Pages: 1
greetings
I recently upgraded my pc to devuan Excalibur, however, after loading into XFCE DE, desktop repeatedly crashes (mouse cursor moves on the screen, but click doesn't work), I had to do a reset, so far I have tried -
use a different web browser
boot into older kernel
but the issue persisted.
here's my system specs:
Intel NUC7i3BEH
16G memory
I had no problem with older devuan 6 Daedalus installed on the same system before upgrade.
Your post does not have much information from which to diagnose.
How long after the desktop loads do you observe the crash?
When the cash occurs are you able to switch to a basic console with Ctrl+Alt+2?
[Edit: That last part was a typo; I meant Ctrl+Alt+F2, but you should also try Ctrl+Alt+F1]
hi, thanks for the reply
it usually crashes after a few minutes of logging in to 'xfce' desktop, i tried Ctrl+Alt+2, nothing happened.
here's the output of 'dmsg'
[ 0.106666] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.106666] pinctrl core: initialized pinctrl subsystem
[ 0.106666] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.106666] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.106666] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.106666] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.106666] audit: initializing netlink subsys (disabled)
[ 0.106666] audit: type=2000 audit(1789343184.000:1): state=initialized audit_enabled=0 res=1
[ 0.106666] thermal_sys: Registered thermal governor 'fair_share'
[ 0.106666] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.106666] thermal_sys: Registered thermal governor 'step_wise'
[ 0.106666] thermal_sys: Registered thermal governor 'user_space'
[ 0.106666] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.106666] cpuidle: using governor ladder
[ 0.106666] cpuidle: using governor menu
[ 0.106666] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.106666] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.106666] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[ 0.106666] PCI: Using configuration type 1 for base access
[ 0.106666] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.106666] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.106666] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.106666] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.106666] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.109293] ACPI: Added _OSI(Module Device)
[ 0.109296] ACPI: Added _OSI(Processor Device)
[ 0.109298] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.174565] ACPI: 8 ACPI AML tables successfully acquired and loaded
[ 0.237602] ACPI: Dynamic OEM Table Load:
[ 0.237610] ACPI: SSDT 0xFFFF8C70C0FF8000 000400 (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ 0.238847] ACPI: Dynamic OEM Table Load:
[ 0.238853] ACPI: SSDT 0xFFFF8C70C0FD4800 000689 (v02 PmRef Cpu0Ist 00003000 INTL 20160527)
[ 0.240129] ACPI: Dynamic OEM Table Load:
[ 0.240134] ACPI: SSDT 0xFFFF8C70C0BDF800 0000F4 (v02 PmRef Cpu0Psd 00003000 INTL 20160527)
[ 0.241797] ACPI: Dynamic OEM Table Load:
[ 0.241803] ACPI: SSDT 0xFFFF8C70C0FD6800 0005FC (v02 PmRef ApIst 00003000 INTL 20160527)
[ 0.243085] ACPI: Dynamic OEM Table Load:
[ 0.243091] ACPI: SSDT 0xFFFF8C70C0FFA800 000317 (v02 PmRef ApHwp 00003000 INTL 20160527)
[ 0.244392] ACPI: Dynamic OEM Table Load:
[ 0.244398] ACPI: SSDT 0xFFFF8C70C0FDC000 000AB0 (v02 PmRef ApPsd 00003000 INTL 20160527)
[ 0.246179] ACPI: Dynamic OEM Table Load:
[ 0.246184] ACPI: SSDT 0xFFFF8C70C0FFB400 00030A (v02 PmRef ApCst 00003000 INTL 20160527)
[ 0.249039] ACPI: EC: EC started
[ 0.249040] ACPI: EC: interrupt blocked
[ 0.249890] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.249893] ACPI: \_SB_.PCI0.LPCB.H_EC: Boot DSDT EC used to handle transactions
[ 0.249895] ACPI: Interpreter enabled
[ 0.249936] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.249937] ACPI: Using IOAPIC for interrupt routing
[ 0.249977] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.249979] PCI: Ignoring E820 reservations for host bridge windows
[ 0.251108] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.267262] ACPI: \_SB_.PCI0.XDCI.USBC: New power resource
[ 0.270507] ACPI: \_SB_.PCI0.SAT0.VOL0.V0PR: New power resource
[ 0.270906] ACPI: \_SB_.PCI0.SAT0.VOL1.V1PR: New power resource
[ 0.271296] ACPI: \_SB_.PCI0.SAT0.VOL2.V2PR: New power resource
[ 0.282921] ACPI: \_SB_.PCI0.CNVW.WRST: New power resource
[ 0.287593] ACPI: \_TZ_.FN00: New power resource
[ 0.287669] ACPI: \_TZ_.FN01: New power resource
[ 0.287742] ACPI: \_TZ_.FN02: New power resource
[ 0.287817] ACPI: \_TZ_.FN03: New power resource
[ 0.287890] ACPI: \_TZ_.FN04: New power resource
[ 0.288561] ACPI: \PIN_: New power resource
[ 0.289484] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.289492] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 0.290577] acpi PNP0A08:00: _OSC: platform does not support [AER]
[ 0.292696] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR]
[ 0.292698] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.294027] PCI host bridge to bus 0000:00
[ 0.294031] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.294034] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.294036] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.294038] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.294039] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[ 0.294041] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.294043] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.294129] pci 0000:00:00.0: [8086:3ecc] type 00 class 0x060000 conventional PCI endpoint
[ 0.294218] pci 0000:00:02.0: [8086:3ea5] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
[ 0.294228] pci 0000:00:02.0: BAR 0 [mem 0xa7000000-0xa7ffffff 64bit]
[ 0.294235] pci 0000:00:02.0: BAR 2 [mem 0x80000000-0x8fffffff 64bit pref]
[ 0.294240] pci 0000:00:02.0: BAR 4 [io 0x4000-0x403f]
[ 0.294258] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.294452] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000 conventional PCI endpoint
[ 0.294465] pci 0000:00:08.0: BAR 0 [mem 0x4022c1a000-0x4022c1afff 64bit]
[ 0.294604] pci 0000:00:12.0: [8086:9df9] type 00 class 0x118000 conventional PCI endpoint
[ 0.294623] pci 0000:00:12.0: BAR 0 [mem 0x4022c19000-0x4022c19fff 64bit]
[ 0.294779] pci 0000:00:14.0: [8086:9ded] type 00 class 0x0c0330 conventional PCI endpoint
[ 0.294795] pci 0000:00:14.0: BAR 0 [mem 0x4022c00000-0x4022c0ffff 64bit]
[ 0.294853] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.296278] pci 0000:00:14.2: [8086:9def] type 00 class 0x050000 conventional PCI endpoint
