#1 2026-09-02 18:31:57
kapqa
/usr/lib/x86_64-linux-gnu/libgtk3-nocsd.so.0' cannot be preloaded
hello ,
on this laptop using devuan freia or maybe unstable
with kde plasma x11.
normally receive fairly daily upgrades , however tody chose to upgrade via "discover" which alwasys remind up impending update/upgrades but then does not finish seem to finish them mostly due to errors. there were lots of packages propeosed , maybe 600+.
since then have now this error here like
source ~/.bashrc
ERROR: ld.so: object '/usr/lib/x86_64-linux-gnu/libgtk3-nocsd.so.0' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
locate libgtk3-nocsd.so.0
/usr/lib/i386-linux-gnu/libgtk3-nocsd.so.0
but when i look inside this folder "/usr/lib/x86_64-linux-gnu" it seems the file object
is not present?
sorry if i made anerror.
