#1 2026-05-05 20:03:10
Robin
My Blog Post About Devuan
Here is a blog post I wrote about Devuan and some of the "lessons learned" from my experience so far.
Be kind though, I'm a newbie.
-Robin
#2 2026-05-05 21:26:46
abower
Re: My Blog Post About Devuan
Thoughtful reflections; thank you for sharing!
#3 2026-05-06 07:55:03
PedroReina
Robin wrote:
I'm a newbie.
You're not! smile But good try. Welcome to the forum, mate.
#4 2026-05-06 12:03:01
Ditto what Pedro said. smile
Nice blog post. Thanks!  I read your other one about Devuan and in it you state that the Refracta uses xlibre. In fact, Refracta uses xorg in the official releases, but you must have picked my test build with xlibre that's in the experimental directory.
That iso was made to test support for seatd in xlibre. There's no elogind in that build, but it'll get pulled in if you install the right things. If you're missing some functions even with elogind, make sure you also have libpam-elogind.
Oh, one more thing about that iso - it's devuan freia, which is still in the testing phase. Don't be surprised if you get 100 package upgrades per day along with occasional breakage. That's one way to learn.
Have fun, and Happy Hacking!
#5 2026-05-06 13:21:15
Robin
Freia, huh? That would be interesting! But in fact, there have been no updates since I installed it about 4 days ago. Perhaps I was wrong about the Xlibre reference in my blog post.
Okay, just checked Fastfetch: It's Excalibur, after all. I should edit my blog post next.
But since it hasn't updated, I suppose I should ask: How often should I expect updates in Excalibur?
Thanks very much!
#6 2026-05-06 17:59:59
RedGreen925
With all Debian based stable releases few and far between mostly only security updates like the kernel that got updated a few days and now it is showing me libc6 and its related package are to be done. Some of these will only be shown if you have enabled the proposed-updates.
Edit:
root@9600k:~# cat /etc/apt/sources.list.d/devuan.sources
## Devuan 6 excalibur
## The new style method of using repositories to install software.
## This /etc/apt/sources.list.d/devuan.sources is new style and location file
## The /etc/apt/old.style.sources.list contains the same as this.
## https://linuxconfig.org/ubuntus-repository-configuration-ubuntu-sources-have-moved-to-etc-apt-sources-list-d-ubuntu-sources
## Normal excalibur sources
Types: deb
URIs: http://gnlug.org/pub/devuan/merged
Suites: excalibur excalibur-backports excalibur-proposed-updates  excalibur-updates
Components: main non-free contrib non-free-firmware
Enabled: yes
Signed-By: /usr/share/keyrings/devuan-archive-keyring.gpg
Architectures: amd64
## excalibur security sources
Types: deb
Suites: excalibur-security
Enabled: yes
Using that for your .sources file will get everything, if you want source packages to install from add deb-src to the Types line.
#7 2026-05-06 19:42:08
Robin
I'm content to leave things as they are as long as there's no harm in doing so; whatever the defaults are that it "shipped" with.
Thanks!
#8 2026-05-06 20:30:45
Very nice! Welcome to Devuan and the forum!
