#1 2026-01-02 02:02:52
Devuan Excalibur 6.1.0 point-release
DEVUAN EXCALIBUR 6.1.0 POINT-RELEASE
Updated isos for Devuan Excalibur 6.1.0 are now available from your favorite mirror.
WHAT'S NEW
This release contains software current in the repositories (concurrent with Debian 13.2) and includes some important fixes:
- speech-synthesis install is now working correctly again.
- slim login manager bugs fixed:
    https://bugs.devuan.org/cgi/bugreport.cgi?bug=857
    https://bugs.devuan.org/cgi/bugreport.cgi?bug=927
There are now (unofficial) community-produced Excalibur images for Raspberry Pi:
    https://arm-files.devuan.org/RaspberryP … %20Builds/
DOCUMENTATION
Whether you are upgrading an existing Devuan installation, migrating from Debian or installing from scratch, instructions and guidance can be found online:
    https://www.devuan.org/os/install
    https://www.devuan.org/get-devuan
Please take time to read the Release Notes. They include important configuration information and tips to help your installation or upgrade go as smoothly as possible:
    https://files.devuan.org/devuan_excalib … _notes.txt
DOWNLOAD
- http, https, ftp and rsync ISO mirrors:
    https://www.devuan.org/get-devuan#https-mirrors
- torrent file:
    https://files.devuan.org/devuan_excalibur.torrent
- magnet link:
(See updated magnet link in post #5)
ARM AND VIRTUAL IMAGES
ARM and Virtual Machine images are provided by the greater Devuan community rather than as part of official releases. Users are being encouraged to build and contribute ARM images for their particular hardware. This will increase the variety of images available and allow the release schedule of the installer ISOs to move forward more quickly.
Images can be built using using arm-sdk and vm-sdk: https://www.devuan.org/os/distro-kit
Arm-related discussion happens at #devuan-arm (Libera.chat) and https://dev1galaxy.org/viewforum.php?id=24
RESOURCES AND SUPPORT
    Mailing list: https://mailinglists.dyne.org/cgi-bin/m … stinfo/dng
    IRC: #devuan #devuan-dev #devuan-arm (Libera)
    Forum: https://dev1galaxy.org
    Press contact: freedom at devuan dot org
    Source code: https://git.devuan.org
    Bug tracker: https://bugs.devuan.org
    Package information: https://pkginfo.devuan.org
    Popularity contest: https://popcon.devuan.org
AFTER EXCALIBUR
The next Devuan release 7, is codenamed Freia. Repositories are already available for the adventurous to test.
APPRECIATION
We wish to thank all of you for the incredible support given to Devuan. Without your help and feedback, Devuan could not be the reliable and versatile distribution that it is.
To support the Devuan project you can examine our financial reports and donate at:
    https://devuan.org/os/donate
or take up one of the tasks listed at:
    https://dev1galaxy.org/viewtopic.php?pid=1380#p1380
The Devuan Team
#2 2026-01-02 19:58:17
Re: Devuan Excalibur 6.1.0 point-release
Nice! Thanks for all your hardwork, you and the entire Devuan team!
#3 2026-01-02 21:08:44
+1
#4 2026-01-02 22:49:52
Great work, thank you for your efforts.
#5 2026-01-03 00:51:23
Oops! The 6.1.0 desktop-live and minimal-live isos don't boot UEFI.
Fixed in 6.1.1.
This only affects the live isos. The installer isos are unchanged.
New torrent file (same link, different file):
New magnet link:
magnet:?xt=urn:btih:673c0c7f8e46e1902cea1071d5ce602bd307605b&dn=devuan_excalibur&tr=udp%3A%2F%2Ftracker.opentrackr.org%3A1337%2Fannounce&tr=udp%3A%2F%2F9.rarbg.me%3A2710%2Fannounce&tr=udp%3A%2F%2Ftracker.cyberia.is%3A6969%2Fannounce&tr=udp%3A%2F%2Ftracker.port443.xyz%3A6969%2Fannounce&tr=http%3A%2F%2Ftracker3.itzmx.com%3A6961%2Fannounce&tr=udp%3A%2F%2Ftracker.moeking.me%3A6969%2Fannounce&tr=http%3A%2F%2Fvps02.net.orel.ru%3A80%2Fannounce&tr=http%3A%2F%2Ftracker.openzim.org%3A80%2Fannounce&tr=udp%3A%2F%2Ftracker.skynetcloud.tk%3A6969%2Fannounce&tr=https%3A%2F%2F1.tracker.eu.org%3A443%2Fannounce&tr=https%3A%2F%2F3.tracker.eu.org%3A443%2Fannounce&tr=http%3A%2F%2Fre-tracker.uz%3A80%2Fannounce&tr=https%3A%2F%2Ftracker.parrotsec.org%3A443%2Fannounce&tr=udp%3A%2F%2Fexplodie.org%3A6969%2Fannounce&tr=udp%3A%2F%2Ftracker.filemail.com%3A6969%2Fannounce&tr=udp%3A%2F%2Ftracker.nyaa.uk%3A6969%2Fannounce&tr=udp%3A%2F%2Fretracker.netbynet.ru%3A2710%2Fannounce&tr=http%3A%2F%2Ftracker.gbitt.info%3A80%2Fannounce&tr=http%3A%2F%2Ftracker2.dler.org%3A80%2Fannounce
My apologies for any inconvenience,
#6 2026-01-03 10:16:16
Many thanks for all your work team... smile
#7 2026-01-03 11:23:28
I assume the install hang issue was fixed?