[ 0.296298] pci 0000:00:14.2: BAR 0 [mem 0x4022c14000-0x4022c15fff 64bit]
[ 0.296312] pci 0000:00:14.2: BAR 2 [mem 0x4022c18000-0x4022c18fff 64bit]
[ 0.297143] pci 0000:00:14.3: [8086:9df0] type 00 class 0x028000 PCIe Root Complex Integrated Endpoint
[ 0.298176] pci 0000:00:14.3: BAR 0 [mem 0x4022c10000-0x4022c13fff 64bit]
[ 0.303063] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[ 0.304368] pci 0000:00:16.0: [8086:9de0] type 00 class 0x078000 conventional PCI endpoint
[ 0.304392] pci 0000:00:16.0: BAR 0 [mem 0x4022c17000-0x4022c17fff 64bit]
[ 0.304482] pci 0000:00:16.0: PME# supported from D3hot
[ 0.304905] pci 0000:00:17.0: [8086:9dd3] type 00 class 0x010601 conventional PCI endpoint
[ 0.304919] pci 0000:00:17.0: BAR 0 [mem 0xa8a24000-0xa8a25fff]
[ 0.304928] pci 0000:00:17.0: BAR 1 [mem 0xa8a27000-0xa8a270ff]
[ 0.304936] pci 0000:00:17.0: BAR 2 [io 0x4090-0x4097]
[ 0.304944] pci 0000:00:17.0: BAR 3 [io 0x4080-0x4083]
[ 0.304951] pci 0000:00:17.0: BAR 4 [io 0x4060-0x407f]
[ 0.304959] pci 0000:00:17.0: BAR 5 [mem 0xa8a26000-0xa8a267ff]
[ 0.305000] pci 0000:00:17.0: PME# supported from D3hot
[ 0.305319] pci 0000:00:1c.0: [8086:9db8] type 01 class 0x060400 PCIe Root Port
[ 0.305343] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.305407] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.305960] pci 0000:00:1c.4: [8086:9dbc] type 01 class 0x060400 PCIe Root Port
[ 0.305982] pci 0000:00:1c.4: PCI bridge to [bus 02-3a]
[ 0.305987] pci 0000:00:1c.4: bridge window [mem 0x90000000-0xa60fffff]
[ 0.305995] pci 0000:00:1c.4: bridge window [mem 0x4000000000-0x4021ffffff 64bit pref]
[ 0.306053] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.306079] pci 0000:00:1c.4: PTM enabled (root), 4ns granularity
[ 0.306635] pci 0000:00:1d.0: [8086:9db0] type 01 class 0x060400 PCIe Root Port
[ 0.306659] pci 0000:00:1d.0: PCI bridge to [bus 3b]
[ 0.306724] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.307272] pci 0000:00:1d.6: [8086:9db6] type 01 class 0x060400 PCIe Root Port
[ 0.307296] pci 0000:00:1d.6: PCI bridge to [bus 3c]
[ 0.307300] pci 0000:00:1d.6: bridge window [io 0x3000-0x3fff]
[ 0.307303] pci 0000:00:1d.6: bridge window [mem 0xa8000000-0xa89fffff]
[ 0.307311] pci 0000:00:1d.6: bridge window [mem 0x4022100000-0x4022afffff 64bit pref]
[ 0.307376] pci 0000:00:1d.6: PME# supported from D0 D3hot D3cold
[ 0.307407] pci 0000:00:1d.6: PTM enabled (root), 4ns granularity
[ 0.307943] pci 0000:00:1f.0: [8086:9d84] type 00 class 0x060100 conventional PCI endpoint
[ 0.308353] pci 0000:00:1f.3: [8086:9dc8] type 00 class 0x040380 conventional PCI endpoint
[ 0.308391] pci 0000:00:1f.3: BAR 0 [mem 0xa8a20000-0xa8a23fff 64bit]
[ 0.308444] pci 0000:00:1f.3: BAR 4 [mem 0x4022b00000-0x4022bfffff 64bit]
[ 0.308536] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.311345] pci 0000:00:1f.4: [8086:9da3] type 00 class 0x0c0500 conventional PCI endpoint
[ 0.311371] pci 0000:00:1f.4: BAR 0 [mem 0x4022c16000-0x4022c160ff 64bit]
[ 0.311400] pci 0000:00:1f.4: BAR 4 [io 0xefa0-0xefbf]
[ 0.311632] pci 0000:00:1f.5: [8086:9da4] type 00 class 0x0c8000 conventional PCI endpoint
[ 0.311649] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]
[ 0.311772] pci 0000:00:1f.6: [8086:15be] type 00 class 0x020000 conventional PCI endpoint
[ 0.311808] pci 0000:00:1f.6: BAR 0 [mem 0xa8a00000-0xa8a1ffff]
[ 0.311988] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[ 0.312192] acpiphp: Slot [1] registered
[ 0.312199] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.312334] pci 0000:02:00.0: [8086:15da] type 01 class 0x060400 PCIe Switch Upstream Port
[ 0.312368] pci 0000:02:00.0: PCI bridge to [bus 03-3a]
[ 0.312378] pci 0000:02:00.0: bridge window [mem 0x90000000-0xa60fffff]
[ 0.312390] pci 0000:02:00.0: bridge window [mem 0x4000000000-0x4021ffffff 64bit pref]
[ 0.312404] pci 0000:02:00.0: enabling Extended Tags
[ 0.312497] pci 0000:02:00.0: supports D1 D2
[ 0.312499] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.312709] pci 0000:00:1c.4: PCI bridge to [bus 02-3a]
[ 0.312790] pci 0000:03:00.0: [8086:15da] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.312825] pci 0000:03:00.0: PCI bridge to [bus 04]
[ 0.312834] pci 0000:03:00.0: bridge window [mem 0xa6000000-0xa60fffff]
[ 0.312861] pci 0000:03:00.0: enabling Extended Tags
[ 0.312959] pci 0000:03:00.0: supports D1 D2
[ 0.312961] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.313144] pci 0000:03:01.0: [8086:15da] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.313181] pci 0000:03:01.0: PCI bridge to [bus 05-39]
[ 0.313191] pci 0000:03:01.0: bridge window [mem 0x90000000-0xa5efffff]
[ 0.313203] pci 0000:03:01.0: bridge window [mem 0x4000000000-0x4021ffffff 64bit pref]
[ 0.313220] pci 0000:03:01.0: enabling Extended Tags
[ 0.313321] pci 0000:03:01.0: supports D1 D2
[ 0.313322] pci 0000:03:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.313499] pci 0000:03:02.0: [8086:15da] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.313534] pci 0000:03:02.0: PCI bridge to [bus 3a]
[ 0.313544] pci 0000:03:02.0: bridge window [mem 0xa5f00000-0xa5ffffff]
[ 0.313570] pci 0000:03:02.0: enabling Extended Tags
[ 0.313662] pci 0000:03:02.0: supports D1 D2
[ 0.313664] pci 0000:03:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.313871] pci 0000:02:00.0: PCI bridge to [bus 03-3a]
[ 0.313924] pci 0000:03:00.0: PCI bridge to [bus 04]
[ 0.313977] pci 0000:03:01.0: PCI bridge to [bus 05-39]
[ 0.314076] pci 0000:3a:00.0: [8086:15db] type 00 class 0x0c0330 PCIe Endpoint
[ 0.314099] pci 0000:3a:00.0: BAR 0 [mem 0xa5f00000-0xa5f0ffff]
[ 0.314176] pci 0000:3a:00.0: enabling Extended Tags
[ 0.314303] pci 0000:3a:00.0: supports D1 D2
[ 0.314305] pci 0000:3a:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.314576] pci 0000:03:02.0: PCI bridge to [bus 3a]
[ 0.314739] pci 0000:00:1d.0: PCI bridge to [bus 3b]
[ 0.314936] pci 0000:3c:00.0: [10ec:522a] type 00 class 0xff0000 PCIe Endpoint
[ 0.314957] pci 0000:3c:00.0: BAR 0 [mem 0xa8000000-0xa8000fff]
[ 0.315105] pci 0000:3c:00.0: supports D1 D2
[ 0.315107] pci 0000:3c:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.315396] pci 0000:00:1d.6: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 0.321334] pci 0000:00:1d.6: PCI bridge to [bus 3c]
[ 0.324583] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.324664] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[ 0.324743] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.324822] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.324900] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.324978] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.325056] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.325134] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.329720] ACPI: EC: interrupt unblocked
