#1 2026-06-19 11:50:02
kapqa
[SOLVED] Spectacle app not opening
Hello ,
am wanting to make a screenshot with Devuan 6.0 KDE , but the app is not responding properly;
the error is
launching spectacle failed
Process org.kde.spectacle exited with error 127
from terminal
spectacle
spectacle: error while loading shared libraries: libfdk-aac.so.2: cannot open shared object file: No such file or directory
libfdk-aac-dev is already the newest version (1:2.0.3-dmo1+b1).
Summary:
thank you very much.
#2 2026-06-19 11:52:23
kapqa
Re: [SOLVED] Spectacle app not opening
it could be solved by installing
libfdk-aac2t64
problem solved, thanks.
