#1 2026-03-03 12:28:43
IdeaFix
Question about https://deb.devuan.org/
wtf?
Admin of SledjHamr.org is not very cool in vhosts?
ip address is 152.53.121.155
#2 2026-03-03 18:16:30
Re: Question about https://deb.devuan.org/
Don't use https with deb.devuan.org. It's a round-robin and not all mirrors support https. If you go to http://deb.devuan.org you'll see the same page as https://pkgmaster.devuan.org.
If you feel a need to use https in your sources.list, you'll need to select a specific mirror that supports it.
I got this explanation from someone else:
Normally sources.list uses http:// protocol not https:// protocol and the mirrors *if* they were to use https would require distributing the certificates to all of the mirrors.  Not practical.  And the signed Releases file was designed before https and protects the integrity of the transfers without needing https.
#3 2026-03-04 06:30:21
IdeaFix
Does this mean opening the first vhost on port 443 is normal behavior when opening https://deb.devuan.org?
In my opinion, the mirror is configured incorrectly.
I expect to see deb.devuan.org, a redirect to http://deb.devuan.org, or nothing when opening https://deb.devuan.org, but I see the first website I come across on the same hosting.
In my opinion, this isn't normal.
#4 2026-03-04 11:34:44
RedGreen925
It is normal for apt everything is signed with the official Debian or in this case Devuan gpg keys. This provides the security in knowing you are getting exactly what was uploaded to the mirrors. If the signatures do not match apt errors and will not install from that mirror. If that is not good enough for your security needs then do not use it or pony up the cash and effort to make every single mirror capable of supporting SSL over the http connection(s).
#5 2026-03-30 15:24:52
scott
This is normal for apt, but I didn't always know that.  It's confusing for users who may misjudge the security of the distro.
Here's what I see from Firefox:
Be careful. Something doesn’t look right.
Firefox spotted a potentially serious security issue with deb.devuan.org. Someone pretending to be the site could try to steal things like credit card info, passwords, or emails.
I'm not suggesting a change -- but I am sympathetic to those feeling troubled by this.  File under "https is a pain and it's not the only way to secure things".
[edit: To explain the above quote, DNS round robin came up with ftp.fau.de in this case, which correctly doesn't have a cert for deb.devuan.org.  sledjhamr has a cert.
But have I misunderstood OP's concern?  Was the concern that deb.devuan.org redirected to sledjhamr.org instead of sledjhamr.org/devuan/  ?  In that case, is the concern about equal for redirecting to ftp.fau.de instead of ftp.fau.de/devuan/ ?
Some mirrors are foo.blah.tld/ and some are foo.blah.tld/devuan.  Apt must be handling that automatically.