That was annoying lol.
#8 2026-01-03 13:17:24
dzz
Firstly, thanks Devuan team for Excalibur. I have already Excalibur installs but still mostly run Daedalus, while I get Excalibur all configured how I want it.
Trying the new ISO in qemu I can't get it to boot from a syslinux USB in my usual way (using the
*.c32 modules from /isolinux). Although qemu does boot the ISO directly.
Undef symbol FAIL: init_fpu
Failed to load libcom32.c32
Failed to load COM32 file vesamenu.c32
On investigation I found the md5sums of /isolinux/*.c32 are different from what is in the (system's) /usr/lib/syslinux/modules/bios ..
They also differ from my own /usr/lib/syslinux/modules/bios/ in both excalibur and daedalus.
If I replace those modules in my USB's /syslinux with the ones from the system, everything works as expected.
I already have verified the sha256sum of the ISO.
Where do /isolinux/*.c32 in the ISO originate from and why are they different?
#9 2026-01-03 13:39:32
rbit
Which devuan ISO file are you using?
#10 2026-01-03 13:46:00
dzz
https://files.devuan.org/devuan_excalib … l-live.iso
sha256:
392032e530b6c03b1e92431401de734fc7746342ae883df486d4a3a4fe403805
devuan_excalibur_6.1.1_amd64_minimal-live.iso
#11 2026-01-03 15:15:59
Oh! They come from the stale versions in the live-sdk build tree. That needs to be re-worked so I don't have to remember to update them.
#12 2026-01-03 16:36:01
dzz
Mystery solved, thanks!
Most of us probably won't notice, except a few who use syslinux on usb and even then, depending on your local syslinux configuration.
EDIT: I'm guessing those modules are incompatible with current ldlinux.sys, which gets updated during syslinux installation to the drive.
#13 2026-01-15 04:47:19
voomto
Hello, and thank you very much for your work.
I have just discovered something strange and worrying about some of the Devuan 6.1 files that I downloaded via the official magnet link.
Regarding the desktop-live/ and minimal-live/ directories, everything is OK, because the command
gpg --verify <NAME>.iso.sha256.asc <NAME>.iso.sha256
returns:
gpg: Signature made Sat Jan  3 01:09:42 2026 CET
gpg:                using RSA key 67F5013216271E85C251E480A73823D3094C5620
gpg: Good signature from "fsmithred (aka fsr) <fsmithred@gmail.com>" [unknown]
gpg: WARNING: This key is not certified with a trusted signature!
gpg:          There is no indication that the signature belongs to the owner.
Primary key fingerprint: 67F5 0132 1627 1E85 C251  E480 A738 23D3 094C 5620
This result is normal and confirms the authenticity of the .sha256 file in relation to Devuan's official public GPG key, which I imported into my keyring from the official file https://files.devuan.org/devuan-devs.gpg, without assigning it a specific trust level.
BUT, in the installer-iso/ directory:
user@devuan:~$ gpg --verify SHA256SUMS.txt.asc SHA256SUMS.txt
gpg: Signature made Thu Dec 25 19:41:10 2025 CET
gpg:                using RSA key 185E56E98DA03B6CEADAC81983161D4768BE620B
gpg:                issuer "dev1@tempforever.com"
gpg: Can't check signature: No public key
→ This RSA fingerprint does not match any key in my GPG keyring, even though I imported the contents of the official file https://files.devuan.org/devuan-devs.gpg!
The gpg --verify result is the same when I download these two files, SHA256SUMS.txt.asc and SHA256SUMS.txt, via HTTP from an official mirror.
I see two possibilities:
  • Or the files in the installer-iso/ directory have been tampered with by an unauthorized person (outside the Devuan team project)
And I notice that:
  • Regarding the address dev1@tempforever.com, DuckDuckGo returns a list of temporary email address providers, and nothing for “tempforever.com.”
  • The tempforever.com website cannot be reached via HTTP because its Apache 2.4.65 server running Debian (IP: 167.88.38.250) located in Boston, USA, is not configured (according to https://sitecheck.sucuri.net/).
The GPG key corresponding to this RSA signature and mysterious email address is available on the hkp://keyserver.ubuntu.com/ server. But since it is not mentioned on the official devuan.org website (https://www.devuan.org/os/keyring), I cannot trust it at all.
I work with Devuan 5 every day and I need to have confidence in the entire Devuan infrastructure in order to continue with Devuan 6.
Am I missing something? Or is this a real problem?
#14 2026-01-15 12:51:16
tempforever's gpg key is listed on this page:
https://www.devuan.org/os/team
And here if you search for tempforever:
https://keyring.devuan.org/
Which will show you that his key has been signed by another devuan dev:
https://keyring.devuan.org/pks/lookup?o … 4768BE620B
He's one of us, for sure. Unfortunately, his key didn't get added to the devuan-keyring package until a couple days ago. It's currently in ceres (version 2026.01.13)
#15 2026-01-15 13:56:42
rbit
I would add to that, it's also in https://files.devuan.org/devuan-devs.gpg from a couple days ago.
#16 2026-01-18 23:10:27
voomto
Thank you for clarifying that.
I had performed several unsuccessful DuckDuckGo searches on site:devuan.org, looking for “tempforever.com” or its long-format RSA key fingerprint, but not for “tempforever” or its short-format key fingerprint.
I just imported tempforever's public RSA key and successfully verified the installer-iso/SHA256SUMS.txt file downloaded via the magnet link.
Everything is OK.
Many thanks to the whole team for their great work on Devuan 6!