[ 0.329722] ACPI: EC: event unblocked
[ 0.329733] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.329735] ACPI: EC: GPE=0x14
[ 0.329737] ACPI: \_SB_.PCI0.LPCB.H_EC: Boot DSDT EC initialization complete
[ 0.329739] ACPI: \_SB_.PCI0.LPCB.H_EC: EC: Used to handle transactions and events
[ 0.329831] iommu: Default domain type: Translated
[ 0.329831] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.329831] pps_core: LinuxPPS API ver. 1 registered
[ 0.329831] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.329831] PTP clock support registered
[ 0.329831] EDAC MC: Ver: 3.0.0
[ 0.329831] NetLabel: Initializing
[ 0.329831] NetLabel: domain hash size = 128
[ 0.329831] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.329831] NetLabel: unlabeled traffic allowed by default
[ 0.329831] PCI: Using ACPI for IRQ routing
[ 0.356710] PCI: pci_cache_line_size set to 64 bytes
[ 0.357034] e820: reserve RAM buffer [mem 0x0009d400-0x0009ffff]
[ 0.357036] e820: reserve RAM buffer [mem 0x796ff000-0x7bffffff]
[ 0.357038] e820: reserve RAM buffer [mem 0x7ad0f000-0x7bffffff]
[ 0.357039] e820: reserve RAM buffer [mem 0x47e000000-0x47fffffff]
[ 0.357223] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.357223] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.357223] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.357223] vgaarb: loaded
[ 0.357236] clocksource: Switched to clocksource tsc-early
[ 0.357927] VFS: Disk quotas dquot_6.6.0
[ 0.357942] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.358092] AppArmor: AppArmor Filesystem Enabled
[ 0.358111] pnp: PnP ACPI init
[ 0.358195] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
[ 0.358554] system 00:01: [io 0x0a00-0x0a1f] has been reserved
[ 0.358557] system 00:01: [io 0x0a20-0x0a2f] has been reserved
[ 0.358559] system 00:01: [io 0x0a30-0x0a3f] has been reserved
[ 0.358561] system 00:01: [io 0x0a40-0x0a4f] has been reserved
[ 0.358562] system 00:01: [io 0x0a50-0x0a5f] has been reserved
[ 0.358564] system 00:01: [io 0x0a60-0x0a6f] has been reserved
[ 0.358787] system 00:02: [io 0x0680-0x069f] has been reserved
[ 0.358789] system 00:02: [io 0x164e-0x164f] has been reserved
[ 0.359007] system 00:03: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.359010] system 00:03: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.359012] system 00:03: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.359015] system 00:03: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.359017] system 00:03: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.359019] system 00:03: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.359021] system 00:03: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.359023] system 00:03: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.359263] system 00:04: [io 0x1800-0x18fe] could not be reserved
[ 0.359266] system 00:04: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 0.359269] system 00:04: [mem 0xfd6b0000-0xfd6cffff] has been reserved
[ 0.359271] system 00:04: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.359273] system 00:04: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.359275] system 00:04: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.359278] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[ 0.359568] system 00:05: [io 0x2000-0x20fe] has been reserved
[ 0.361424] pnp: PnP ACPI: found 7 devices
[ 0.367179] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.367240] NET: Registered PF_INET protocol family
[ 0.367371] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.382622] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.382650] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.382701] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.382917] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.383159] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.383241] MPTCP token hash table entries: 16384 (order: 7, 393216 bytes, linear)
[ 0.383295] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.383334] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.383394] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.383401] NET: Registered PF_XDP protocol family
[ 0.383413] pci 0000:03:01.0: bridge window [io 0x1000-0x0fff] to [bus 05-39] add_size 1000
[ 0.383419] pci 0000:02:00.0: bridge window [io 0x1000-0x0fff] to [bus 03-3a] add_size 1000
[ 0.383421] pci 0000:00:1c.4: bridge window [io 0x1000-0x0fff] to [bus 02-3a] add_size 2000
[ 0.383423] pci 0000:00:1d.0: bridge window [io 0x1000-0x0fff] to [bus 3b] add_size 1000
[ 0.383426] pci 0000:00:1d.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 3b] add_size 200000 add_align 100000
[ 0.383429] pci 0000:00:1d.0: bridge window [mem 0x00100000-0x000fffff] to [bus 3b] add_size 200000 add_align 100000
[ 0.383438] pci 0000:00:1d.0: bridge window [mem 0xa6100000-0xa62fffff]: assigned
[ 0.383442] pci 0000:00:1d.0: bridge window [mem 0x4022d00000-0x4022efffff 64bit pref]: assigned
[ 0.383446] pci 0000:00:1c.4: bridge window [io 0x5000-0x6fff]: assigned
[ 0.383448] pci 0000:00:1d.0: bridge window [io 0x7000-0x7fff]: assigned
[ 0.383452] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.383465] pci 0000:02:00.0: bridge window [io 0x5000-0x5fff]: assigned
[ 0.383467] pci 0000:03:01.0: bridge window [io 0x5000-0x5fff]: assigned
[ 0.383469] pci 0000:03:00.0: PCI bridge to [bus 04]
[ 0.383474] pci 0000:03:00.0: bridge window [mem 0xa6000000-0xa60fffff]
[ 0.383483] pci 0000:03:01.0: PCI bridge to [bus 05-39]
[ 0.383486] pci 0000:03:01.0: bridge window [io 0x5000-0x5fff]
[ 0.383491] pci 0000:03:01.0: bridge window [mem 0x90000000-0xa5efffff]
[ 0.383495] pci 0000:03:01.0: bridge window [mem 0x4000000000-0x4021ffffff 64bit pref]
[ 0.383502] pci 0000:03:02.0: PCI bridge to [bus 3a]
[ 0.383507] pci 0000:03:02.0: bridge window [mem 0xa5f00000-0xa5ffffff]
[ 0.383515] pci 0000:02:00.0: PCI bridge to [bus 03-3a]
[ 0.383518] pci 0000:02:00.0: bridge window [io 0x5000-0x5fff]
[ 0.383523] pci 0000:02:00.0: bridge window [mem 0x90000000-0xa60fffff]
[ 0.383527] pci 0000:02:00.0: bridge window [mem 0x4000000000-0x4021ffffff 64bit pref]
[ 0.383533] pci 0000:00:1c.4: PCI bridge to [bus 02-3a]
[ 0.383535] pci 0000:00:1c.4: bridge window [io 0x5000-0x6fff]
[ 0.383539] pci 0000:00:1c.4: bridge window [mem 0x90000000-0xa60fffff]
[ 0.383542] pci 0000:00:1c.4: bridge window [mem 0x4000000000-0x4021ffffff 64bit pref]
