#1 2026-06-14 11:44:41
amaro
[SOLVED] missing firmware /lib/firmware/i915/
Hello everybody,
I am doing the upgrade from Daedalus to Excalibur. Followed the step here https://www.devuan.org/os/documentation … -excalibur
In the process got this message
update-initramfs: Generating /boot/initrd.img-6.12.57+deb12-amd64
W: Possible missing firmware /lib/firmware/i915/mtl_gsc_1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_huc_7.9.3.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg1_huc.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_huc.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg2_huc_gsc.bin for module i915
W: Possible missing firmware /lib/firmware/i915/mtl_huc_gsc.bin for module i915
W: Possible missing firmware /lib/firmware/i915/skl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/bxt_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/kbl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/glk_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/cml_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/icl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/ehl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg1_guc_70.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_guc_69.0.3.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_guc_70.bin for module i915
W: Possible missing firmware /lib/firmware/i915/adlp_guc_69.0.3.bin for module i915
W: Possible missing firmware /lib/firmware/i915/adlp_guc_70.1.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/adlp_guc_70.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg2_guc_70.bin for module i915
W: Possible missing firmware /lib/firmware/i915/mtl_guc_70.bin for module i915
Is this an issue?
If so, how to fix it?
Thank you in advance!
#2 2026-06-14 12:43:27
Re: [SOLVED] missing firmware /lib/firmware/i915/
If you actually have i915 graphics, you might want to install a couple of packages. Run 'lspci' to check. In my experience, it will still work without that. I'm not sure if you miss anything that way - I don't do anything that requires intense graphics. Just simple games and video here.
$ apt-cache search i915
xserver-xorg-video-intel - X.Org X server -- Intel i8xx, i9xx display driver
firmware-intel-graphics - Binary firmware for Intel iGPUs and IPUs
#3 2026-06-14 13:18:13
amaro wrote:
Is this an issue?
Not necessarily, more so if your graphics are working properly.
I had the same issue with my Nvidia Quadro FX 580s and Nouveau drivers.
See here: https://dev1galaxy.org/viewtopic.php?pid=51169#p51169
#4 2026-06-14 19:44:20
So for daedalus the i915 stuff is in firmware-misc-nonfree, but for excalibur they split it off into it's own package that fsmithred mentioned above firmware-intel-graphics.
Looks like most likely you had the daedalus version and were using it possibly, but after the upgrade the intel i915 firmware is no longer in the package so it's no longer on your system.
There's also a firmware-intel-misc package that's new in excalibur, not sure what's in that as I don't have an excalibur system on my machine right now.
#5 2026-06-17 17:07:03
amaro
Due to several issues with Excalibur I switched to Freia. Everything works.
Thank you , guys!
p.s. For the record
# apt-cache search firmware-intel-graphics firmware-intel-misc
# apt-cache search i915
#6 2026-06-17 17:35:15
If you want the missing packages, you need to add non-free-firmware to sources.list and then 'apt update'. You probably don't need firmware-intel-misc, but the -graphics package has firmware for i915. I don't know if it will make it work better.
deb http://deb.devuan.org/merged freia main non-free-firmware
