#1 2026-03-12 06:07:56
Devuan on PC replacing the smartness in smart TV
I've run a Linux PC on my TV's since 20 years and during this time Smart TV's have made their entrance . Since 7 years it's been only Devuan, of course. The UI on Smart TV's leave A LOT to be desired, I think. It's slow and cumbersome and eventually the TV can't be upgraded anymore.
My most recent example is a Samsung TV with relatively new software which very often lost contact with the net. You had to restart the TV all the time. And on top of that, the cumbersome UI.
A real Linux PC has many advantages; Easier configuration of the network (DNS in this case), easier to watch like Youtube without ads,  if so inclined you can watch several shows, clips, videos at once. (Freedom). And play a game at the same time, and check your mail, and google stuff. And read the Devuan forum too.
With wireless keyboard and mouse, you can lay back in your couch and enjoy life.
And in this backwards world of ours, a TV without the "Smartness" would be more expensive than a TV with Smartness.
The one drawback, is that your mind might become even more fragmented. smile smile
#2 2026-05-11 19:58:31
JCK
Re: Devuan on PC replacing the smartness in smart TV
If your samsung tv isn't too new you can access the service menu and enable 'Default HDMI1 booting' so you don't see the tv's interface every time you start it. smile
I got used to mine quite a while ago.
#3 2026-05-11 22:34:37
soulstenance
Yeah "smart" TVs are becoming more mainstream, sadly. The little known reason why they're cheaper is because you're not really buying the TV as a customer, but rather you're signing up for an ad distribution and data collection service. That's where they're really making money. The best solution I can think of is to try to buy a larger computer monitor that at least comes close to the desired size of your TV. These, at least for now still tend to be relatively "dumb". Probably more costly, but if you can afford it, it's likely worth it to not be spied on and tracked.
Back when I had a smart TV, I set it up, then booted it off the internet and used my Steamdeck as a sort of TV box. It was great - not only could I play games, but things like Netflx just worked without needing to load a slow, proprietary TV app that often crashed.
#4 2026-05-12 07:29:05
kapqa
using a odroid n2+ with core-elec  on a non-smart tv ≤≥ liking it very much, functional for youtube, netflix, prime etc
but sometimes things break Z the soundbar howeveis bit-smart with bluetooth that seem always active when powered on, which is a nuisance, but the sound is good and subwoofer wired. wished could make use of less of less wires, get rid of LED TV (strainging the eyes) but for the moment, thats the setup.
#5 2026-05-12 10:49:42
JCK
@kapqa That is quite neat too, does kodi work with the remote with the CEC thing?
Btw i start to understand why people hang on to 20 year old plasmas and cfl lcd's, not because they were expensive at the time but bc's they are indestructible + the picture "feels" more pleasant even if poorly calibrated, my mom has a 15 year old early gen led backlit tv and none of the problems of modern ones, i just replaced caps (well, removed the bulged ones and stuck the new ones wherever it had space on the board :-) ) so good for another 15 years.
My early ish gen samsung 4k also needed the filter cap replaced and i modded it on the backlight circuit with another.
#6 2026-05-12 11:58:52
kapqa
@jck ,yes, most of the times flawlesslly, it depends on the TV being connecte to; out of 3 tv (one LED, one Plama, one CCFL) only the bravia CCFL TFT has problem with CEC (but otherwise a pretty gorgeous picture; somewone throw it away , so got away to testit)
have also a usb keyboard at disposal which has a trackpad which is handy if fire up android 14-15 which sits on eMMC and is nice for browsing the web;
but tend to use coreelec most of the time.
#7 2026-05-12 14:31:22
Andre4freedom
Interesting.
I always had success by connecting a PC (or STB) directly to a "smart"-TV (HDMI or DVI-HDMI) and use that TV as a monitor (display) only. To avoid data harvesting, ad-floods etc just don't connect a network to the TV, and no antenna/cable connection.
I'm not sure about that CEC thing, I had to disable that feature because here my SamsungTV-MarantzAVR interaction didn't work well with CEC.
Your PC can handle all these TV- and Internet-tasks, can't it?
#8 2026-05-13 06:26:47
pcalvert
kapqa wrote:
using a odroid n2+ with core-elec  on a non-smart tv ≤≥ liking it very much, functional for youtube, netflix, prime etc...
Thank you for mentioning CoreELEC. I learned about it a little over a year ago and more or less forgot about it. Now that you reminded me about it, I think I will buy a (relatively) cheap Amlogic-based Android TV box and install CoreELEC on it. Unless, of course, there is some other option that would be even better.
As for TVs, I have an old flat-screen TV that my sister gave me. It's not huge, but it's bigger than any computer monitor that I have ever used. And the reason I know that it's old is because it has a slew of RCA jacks on the back. I've never turned it on, so I don't even know if it works. I hope it does.
Another one is called Luxxle.
#9 2026-05-13 06:54:35
kapqa
have an older android "smartbox" with an rk3328 (or rk3318?) ; have never attempted to install libreelec on it; but shelved some quick time ago, since it made me feel uneasy, with wifi+bluetooth on board; those are difficult to disable; and good luck finding a "cheap box " amlogic without wifi-bluetooth.
had bought as an upgrade the newly odroid c5, (40 dollar) at the time, but now prices went up (around 68 dollar). it is very capable little "box", but not so refined , yet. if you can find a good deal , it is worth considering. (has also support for av1 codec).(if you need importing it, can become bit expensive, but i think if you want a good non-smart-option, it could be a worthy companion).
#10 2026-05-13 10:21:37
pcalvert
Even if Wi-Fi and Bluetooth can't easily be disabled, one could still block them using a firewall. And since Bluetooth could be useful for controlling the TV box, one could configure the firewall to only allow connections from specific MAC addresses.