[ 0.383546] pci 0000:00:1d.0: PCI bridge to [bus 3b]
[ 0.383550] pci 0000:00:1d.0: bridge window [io 0x7000-0x7fff]
[ 0.383554] pci 0000:00:1d.0: bridge window [mem 0xa6100000-0xa62fffff]
[ 0.383557] pci 0000:00:1d.0: bridge window [mem 0x4022d00000-0x4022efffff 64bit pref]
[ 0.383562] pci 0000:00:1d.6: PCI bridge to [bus 3c]
[ 0.383564] pci 0000:00:1d.6: bridge window [io 0x3000-0x3fff]
[ 0.383568] pci 0000:00:1d.6: bridge window [mem 0xa8000000-0xa89fffff]
[ 0.383571] pci 0000:00:1d.6: bridge window [mem 0x4022100000-0x4022afffff 64bit pref]
[ 0.383577] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.383579] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.383581] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.383582] pci_bus 0000:00: resource 7 [mem 0x80000000-0xdfffffff window]
[ 0.383584] pci_bus 0000:00: resource 8 [mem 0x4000000000-0x7fffffffff window]
[ 0.383586] pci_bus 0000:00: resource 9 [mem 0xfc800000-0xfe7fffff window]
[ 0.383588] pci_bus 0000:02: resource 0 [io 0x5000-0x6fff]
[ 0.383590] pci_bus 0000:02: resource 1 [mem 0x90000000-0xa60fffff]
[ 0.383591] pci_bus 0000:02: resource 2 [mem 0x4000000000-0x4021ffffff 64bit pref]
[ 0.383593] pci_bus 0000:03: resource 0 [io 0x5000-0x5fff]
[ 0.383595] pci_bus 0000:03: resource 1 [mem 0x90000000-0xa60fffff]
[ 0.383596] pci_bus 0000:03: resource 2 [mem 0x4000000000-0x4021ffffff 64bit pref]
[ 0.383598] pci_bus 0000:04: resource 1 [mem 0xa6000000-0xa60fffff]
[ 0.383600] pci_bus 0000:05: resource 0 [io 0x5000-0x5fff]
[ 0.383601] pci_bus 0000:05: resource 1 [mem 0x90000000-0xa5efffff]
[ 0.383603] pci_bus 0000:05: resource 2 [mem 0x4000000000-0x4021ffffff 64bit pref]
[ 0.383605] pci_bus 0000:3a: resource 1 [mem 0xa5f00000-0xa5ffffff]
[ 0.383606] pci_bus 0000:3b: resource 0 [io 0x7000-0x7fff]
[ 0.383608] pci_bus 0000:3b: resource 1 [mem 0xa6100000-0xa62fffff]
[ 0.383609] pci_bus 0000:3b: resource 2 [mem 0x4022d00000-0x4022efffff 64bit pref]
[ 0.383611] pci_bus 0000:3c: resource 0 [io 0x3000-0x3fff]
[ 0.383613] pci_bus 0000:3c: resource 1 [mem 0xa8000000-0xa89fffff]
[ 0.383614] pci_bus 0000:3c: resource 2 [mem 0x4022100000-0x4022afffff 64bit pref]
[ 0.384191] pci 0000:02:00.0: CLS mismatch (64 != 128), using 64 bytes
[ 0.384300] pci 0000:02:00.0: enabling device (0006 -> 0007)
[ 0.384540] DMAR: No ATSR found
[ 0.384542] DMAR: No SATC found
[ 0.384544] DMAR: IOMMU feature fl1gp_support inconsistent
[ 0.384546] DMAR: IOMMU feature pgsel_inv inconsistent
[ 0.384547] DMAR: IOMMU feature nwfs inconsistent
[ 0.384548] DMAR: IOMMU feature pasid inconsistent
[ 0.384550] DMAR: IOMMU feature eafs inconsistent
[ 0.384551] DMAR: IOMMU feature prs inconsistent
[ 0.384552] DMAR: IOMMU feature nest inconsistent
[ 0.384553] DMAR: IOMMU feature mts inconsistent
[ 0.384554] DMAR: IOMMU feature sc_support inconsistent
[ 0.384555] DMAR: IOMMU feature dev_iotlb_support inconsistent
[ 0.384557] DMAR: dmar0: Using Queued invalidation
[ 0.384561] DMAR: dmar1: Using Queued invalidation
[ 0.384592] Trying to unpack rootfs image as initramfs...
[ 0.384799] pci 0000:00:02.0: Adding to iommu group 0
[ 0.384847] pci 0000:00:00.0: Adding to iommu group 1
[ 0.384861] pci 0000:00:08.0: Adding to iommu group 2
[ 0.384879] pci 0000:00:12.0: Adding to iommu group 3
[ 0.384904] pci 0000:00:14.0: Adding to iommu group 4
[ 0.384917] pci 0000:00:14.2: Adding to iommu group 4
[ 0.384930] pci 0000:00:14.3: Adding to iommu group 5
[ 0.384947] pci 0000:00:16.0: Adding to iommu group 6
[ 0.384960] pci 0000:00:17.0: Adding to iommu group 7
[ 0.384982] pci 0000:00:1c.0: Adding to iommu group 8
[ 0.384998] pci 0000:00:1c.4: Adding to iommu group 9
[ 0.385021] pci 0000:00:1d.0: Adding to iommu group 10
[ 0.385039] pci 0000:00:1d.6: Adding to iommu group 11
[ 0.385077] pci 0000:00:1f.0: Adding to iommu group 12
[ 0.385091] pci 0000:00:1f.3: Adding to iommu group 12
[ 0.385105] pci 0000:00:1f.4: Adding to iommu group 12
[ 0.385119] pci 0000:00:1f.5: Adding to iommu group 12
[ 0.385133] pci 0000:00:1f.6: Adding to iommu group 12
[ 0.385150] pci 0000:02:00.0: Adding to iommu group 13
[ 0.385167] pci 0000:03:00.0: Adding to iommu group 14
[ 0.385183] pci 0000:03:01.0: Adding to iommu group 15
[ 0.385199] pci 0000:03:02.0: Adding to iommu group 16
[ 0.385207] pci 0000:3a:00.0: Adding to iommu group 16
[ 0.385223] pci 0000:3c:00.0: Adding to iommu group 17
[ 0.386579] DMAR: Intel(R) Virtualization Technology for Directed I/O
[ 0.386583] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.386585] software IO TLB: mapped [mem 0x00000000756ff000-0x00000000796ff000] (64MB)
[ 0.386676] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.387152] Initialise system trusted keyrings
[ 0.387163] Key type blacklist registered
[ 0.387213] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[ 0.387225] zbud: loaded
[ 0.387321] fuse: init (API version 7.41)
[ 0.387458] integrity: Platform Keyring initialized
[ 0.387467] integrity: Machine keyring initialized
[ 0.415851] Key type asymmetric registered
[ 0.415857] Asymmetric key parser 'x509' registered
[ 0.455630] Freeing initrd memory: 32092K
[ 0.460655] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.460689] io scheduler mq-deadline registered
[ 0.464130] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.464234] pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
[ 0.464361] pcieport 0000:00:1c.4: PME: Signaling with IRQ 123
[ 0.464388] pcieport 0000:00:1c.4: pciehp: Slot #8 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.464569] pcieport 0000:00:1d.0: PME: Signaling with IRQ 124
[ 0.464597] pcieport 0000:00:1d.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.464896] pcieport 0000:00:1d.6: PME: Signaling with IRQ 125
[ 0.464918] pcieport 0000:00:1d.6: pciehp: Slot #18 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.465365] pcieport 0000:03:01.0: enabling device (0006 -> 0007)
[ 0.465479] pcieport 0000:03:01.0: pciehp: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.465782] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.466469] ACPI: thermal: [Firmware Bug]: No valid trip points!
[ 0.466512] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.466514] ACPI: thermal: Thermal Zone [TZ0] (-263 C)
[ 0.466816] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.466818] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[ 0.466932] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.467576] hpet_acpi_add: no address or irqs in _CRS
[ 0.467604] Linux agpgart interface v0.103
[ 1.251063] i8042: PNP: No PS/2 controller found.
[ 1.251067] i8042: Probing ports directly.
