#1 2026-08-24 12:11:37
MageSlayer
xrdp. Update request
Hi
I am currently on Excalibur.
It shows:
# apt policy xrdp
xrdp:
  Installed: 0.10.1-3.1+deb13u1
  Candidate: 0.10.1-3.1+deb13u1
  Version table:
 *** 0.10.1-3.1+deb13u1 500
        500 http://deb.devuan.org/merged excalibur/main amd64 Packages
        500 http://deb.devuan.org/merged excalibur-security/main amd64 Packages
Latest version at Github is 0.10.6.1 which contains security fixes and also has a fix for the annoying issue mentioned here - https://dev1galaxy.org/viewtopic.php?pid=59918#p59918 and https://github.com/neutrinolabs/xrdp/di … t-13407673
Please upgrade
BR
#2 2026-08-24 12:53:05
Re: xrdp. Update request
I fear you are in the wrong place here, this is a native Debian package. Can be seen on this +deb13u1.
You should ask the Debian maintainers to update this package.
#3 2026-08-24 13:06:39
MageSlayer
Ok. I got it.
I see Debian has the upgrade in its testing (Forky), but has not been patched to Trixie.
#4 2026-08-24 13:32:37
With a bit of luck the patched upgrade will go into Trixie-Backports.
