit-core
Provides: sysvinit-core
Depends: openrc
After installing this package, `sysvinit-core` is removed from the system.
## 2. Use `openrc-init` as PID 1
Create a symlink that points `/sbin/init` to the `openrc-init` provided by OpenRC:
```sh
ln -sf /sbin/openrc-init /sbin/init
I also created the `poweroff` and `reboot` commands.
### `poweroff`
```sh
exec /sbin/openrc-shutdown -p 0
### `reboot`
```sh
exec /sbin/openrc-shutdown -r 0
## 3. Create and enable TTY services
Create `agetty` service links for `tty1` through `tty6`, then add them to the default runlevel:
```sh
for n in $(seq 1 6); do
    ln -s agetty "agetty.tty$n"
    rc-update add "agetty.tty$n" default
done
The system was able to boot normally. 👍
## Idea
As more and more Debian packages remove support for SysV service scripts in the future, it may be possible to build a Devuan distribution centered around OpenRC without extensively modifying or rebuilding upstream Debian packages.
The general approach could be:
- Reuse upstream Debian SysV service scripts whenever they are still available, reducing maintenance work;
- When a service no longer has a usable SysV script, obtain an appropriate OpenRC service script from Gentoo or Alpine Linux;
- Provide a compatibility layer or adaptation mechanism so that existing Debian packages can continue to work in an OpenRC environment;
- Minimize modifications to upstream packages in order to reduce long-term maintenance costs.
In this way, Devuan could preserve the Debian package ecosystem while gradually building a more complete and independent initialization and service-management system centered around OpenRC.
#2 2026-09-15 07:37:24
Re: An interesting attempt to modify init->openrc-init
The "what" is easy, the "who" is hard.
#3 2026-09-19 14:01:59
alin
I have currently packaged this and written a script to automate the operations described above. I also modified some services from the original `initscripts` to use the OpenRC format, mainly by adding `depend()` functions and virtual dependencies. They can run and work properly.
However, I cannot think of a good way to handle the following issue: if `initscripts` or other software is upgraded or updated, it may overwrite my scripts with the newer versions. Copying the many OpenRC service files from Alpine may also be difficult to manage.
#4 2026-09-19 15:37:09
rbit
I believe that this can be handled via dpkg-divert?
#5 2026-09-19 18:08:21
tux_99
Isn't this problem already covered by the "orphan-sysvinit-scripts" package?
“Either the users control the program – or the program controls the users” Richard Stallman
#6 2026-09-21 10:42:11
alin
I don't understand how to quote or reply
Do not see an action button similar to @who, So I copied the original text directly:
[I believe that this can be handled via dpkg-divert?]
1.
Thanks for the reply
I read the dpkg-divert manual/etc/init.d/*as confiles
Say it may not be reliable
Maybe I can use a different name for service such as xxx-openrc(openrc) vs xxx(sysv)
[Isn't this problem already covered by the "orphan-sysvinit-scripts" package?]
2.There are fewer and fewer people maintaining sysv, so I still don't feel at ease. In addition,I Want to make an pure  openrc style devuan to play haha for fun