[ 1.252187] i8042: No controller found
[ 1.252318] mousedev: PS/2 mouse device common for all mice
[ 1.252352] rtc_cmos rtc_cmos: RTC can wake from S4
[ 1.253601] rtc_cmos rtc_cmos: registered as rtc0
[ 1.253827] rtc_cmos rtc_cmos: setting system clock to 2026-09-13T23:46:25 UTC (1789343185)
[ 1.253854] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 1.253985] intel_pstate: Intel P-state driver initializing
[ 1.254171] intel_pstate: HWP enabled
[ 1.254489] NET: Registered PF_INET6 protocol family
[ 1.258880] Segment Routing with IPv6
[ 1.258894] In-situ OAM (IOAM) with IPv6
[ 1.258919] mip6: Mobile IPv6
[ 1.258923] NET: Registered PF_PACKET protocol family
[ 1.258948] mpls_gso: MPLS GSO support
[ 1.259198] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 1.259242] microcode: Current revision: 0x000000f4
[ 1.259408] IPI shorthand broadcast: enabled
[ 1.261068] sched_clock: Marking stable (1248339877, 11048977)->(1294446437, -35057583)
[ 1.261269] registered taskstats version 1
[ 1.261382] Loading compiled-in X.509 certificates
[ 1.267239] pci_bus 0000:04: Allocating resources
[ 1.267250] pci_bus 0000:3a: Allocating resources
[ 1.280292] Loaded X.509 cert 'Build time autogenerated kernel key: 1377f7e66160198e27a736ed1bf2551bff25bd3d'
[ 1.282151] Demotion targets for Node 0: null
[ 1.282277] Key type .fscrypt registered
[ 1.282280] Key type fscrypt-provisioning registered
[ 1.300862] Key type encrypted registered
[ 1.300867] AppArmor: AppArmor sha256 policy hashing enabled
[ 1.300876] ima: Allocated hash algorithm: sha256
[ 1.317729] ima: No architecture policies found
[ 1.317744] evm: Initialising EVM extended attributes:
[ 1.317745] evm: security.selinux
[ 1.317746] evm: security.SMACK64 (disabled)
[ 1.317747] evm: security.SMACK64EXEC (disabled)
[ 1.317748] evm: security.SMACK64TRANSMUTE (disabled)
[ 1.317749] evm: security.SMACK64MMAP (disabled)
[ 1.317750] evm: security.apparmor
[ 1.317750] evm: security.ima
[ 1.317751] evm: security.capability
[ 1.317752] evm: HMAC attrs: 0x1
[ 1.318582] RAS: Correctable Errors collector initialized.
[ 1.322919] clk: Disabling unused clocks
[ 1.322922] PM: genpd: Disabling unused power domains
[ 1.324286] Freeing unused decrypted memory: 2028K
[ 1.324736] Freeing unused kernel image (initmem) memory: 4168K
[ 1.324804] Write protecting the kernel read-only data: 28672k
[ 1.325133] Freeing unused kernel image (rodata/data gap) memory: 472K
[ 1.371523] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.371526] x86/mm: Checking user space page tables
[ 1.412692] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.412722] Run /init as init process
[ 1.412723] with arguments:
[ 1.412725] /init
[ 1.412726] with environment:
[ 1.412726] HOME=/
[ 1.412727] TERM=linux
[ 1.419479] tsc: Refined TSC clocksource calibration: 2999.999 MHz
[ 1.419485] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b3e44b2357, max_idle_ns: 440795324996 ns
[ 1.419512] clocksource: Switched to clocksource tsc
[ 1.429755] udevd[177]: starting version 3.2.14
[ 1.430588] udevd[179]: starting eudev-3.2.14
[ 1.482228] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 1.482277] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 1.484146] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 1.504707] SCSI subsystem initialized
[ 1.532919] e1000e: Intel(R) PRO/1000 Network Driver
[ 1.532922] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.533165] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.534568] ACPI: bus type USB registered
[ 1.534601] usbcore: registered new interface driver usbfs
[ 1.534612] usbcore: registered new interface driver hub
[ 1.534626] usbcore: registered new device driver usb
[ 1.546465] libata version 3.00 loaded.
[ 1.559338] ahci 0000:00:17.0: version 3.0
[ 1.569658] ahci 0000:00:17.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[ 1.569663] ahci 0000:00:17.0: 1/1 ports implemented (port mask 0x4)
[ 1.569664] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part deso sadm sds apst
[ 1.570119] scsi host0: ahci
[ 1.570263] scsi host1: ahci
[ 1.570381] scsi host2: ahci
[ 1.570431] ata1: DUMMY
[ 1.570433] ata2: DUMMY
[ 1.570438] ata3: SATA max UDMA/133 abar m2048@0xa8a26000 port 0xa8a26200 irq 131 lpm-pol 3
[ 1.771477] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[ 1.835561] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 1c:69:7a:a7:7a:02
[ 1.835576] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[ 1.835670] e1000e 0000:00:1f.6 eth0: MAC: 13, PHY: 12, PBA No: FFFFFF-0FF
[ 1.883789] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.884021] ata3.00: ATA-10: Corsair Force LS SSD, S9FM01.8, max UDMA/133
[ 1.884126] ata3.00: 117231408 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.884451] ata3.00: configured for UDMA/133
[ 1.884765] scsi 2:0:0:0: Direct-Access ATA Corsair Force LS 01.8 PQ: 0 ANSI: 5
[ 1.912096] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.912119] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.913422] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 1.914061] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.914076] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.914088] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.914210] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[ 1.914219] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.914224] usb usb1: Product: xHCI Host Controller
[ 1.914229] usb usb1: Manufacturer: Linux 6.12.96+deb13-amd64 xhci-hcd
[ 1.914233] usb usb1: SerialNumber: 0000:00:14.0
[ 1.914603] hub 1-0:1.0: USB hub found
[ 1.914635] hub 1-0:1.0: 12 ports detected
[ 1.917644] sd 2:0:0:0: [sda] 117231408 512-byte logical blocks: (60.0 GB/55.9 GiB)
[ 1.917674] sd 2:0:0:0: [sda] Write Protect is off
[ 1.917682] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.917718] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.917781] sd 2:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[ 1.919397] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[ 1.919412] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.919421] usb usb2: Product: xHCI Host Controller
[ 1.919427] usb usb2: Manufacturer: Linux 6.12.96+deb13-amd64 xhci-hcd
[ 1.919435] usb usb2: SerialNumber: 0000:00:14.0
[ 1.919857] hub 2-0:1.0: USB hub found
[ 1.919892] hub 2-0:1.0: 6 ports detected
[ 1.922520] xhci_hcd 0000:3a:00.0: xHCI Host Controller
[ 1.922535] xhci_hcd 0000:3a:00.0: new USB bus registered, assigned bus number 3
[ 1.923816] xhci_hcd 0000:3a:00.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000200009810
[ 1.924310] xhci_hcd 0000:3a:00.0: xHCI Host Controller
[ 1.924324] xhci_hcd 0000:3a:00.0: new USB bus registered, assigned bus number 4
[ 1.924336] xhci_hcd 0000:3a:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.924422] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[ 1.924430] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.924435] usb usb3: Product: xHCI Host Controller
[ 1.924439] usb usb3: Manufacturer: Linux 6.12.96+deb13-amd64 xhci-hcd
[ 1.924443] usb usb3: SerialNumber: 0000:3a:00.0
[ 1.924803] hub 3-0:1.0: USB hub found
[ 1.924835] hub 3-0:1.0: 2 ports detected
[ 1.925701] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[ 1.925710] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.925715] usb usb4: Product: xHCI Host Controller
[ 1.925719] usb usb4: Manufacturer: Linux 6.12.96+deb13-amd64 xhci-hcd
[ 1.925723] usb usb4: SerialNumber: 0000:3a:00.0
[ 1.926089] hub 4-0:1.0: USB hub found
[ 1.926135] hub 4-0:1.0: 2 ports detected
[ 1.940670] sda: sda1 sda2 < sda5 sda6 >
[ 1.941548] sd 2:0:0:0: [sda] Attached SCSI disk
[ 2.035583] PM: Image not found (code -22)
[ 2.167062] usb 1-2: new full-speed USB device number 2 using xhci_hcd
[ 2.247164] EXT4-fs (sda1): mounted filesystem b9ed5f46-3447-4b23-a84a-c208188228c3 ro with ordered data mode. Quota mode: none.
