#1 2026-09-12 10:50:41
jpthiran
Devuan without refracta
Good morning All.
Please, can you provide the link to download Devuan Excalibur without Refracta ?
I want to install Devuan the old way, as it works perfectly for me.
Thank you in advance for your help.
Best regards,
Jean-Pierre.
#2 2026-09-12 11:09:16
Re: Devuan without refracta
Look at the top of this page, there is a link to "Download | Devuan.org | .... ".
#3 2026-09-12 11:19:45
jpthiran
In the Devuan Release Archive there are 2 options:
- devuan_excalibur_6.1.1_amd64_desktop-live.iso - 2 G - desktop-live/
- devuan_excalibur_6.1.1_amd64_desktop.iso .----- 4 G - installer-iso/
I supose that these are the best links.
Which one is the correct ?
#4 2026-09-12 11:47:56
Use the installer-iso path to get to the options with the traditional installer. I typically use the netinstaller.
#5 2026-09-12 11:52:49
jpthiran
The answer is:
- devuan_excalibur_6.1.1_amd64_desktop.iso .----- 4 G - installer-iso/ - option 1 install (simple install)
In fact it's the easier way to install, much easier then Refracta
