#1 2026-05-20 03:01:23
Legion
[SOLVED] Home Server access issues
I set up Devuan 6 with Cinnamon 6.4. Everything works great except access to my home server. I set up access in exactly the same way as I did with Deb 13 and edited FSTAB to automount two folders on the server on start. I am have a couple of issues.
1. Folders on server do not automount on start, they appear on NEMO, because I bookmarked them, but they're not mounted.
2. Preview in NEMO was set up as usual, but nothing except images is previewed. Previously video files and pdf files etal, were previewed.
3. LibreOffice files will not load directly from the server, I have to copy to desktop. then they can be opened.
Also the whole server set up was wrong. Under Deb13, having created a target directory for mount point, then made the changes to FSTAB, on start the folders, correctly named would appear in NEMO. Under Devuan, even doing exactly the same as on DEB13 the folders didn't appear. Instead I had to set up my log in to the server, then 'bookmark' the folders.
The FSTAB entries seem to be ignored on start as the folders appearance is down to the bookmarks.
I am guessing some sort of permissions issue but having fiddled with this for weeks have been unable to resolved.
#2 2026-05-23 14:52:33
rbit
Re: [SOLVED] Home Server access issues
It would probably be helpful to see the actual lines you added to /etc/fstab.
#3 2026-05-23 15:44:41
Betcha a cookie this is yet another case of the conspicuously still not backported to stable network-manager packaging SNAFU.
#4 2026-05-23 16:19:57
Andre4freedom
That's correct, I tested the latest excalibur installer iso (6.1.1) and Networkmanager is still not patched. Your proposed workaround is still valid and fine.
https://dev1galaxy.org/viewtopic.php?pid=63973#p63973 Entry #6
#5 2026-05-24 14:53:01
Andre4freedom
Good news:
Devuan Freia just test-installed (Freia-Cinnamon-OpenRC) and checked: it's fixed.
The missing file in question is here, out-of-the box. Bravo Devuan, packagers, maintainers and contributors!
Installed iso: devuan_freia_7.0-202605091913_amd64_netinstall.iso
dpkg -l | grep -i network-manager
ii  network-manager                         1.56.1-1devuan1                    amd64        network management framework (daemon and userspace tools)
ii  network-manager-l10n                    1.56.1-1devuan1                    all          network management framework (translation files)
ii  network-manager-tui                     1.56.1-1devuan1                    amd64        NetworkManager curses-based UI
NFS mounts in /etc/fstab: works!!
For Devuan Excalibur, steve-v's workaround will solve the problem.
I will add my next donation, I would do so anyway.
#6 2026-06-04 03:27:51
Legion
I fixed the issue by adding x-gvfs to my fstab, The network folders now show up under network, mounted and ready to go. Full fstab, x 2, one for each folder, is 192.168.178.29:/volume1/Base /media/NAS/Base nfs user,nofail,x-gvfs-show,rsize=8192,wsize=8192,timeo=14,intr