[ 2.296825] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 2.306250] usb 1-2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.01
[ 2.306257] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.306259] usb 1-2: Product: USB Receiver
[ 2.306261] usb 1-2: Manufacturer: Logitech
[ 2.427099] usb 1-3: new high-speed USB device number 3 using xhci_hcd
[ 2.551541] udevd[450]: starting version 3.2.14
[ 2.567932] usb 1-3: New USB device found, idVendor=0781, idProduct=556b, bcdDevice= 1.27
[ 2.567938] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.567941] usb 1-3: Product: Cruzer Edge
[ 2.567943] usb 1-3: Manufacturer: SanDisk
[ 2.567945] usb 1-3: SerialNumber: 4C530301240113000181
[ 2.601415] udevd[450]: unknown key 'SYSFS{idVendor}' in /etc/udev/rules.d/60-brother-libsane-type1-inst.rules:14
[ 2.601562] udevd[450]: invalid rule '/etc/udev/rules.d/60-brother-libsane-type1-inst.rules:14'
[ 2.655245] udevd[450]: GOTO 'alsa_restore_std' has no matching label in: '/usr/lib/udev/rules.d/90-alsa-restore.rules'
[ 2.655394] udevd[450]: GOTO 'alsa_restore_std' has no matching label in: '/usr/lib/udev/rules.d/90-alsa-restore.rules'
[ 2.664916] udevd[451]: starting eudev-3.2.14
[ 2.687090] usb 1-4: new full-speed USB device number 4 using xhci_hcd
[ 2.720070] usb-storage 1-3:1.0: USB Mass Storage device detected
[ 2.720205] scsi host3: usb-storage 1-3:1.0
[ 2.720284] usbcore: registered new interface driver usb-storage
[ 2.726159] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 2.726208] ACPI: button: Sleep Button [SLPB]
[ 2.726254] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 2.726280] ACPI: button: Power Button [PWRB]
[ 2.730908] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 2.732349] usbcore: registered new interface driver uas
[ 2.732380] ACPI: button: Power Button [PWRF]
[ 2.768110] intel_pmc_core INT33A1:00: initialized
[ 2.798361] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 2.805565] input: PC Speaker as /devices/platform/pcspkr/input/input3
[ 2.829815] usb 1-4: New USB device found, idVendor=046d, idProduct=c52f, bcdDevice=22.01
[ 2.829822] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.829824] usb 1-4: Product: USB Receiver
[ 2.829826] usb 1-4: Manufacturer: Logitech
[ 2.859620] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 2.963104] usb 1-10: new full-speed USB device number 5 using xhci_hcd
[ 2.969675] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 2.969680] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 2.969682] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 2.969683] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 2.969684] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 2.969686] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 2.972855] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.986908] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[ 2.987139] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[ 2.987346] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.987555] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 3.008323] ACPI: bus type drm_connector registered
[ 3.010232] cryptd: max_cpu_qlen set to 1000
[ 3.043925] AES CTR mode by8 optimization enabled
[ 3.099993] Intel(R) Wireless WiFi driver for Linux
[ 3.101255] iwlwifi 0000:00:14.3: Detected crf-id 0x2816, cnv-id 0x1000100 wfpm id 0x80000000
[ 3.101267] iwlwifi 0000:00:14.3: PCI dev 9df0/0034, rev=0x312, rfid=0x105110
[ 3.101270] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz
[ 3.107499] usb 1-10: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[ 3.107504] usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.115809] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 3.115813] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 3.115815] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 3.115817] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 3.115818] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 3.115819] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 3.115821] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 3.115822] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 3.115823] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 3.115824] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 3.115826] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 3.115827] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 3.115828] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 3.115829] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 3.115831] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 3.115832] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 3.115833] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 3.116133] iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
[ 3.116142] iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
[ 3.116150] iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
[ 3.116153] iwlwifi 0000:00:14.3: loaded firmware version 46.7e3e4b69.0 9000-pu-b0-jf-b0-46.ucode op_mode iwlmvm
[ 3.152517] hid: raw HID events driver (C) Jiri Kosina
[ 3.184454] usbcore: registered new interface driver usbhid
[ 3.184458] usbhid: USB HID core driver
[ 3.204178] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C52B.0001/input/input4
[ 3.352142] Bluetooth: Core ver 2.22
[ 3.395098] NET: Registered PF_BLUETOOTH protocol family
[ 3.395102] Bluetooth: HCI device and connection manager initialized
[ 3.395106] Bluetooth: HCI socket layer initialized
[ 3.395108] Bluetooth: L2CAP socket layer initialized
[ 3.395114] Bluetooth: SCO socket layer initialized
[ 3.443220] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-2/input0
[ 3.443515] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input5
[ 3.443946] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input6
[ 3.471290] iwlwifi 0000:00:14.3: base HW address: c8:e2:65:3e:28:35, OTP minor version: 0x4
[ 3.479834] usbcore: registered new interface driver btusb
[ 3.491497] Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
[ 3.491524] Bluetooth: hci0: Boot Address: 0x40800
[ 3.491525] Bluetooth: hci0: Firmware Version: 201-12.24
[ 3.491527] Bluetooth: hci0: Firmware already loaded
[ 3.493756] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[ 3.504877] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input7
[ 3.504993] hid-generic 0003:046D:C52B.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-2/input1
[ 3.505531] hid-generic 0003:046D:C52B.0003: hiddev1,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-2/input2
[ 3.505650] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:046D:C52F.0004/input/input9
[ 3.505871] hid-generic 0003:046D:C52F.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-4/input0
[ 3.506097] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:046D:C52F.0005/input/input10
[ 3.559220] hid-generic 0003:046D:C52F.0005: input,hiddev2,hidraw4: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-4/input1
[ 3.751165] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 3.751599] scsi 3:0:0:0: Direct-Access SanDisk Cruzer Edge 1.27 PQ: 0 ANSI: 6
[ 3.752088] sd 3:0:0:0: Attached scsi generic sg1 type 0
[ 3.753406] sd 3:0:0:0: [sdb] 15633408 512-byte logical blocks: (8.00 GB/7.45 GiB)
[ 3.755146] sd 3:0:0:0: [sdb] Write Protect is off
[ 3.755151] sd 3:0:0:0: [sdb] Mode Sense: 43 00 00 00
[ 3.755513] sd 3:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 3.761834] warning: `iwconfig' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 3.870065] i915 0000:00:02.0: [drm] Found COFFEELAKE/ULT (device ID 3ea5) display version 9.00 stepping N/A
[ 3.870845] i915 0000:00:02.0: [drm] Found 128MB of eDRAM
[ 3.870866] i915 0000:00:02.0: [drm] VT-d active for gfx access
[ 3.870904] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 3.871997] Console: switching to colour dummy device 80x25
[ 3.872063] i915 0000:00:02.0: [drm] Using Transparent Hugepages
[ 3.872890] sdb: sdb1 sdb2
[ 3.873301] sd 3:0:0:0: [sdb] Attached SCSI removable disk
[ 3.874738] i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 3.874782] i915 0000:00:02.0: firmware: failed to load i915/kbl_dmc_ver1_04.bin (-2)
[ 3.874792] i915 0000:00:02.0: firmware: failed to load i915/kbl_dmc_ver1_04.bin (-2)
[ 3.874801] i915 0000:00:02.0: firmware: failed to load i915/kbl_dmc_ver1_04.bin (-2)
[ 3.874803] i915 0000:00:02.0: Direct firmware load for i915/kbl_dmc_ver1_04.bin failed with error -2
[ 3.874806] i915 0000:00:02.0: [drm] Failed to load DMC firmware i915/kbl_dmc_ver1_04.bin (-ENOENT). Disabling runtime power management.
