#1 2025-12-17 19:03:37
klein
[SOLVED] ssh enable and link
good day all
i have vuu-do 5.03 installed and need to enable ssh, and make it start at startup.
i can't seem to find what i need.
#2 2025-12-17 19:11:26
kapqa
Re: [SOLVED] ssh enable and link
you could do "sudo tasksel"
and enable ssh?
#3 2025-12-17 19:23:24
klein
wil it still be enabled after a reboot ?
#4 2025-12-17 19:25:24
klein
"sudo tasksel"
is not installed
#5 2025-12-17 19:31:16
apt update
apt list openssh-server
apt install openssh-server
Per default openssh-server listens on port 22. Always (after a reboot).
#6 2025-12-17 19:56:24
klein
thank you rolfie
i thought it was installed by defult .
#7 2025-12-17 20:02:18
No, never was as far as I can remember. It has to be installed I don't know exactly for how many releases now in Debian/Devuan?
