I want to try out Devuan, as a systemd free linux.
Before I do that, I would like to ask a few questions:
1. does ZFSbootmenu work well with Devuan?
(I ask because I am FreeBSD user, but FreeBSD isn't completely optimal for desktop/laptop. But I want to keep ZFS and boot environments as much as possible.)
2. what is the current state of Nvidia/Nouveau/amdgpu drivers?
(There have been serious issues with Nvidia drivers [e.g. freezes etc] and Nouveau [stability] recently, so I have been using AMD R5 430 as framebuffer recently. But the amdgpu driver has its own issues, incomplete repaint etc, so I wonder whether maybe Nvidia or Nouveau drivers have improved recently, so I can put to use my GT 730 cards again?)
3. does hibernate (suspend to disk) work well/reliably with Devuan? (and with ZFSbootmenu?)
Thank you very much ![]()
Welcome to Devuan.
To your questions:
1.) I don't use ZFS, no idea how this is supported. I am on ext4, grub and luks encryption. Works for me.
2.) The current state of Nvidia/Nouveau/amdgpu drivers is exactly the same as for Debian. Devuan is a Debian - systemd + support for sysvinit and various other init systems. https://dev1galaxy.org/viewtopic.php?id=3192
I guess this old GT730 is loosing support by NVidia, and older driver packages do no more build with current kernels.
3.) I use hibernation, it works fine on my grub system, Excalibur, encrypted, LightDM/Cinnamon DE.
for the graphics driver nvidia,
think there is way to get it function on debian13/cdevuan6 for your card mentioned, atleast had so once if not mistaken, but it is a bit difficult , involves some workaround; think you could find info on net; at the moment i am using the gt 710 on another computer just with open-source driven, it function ok.
here is info on how to https://www.reddit.com/r/debian/comment … rivers_on/
for amdgpu it is not officiially supported on debian (yet) but for some newer cards there is rocm support (debian), so it could function also on devuan. for older card, you will find better route just using the card as it is (like r5 430), if you strictly need opencl or such, you might find ways to enable it (there is also onoging effort for newer thing like rusticl or something, but there are other people here more knowledgeable on such matters that might advise you.
if you use a high-end monitor or 4k, then the gt 730 might be lacking with nouveau, but i just office 16:10 1680x1050, and it function well enough; but the driver part can be installed, if you strictly need to (as discussed in relevant forumposts, with instructions).
https://forums.developer.nvidia.com/t/i … -13/352727
i can't answer that, but i have been using ZFS for non-root storage without issue
for years. i have ZFS pools on spinning rust, SATA SSD and NVME SSD and
they're working well. the NVME set-up is an experiment, but it is working. i have
4x1TB NVME in RAID-0 (live fast, die young!) for storing QEMU qcow2 images
and it has not fallen over yet.
yeah, i am a fan of ZFS
due to licensing conflict, CDDL v. GPL, ZFS has to be bolted-on after the fact.
this is done via kernel modules that are built using linux kernel dkms system.
i prefer to use backports for ZFS to better stay up-to-date. so, for me, this is
what i did:
sudo apt install dkms
sudo apt install -t daedalus-backports zfs-dkms
sudo apt install -t daedalus-backports zfsutils-linux
sudo apt install -t daedalus-backports zfs-zedthe only ZFS-on-root how-to i could find on here is an old one (2020)
https://dev1galaxy.org/viewtopic.php?id=3794
there is another thread (2022) talking about using ZFS (somewhat). not
sure if it will be helpful to you, but just in case
https://dev1galaxy.org/viewtopic.php?id=5285
once installed, ZFS puts a bunch of scripts in /etc/init.d:
zfs-import
zfs-load-key
zfs-mount
zfs-share
zfs-zed
the ZFS configuration file is /etc/modprobe.d/zfs.conf
and the trim+scrub cron jobs are in file /etc/cron/d/zfsutils-linux
hope this helps
Don't think that is a stupid question.
But yeah, nvidia drivers have issues sometimes. older ones work as well on open firmware as nvidias proprietary stuff I hear, but ZFS?
Never used it.
If you wish to be humbled, try to exalt yourself long term If you wish to be exalted, try to humble yourself long term
Thank you all for your input!