[ 3.874809] i915 0000:00:02.0: [drm] DMC firmware homepage: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
[ 4.002605] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 1
[ 4.092351] intel_rapl_common: Found RAPL domain package
[ 4.092355] intel_rapl_common: Found RAPL domain core
[ 4.092356] intel_rapl_common: Found RAPL domain uncore
[ 4.092357] intel_rapl_common: Found RAPL domain dram
[ 4.092358] intel_rapl_common: Found RAPL domain psys
[ 4.175518] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-2/input2
[ 4.293064] input: Logitech Wireless Device PID:4024 Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:4024.0006/input/input13
[ 4.335227] logitech-djreceiver 0003:046D:C52F.0004: hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-4/input0
[ 4.407143] input: Logitech Wireless Device PID:4024 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:4024.0006/input/input14
[ 4.443274] hid-generic 0003:046D:4024.0006: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4024] on usb-0000:00:14.0-2/input2:1
[ 4.443347] logitech-djreceiver 0003:046D:C52F.0005: hiddev1,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-4/input1
[ 4.504735] logitech-djreceiver 0003:046D:C52F.0005: device of type eQUAD step 4 DJ (0x04) connected on slot 1
[ 4.512190] input: Logitech Wireless Mouse PID:1024 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:046D:C52F.0005/0003:046D:1024.0007/input/input18
[ 4.512581] input: Logitech Wireless Mouse PID:1024 Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:046D:C52F.0005/0003:046D:1024.0007/input/input19
[ 4.512661] hid-generic 0003:046D:1024.0007: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:1024] on usb-0000:00:14.0-4/input1:1
[ 4.688830] i915 0000:00:02.0: [drm] [ENCODER:98:DDI A/PHY A] failed to retrieve link info, disabling eDP
[ 4.694584] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
[ 4.725060] input: Logitech K400 as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:4024.0006/input/input23
[ 4.735489] [drm] Initialized i915 1.6.0 for 0000:00:02.0 on minor 0
[ 4.739672] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 4.740415] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input24
[ 4.811830] logitech-hidpp-device 0003:046D:4024.0006: input,hidraw2: USB HID v1.11 Keyboard [Logitech K400] on usb-0000:00:14.0-2/input2:1
[ 4.883270] input: Logitech M310 as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:046D:C52F.0005/0003:046D:1024.0007/input/input25
[ 4.883665] logitech-hidpp-device 0003:046D:1024.0007: input,hidraw4: USB HID v1.11 Mouse [Logitech M310] on usb-0000:00:14.0-4/input1:1
[ 5.017779] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 5.025080] fbcon: i915drmfb (fb0) is primary device
[ 5.052310] Console: switching to colour frame buffer device 240x67
[ 5.078536] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 5.129964] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC233: line_outs=1 (0x21/0x0/0x0/0x0/0x0) type:hp
[ 5.129975] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 5.129980] snd_hda_codec_realtek hdaudioC0D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 5.129984] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 5.129987] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 5.129990] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 5.129995] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ 5.189708] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[ 5.193462] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[ 5.193635] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[ 5.193796] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input29
[ 5.193983] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
[ 5.194134] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
[ 5.479123] Adding 1972220k swap on /dev/sda6. Priority:-2 extents:1 across:1972220k SS
[ 5.530857] EXT4-fs (sda1): re-mounted b9ed5f46-3447-4b23-a84a-c208188228c3 r/w.
[ 5.703057] lp: driver loaded but no devices found
[ 5.712189] ppdev: user-space parallel port driver
[ 5.719316] EXT4-fs (sda5): mounted filesystem 52b78fc8-2b5b-46b2-87b1-3e6c9ce1e0b9 r/w with ordered data mode. Quota mode: none.
[ 5.797807] audit: type=1400 audit(1789343189.907:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=1281 comm="apparmor_parser"
[ 5.797828] audit: type=1400 audit(1789343189.907:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=1283 comm="apparmor_parser"
[ 5.798095] audit: type=1400 audit(1789343189.907:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=1280 comm="apparmor_parser"
[ 5.798151] audit: type=1400 audit(1789343189.907:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=1282 comm="apparmor_parser"
[ 5.800178] audit: type=1400 audit(1789343189.911:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=1292 comm="apparmor_parser"
[ 5.800942] audit: type=1400 audit(1789343189.911:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=1291 comm="apparmor_parser"
[ 5.801393] audit: type=1400 audit(1789343189.911:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=1293 comm="apparmor_parser"
[ 5.802883] audit: type=1400 audit(1789343189.911:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=1296 comm="apparmor_parser"
[ 5.803430] audit: type=1400 audit(1789343189.915:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-checkns" pid=1298 comm="apparmor_parser"
[ 5.805886] audit: type=1400 audit(1789343189.915:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=1297 comm="apparmor_parser"
[ 6.522607] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.522612] Bluetooth: BNEP filters: protocol multicast
[ 6.522616] Bluetooth: BNEP socket layer initialized
[ 6.525668] Bluetooth: MGMT ver 1.23
[ 6.535689] NET: Registered PF_ALG protocol family
[ 6.592303] Bluetooth: RFCOMM TTY layer initialized
[ 6.592310] Bluetooth: RFCOMM socket layer initialized
[ 6.592314] Bluetooth: RFCOMM ver 1.11
[ 7.310023] NET: Registered PF_QIPCRTR protocol family
[ 24.712854] logitech-hidpp-device 0003:046D:4024.0006: HID++ 2.0 device connected.
