I like to keep things light in desktop world.
You may not. Thats is more than fine. Its not called free software for nothing !
However, sometimes, it feels as though loginkit and dbus is a soggy box, and certainly not a help.
So you can live with and / or without them :
Here is part of one reasonably flexible solution.
Assuming you have:
a/ xutils installed AND
b/ you are allowed to login from the console.
see: /etc/X11/Xwrapper.config
c/ an optionally dbus free window manager
You should be able to simply login and
startx
or
xinit somexsessionhere -- :2
the icewm is a nice example
this _may_ override any commandline options (xinit)
# save to ~/.xinitrc and or ~/.xsession
# ~$ man startx for more information about why and what
# this file was originally from the sources of *slim display manager*
# edit to taste
# usage: (where "foobar" will match your desired window manager)
# ~$ startx foobar
# ~$ xinit foo -- :1
# allocate to your default preference
# here
DEFAULT_SESSION=openbox-session
case $1 in
openb* | ob | foo)
# see also: ~/.config/openbox/autostart
exec openbox-session
twm)
# it is OK to not have xbindkeys
xbindkeys || true &
xterm &
exec twm
# examples
enlightenment)
exec /usr/bin/enlightenment_start
enlightenment?*)
exec /usr/local/bin/enlightenment_start
icewm)
icewmbg &
icewmtray &
exec icewm
wmaker)
exec wmaker
blackbox)
exec blackbox
exec $DEFAULT_SESSION
esac
of course you can simply try:
xinit -- :1
startx
for defaults
Or your window manager may provide an initialisation script
tab may be your friend
Upsides and uses include:
- testing window managers
and gui tools. (multiple logins and quick tests are easy to flip between)
- If you don't need or want a full Desktop Manager with
DBUS and login "friends"
- Its OK with no {pulse,port}audio as well
you can uninstall all or some of the above and _simplify your life_ or not. ;>
- You also wont need a Display Manager (slim or lightdm)
But you can still use them for other users. (or even yourself with a little thought)
and certainly wont need GDM or kdm etal.
Its your system its your code
break it your way.
As far as I can see, all window managers are "dbus-free". dbus is, for example, required by file managers for mounting external devices. See: https://dev1galaxy.org/viewtopic.php?pid=1028
That's why you would probably want to have
exec dbus-launch --exit-with-session openbox-session
instead of just
inside your ~/.xinitrc file. At least when using Thunar or PCManFM.
Yes that probably is wise.
There are many apps that use dbus.
I get by without it OK though just occasionally its a bother.
I will post a better version in any case with dbus options.
PeteGozz wrote:an optionally dbus free window manager
instead of just
The type of use case as discussed above would most probably use a Display Manager in any case.
(and dbus and udev etc)
I am not suggesting that a chopped down xinit type login would have all conveniences.
I am certainly not suggesting this is a default setting for anybody but those who are curious
or working toward smaller footprints and perhaps developing debugging.
Its also a dying skill set
(and I'm not excluding myself)
In any case the next post should go some way to covering your absolutely correct note.
(untested as I have no dbus to test )
And probably even buggier now .
I need to trace startx a little more carefully as well.
Its just a hack. Not for user land.
edit:
There should be a useful version with somewhat more advanced dbus support at::
https://git.devuan.org/PeteGozz/slim/bl … trc.sample
/edit
So a slightly more baroque version.
Is nicer to the startx wrapper the poor user and
should use dbus if its available.
(of course you can set that to "" or /bin/true)
or even better rewrite this into something useful for you.
Check and edit this to suit your needs.
Note that startx should use and digest all the system /etc/X11/Xsession.* stuff.
Not so sure about xinit.
This can also work for plain old X -query type asks
Sheeze its been a while.
# usage: (where "foobar" will possibly match your desired window manager)
# ~$ startx foobar
# ~$ xinit foobar -- :1
# ~$ xinit -- :$(tty | tr -d /dev/tty)
# now with simple dbus detection
# allocate to your default window manager
# dbus executable ?
if [ -x dbus-launch ];then
DESKTOP_BUS="dbus-launch --exit-with-session"
else
DESKTOP_BUS=""
fi
if [ -z $1 ];
then
# no option for xinit then just jump to default
exec $DESKTOP_BUS $DEFAULT_SESSION
elif [ -x $1 ];
then
# $1 in our PATH and executable
case $1 in
fluxbox )
# see also: ~/.fluxbox/startup
exec $DESKTOP_BUS startfluxbox
openbox )
twm)
xbindkeys || true &
xterm -e /bin/bash &
exec twm
icewm)
icewmbg &
icewmtray &
exec $DESKTOP_BUS icewm
wmaker)
exec wmaker
blackbox)
exec blackbox
# we should not arrive here unless we fed $1 with a shell or something
# but I'm just gunna pretend we never did and go default
esac
elif [ ! -x $1 ];
then
# spit some help in the middle of all those Xorg messages
echo ""
echo Please Note: Unable to understand: $1
echo Try xinit or startx with no options for $DEFAULT_SESSION
echo "or if server in use try: xinit -- :$(tty | tr -d /dev/tty)"
echo Or try: startx $1 finally try: startx sh
else
# we have to hope $1 is some argument an xterm or xinit understands
xterm -e $1 || xterm &
# this is a guess and seems a little safer than nothing
fi
### this should never do a thing but the use cases are vast and interesting
### as this sourced thing should have been abandoned by exec millisecs ago
if [ "$?" != "0" ]; then
echo -e "\ntry:\t xinit -- :$(tty | tr -d /dev/tty)"
echo -e "or plain startx "
fi
#eof