@rolfie and @kapqa:
I need only 2D framebuffer stuff (most challenging is youtube 4k). I now am thinking whether I should use that old GT730 or that K2000 lying around, just to evaluate how Nouveau has improved meantime. No need for a 300 watt turbofan engine ![]()
@grunchy:
great to see that other Devuan users also are big ZFS fans ![]()
Actually I used ZFS on root on Debian for years, until a RAM ECC error halted the system very roughly and destroyed the data pool (the last snapshot was still readable, though). After that I switched back to FreeBSD. But, as said, FreeBSD is less than ideal for desktop usage, no hibernate support and other things.
@zapper:
I guess I just should try again Nvidia/Nouveau after that long time...
But what worries me a bit right now is that I need to help debug some KDE packages and have to build/install them manually using custom options. I read that is extremely difficult on Debian/Devuan in comparison to FreeBSD or, say, Void Linux. Iiuc in the former, one has to modify the build scripts themselves, while in the latter one can concentrate on the options setting, without fear of trashing the whole system. But maybe that is just dramatized? *scratching head* Whatever, this makes me ask what is more advisable, devuan or void... please excuse me, I am still trying to understand before I start the project...
Thank you all again ![]()
Older graphic cards have their limitations.
"4k@30Hz" isn't fun.
"4k@60Hz" is supported since "hdmi-2.0" respectively "dvi-1.2".
The "GT730" is (likely) out here.
@clueless, if you using ZFS, might readily be more advanced in the computing then me here;
however, the GT 730 according to Techpowerup conly hdmii 1.3a, so you might not fare well with 4k;
even the GT 710 has hdmi 1.4; and might be luckier for higher resolution, but that might also be wrong info on the side of techpowerup (/which happens sometimes)
have checked again, and found that the devuan box mentioned has the proper driver installed; but don't asked how it is done; it is elaborated probably only thanks to this post from user in southern france, that shared the respective kernel patch or something.
happy landing on devuan.
@delgado I never understood the push to go beyond 360p.
For me that is sufficient for my videos.
Anything beyond? Idk....
I'm using Devuan with a Nvidia GTX 1050 card and the proprietary Nvidia drivers (the 550 version from the Devuan/Debian repos) without any problems, the system is absolutely stable and everything works fine (OpenGL, Vdpau, NVDEC and Vulkan).
The only thing I couldn't get working is VAAPI hw video decoding in Firefox, if I enable that Firefox crashes the moment I start a video in the browser (for example on youtube), but with VAAPI hw video decoding disabled videos in Firefox obviously play fine so it's not a big issue.
That said the GT 730 that you are trying to use is apparently no longer supported by the 535 and 550 propietary drivers in Devuan 6 (Excalibur), the most recent Nvidia drivers that still support the GT 730 are the 470 series.
There is a guide on github on how to install the 470 series drivers (and the older 340 and 390 series) on Debian 13 (the Devuan 6 equivalent) so if you are adventurous you should be able to get it working:
https://gist.github.com/Anakiev2/8d62e2 … ff855a22a7
“Either the users control the program – or the program controls the users” Richard Stallman
Can confirm installing Excalibur with ZFS is not particularly difficult if you're familiar with a manual installation (i.e. debootstrap)!
It basically comes to:
Do a full (= non-live, or maybe live+persistence) install to another disk
Boot from it and install headers + zfs-dkms + zfs-utils + debootstrap (might as well get other utilities like arch-install-scripts, gdisk, nvme-cli, and various other filesystems on it)
Create pool and datasets with appropriate options; personally I went for 4 datasets - root, home, media+documents, and /var/cache/apt/archives — this is not particularly distro-specific, refer to ZfsBootMenu's tutorials for Void and Debian,
Unmount, temporary-remount, install base system with debootstrap, chroot in (arch-chroot from the above package or Void's xchroot are convenient for automatically passing /dev /sys and /proc), configure sources.list/hostname/timezone/keyboard/locales (the last 3 points are "best" done in the Debian system with dpkg-reconfigure), install network access software/aptitude/sudo/whatever-you-like and configure users + superuser access — as you can see, although this general point is somewhat laborious, it's not ZFS specific (and is somewhat explained in the above guides)
Install kernel + headers + zfs-dkms + zfs-utils — hey, you pretty much did it before ![]()
Download and setup ZfsBootMenu — yup, still explained by ZfsBootMenu people
Check that it works, install desired applications, spend 30 minutes on customizations like sudo insults & saving password for 2 hours and decrapifying Firefox, enjoy — not ZFS specific either
No luck (haven't tried the above manual backport method) with a (2020 GDDR5 reissue) 710, and Nouveau likes freezing, not that I expected better from the green company on my blacklist since the 2007 BGA reliability scandals with about as much support of libre as Br*adcom...!