[ 44.571369] kauditd_printk_skb: 221 callbacks suppressed
[ 44.571372] audit: type=1400 audit(1789343228.684:233): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=1994 comm="Xorg" requested_mask="wrc" denied_mask="wrc" fsuid=0 ouid=0
[ 44.571377] audit: type=1400 audit(1789343228.684:234): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=1994 comm="Xorg" requested_mask="wrc" denied_mask="wrc" fsuid=0 ouid=0
[ 44.571379] audit: type=1400 audit(1789343228.684:235): apparmor="ALLOWED" operation="file_lock" class="file" profile="Xorg" name="/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=1994 comm="Xorg" requested_mask="wk" denied_mask="wk" fsuid=0 ouid=0
[ 44.571391] audit: type=1400 audit(1789343228.684:236): apparmor="ALLOWED" operation="file_lock" class="file" profile="Xorg" name="/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=1994 comm="Xorg" requested_mask="wk" denied_mask="wk" fsuid=0 ouid=0
[ 44.571590] audit: type=1400 audit(1789343228.684:237): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=1994 comm="Xorg" requested_mask="wrc" denied_mask="wrc" fsuid=0 ouid=0
[ 44.571597] audit: type=1400 audit(1789343228.684:238): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=1994 comm="Xorg" requested_mask="wrc" denied_mask="wrc" fsuid=0 ouid=0
[ 44.571603] audit: type=1400 audit(1789343228.684:239): apparmor="ALLOWED" operation="file_lock" class="file" profile="Xorg" name="/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=1994 comm="Xorg" requested_mask="wk" denied_mask="wk" fsuid=0 ouid=0
[ 44.571607] audit: type=1400 audit(1789343228.684:240): apparmor="ALLOWED" operation="file_lock" class="file" profile="Xorg" name="/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=1994 comm="Xorg" requested_mask="wk" denied_mask="wk" fsuid=0 ouid=0
[ 44.572245] audit: type=1400 audit(1789343228.684:241): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/.cache/mesa_shader_cache_db/part0/mesa_cache.idx" pid=1994 comm="Xorg" requested_mask="wrc" denied_mask="wrc" fsuid=0 ouid=0
[ 44.572252] audit: type=1400 audit(1789343228.684:242): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/.cache/mesa_shader_cache_db/part0/mesa_cache.db" pid=1994 comm="Xorg" requested_mask="wrc" denied_mask="wrc" fsuid=0 ouid=0Last edited by erdos (2026-09-14 00:55:31)
My apologies. I meant Ctrl+Alt+F2, but that might actually point to your GUI session, so try Ctrl+Alt+F1 also. One of those should, under normal circumstances, switch you to a text-mode terminal where you can do additional debugging. If nothing happens after a few seconds of either key combo, then your system has actually stopped responding to input.
I've spent a big portion of last weekend to troubleshoot the issue and here's what I did to resolve the repeated desktop crash.
Examine multiple log files to look for error -
# Check the end of the system log for kernel panic or oops traces before the crash
sudo grep -iE 'error|panic|oops|warn' /var/log/syslog | tail -n 50
# Check kernel ring buffer messages
dmesg -T -l emerg,alert,crit,err
# Check X11/Display server logs if the crash occurs inside a graphical environment
cat /var/log/Xorg.0.log | grep -E 'EE|WW'
and spot the following lines in the logfile
2026-09-19T16:12:00.676256-04:00 htpc-devuan kernel: RAS: Correctable Errors collector initialized.
2026-09-19T16:12:00.676935-04:00 htpc-devuan kernel: i915 0000:00:02.0: Direct firmware load for i915/kbl_dmc_ver1_04.bin failed with error -2
udevd[479]: GOTO 'alsa_restore_std' has no matching label in: '/usr/lib/udev/rules.d/90-alsa-restore.rules'
2026-09-20T01:22:11.308674-04:00 htpc-devuan pulseaudio[2552]: [pulseaudio] x11wrap.c: X11 I/O error handler called
2026-09-20T01:22:11.308686-04:00 htpc-devuan pulseaudio[2552]: [pulseaudio] x11wrap.c: X11 I/O error exit handler called, preparing to tear down X11 modules
2026-09-20T01:22:11.310952-04:00 htpc-devuan pulseaudio[2552]: [pulseaudio] x11wrap.c: X11 I/O error handler called
2026-09-20T01:22:11.310963-04:00 htpc-devuan pulseaudio[2552]: [pulseaudio] x11wrap.c: X11 I/O error exit handler called, preparing to tear down X11 modules
2026-09-20T01:22:11.744708-04:00 htpc-devuan pulseaudio[2552]: [pulseaudio] module-x11-xsmp.c: ICE I/O error handler called
2026-09-20T01:22:12.414471-04:00 htpc-devuan pulseaudio[2552]: [pulseaudio] x11wrap.c: X11 I/O error handler called
2026-09-20T01:22:12.414488-04:00 htpc-devuan pulseaudio[2552]: [pulseaudio] x11wrap.c: X11 I/O error exit handler called, preparing to tear down X11 modulesafter looking up the errors online, i had to reinstall the i915 driver and regenerated initamfs
$ sudo apt install -y firmware-linux firmware-linux-nonfree firmware-misc-nonfree
$ sudo update-initramfs -u -k all
then appended '/etc/default/grub' to limit GPU power saving that might cause crash,
GRUB_CMDLINE_LINUX_DEFAULT="quiet intel_idle.max_cstate=1 processor.max_cstate=1 i915.enable_rc6=0 i915.enable_dc=0"
append '/usr/lib/udev/rules.d/90-alsa-restore.rules'
LABEL="alsa_restore_std"
but excalibur still crashes,
updated excalibur system, updated computer bios, still no go.
finally, I purged 'pulseaudio' and replaced with 'pipewire', YES, that seems solved the problem, been running computer for 24 hrs without any crash ![]()
somehow, upgrading to excalibur from Daedalus seems breaking multiple settings on my computer -
i915 graphics driver (moved from /lib/firmware/i915/ to /usr/lib/firmware/i915/kbl_dmc_ver1_04.bin)
alsa (missing label in '/usr/lib/udev/rules.d/90-alsa-restore.rules')
pulseaudio (broken)
Maybe there's a problem with the edit you made to 90-alsa-restore.rules. I think "append" is not the right thing to do. There's a one-line replacement needed. It should look like the following.
Note: If you don't want it to be overwritten on update, put it in /etc/udev/rules.d instead of /usr/lib/udev/rules.d.
# do not edit this file, it will be overwritten on update
ACTION=="add", SUBSYSTEM=="sound", KERNEL=="controlC*", KERNELS!="card*", TEST=="/usr/sbin", TEST=="/usr/share/alsa", GOTO="alsa_restore_go"
GOTO="alsa_restore_end"
LABEL="alsa_restore_go"
ENV{ALSA_CARD_NUMBER}="$attr{device/number}"
# mark HDA analog card; HDMI/DP card does not have capture devices
DRIVERS=="snd_hda_intel", TEST=="device/pcmC$env{ALSA_CARD_NUMBER}D0p", RUN+="/bin/sh -c 'echo ALSA_CARD_HDA_ANALOG=$env{ALSA_CARD_NUMBER} >> /run/udev/alsa-hda-analog-card'"
# check for ACP hardware
TEST=="device/device/acp3x-dmic-capture", GOTO="alsa_hda_analog"
TEST=="device/device/acp6x-dmic-capture", GOTO="alsa_hda_analog"
TEST=="device/device/acp63-dmic-capture", GOTO="alsa_hda_analog"
TEST=="device/device/acp-dmic-codec", GOTO="alsa_hda_analog"
GOTO="alsa_restore_std"
LABEL="alsa_hda_analog"
# restore configuration for profile with combined cards (HDA + digital mic)
TEST!="/run/udev/alsa-hda-analog-card", GOTO="alsa_restore_std"
IMPORT{program}="/usr/bin/cat /run/udev/alsa-hda-analog-card"
ENV{ALSA_CARD_HDA_ANALOG}!="", ENV{ALSA_CARD_NUMBER}="$env{ALSA_CARD_HDA_ANALOG}"
TEST!="/etc/alsa/state-daemon.conf", TEST=="/usr/sbin/alsactl", RUN+="/usr/sbin/alsactl -E HOME=/run/alsa -E XDG_RUNTIME_DIR=/run/alsa/runtime restore $env{ALSA_CARD_NUMBER}"
TEST=="/etc/alsa/state-daemon.conf", TEST=="/usr/sbin/alsactl", RUN+="/usr/sbin/alsactl -E HOME=/run/alsa -E XDG_RUNTIME_DIR=/run/alsa/runtime nrestore $env{ALSA_CARD_NUMBER}"
LABEL="alsa_restore_end"Offline
Pages: 1
