#1 2017-06-18 17:20:26
spartrekus
Installing DEVUAN on a NEC PC-8201 ?
Hello,
I am trying to install Linux with a tiny install on a NEC PC-8201.
After soldering a lot to fix it, now the machine is operational wink  I gave it a new life.
Getting a really small Devuan, right? Do you think that there is a small install of devuan available for such perfs.?
herewith the beast:
https://www.youtube.com/watch?v=d6z6nzzXlUQ
#2 2017-06-18 18:56:11
Re: Installing DEVUAN on a NEC PC-8201 ?
Any of the installer images and the minimal live will give you a minimal system. Only the desktop-live forces you to take the whole desktop. Uncheck everything (or everything except 'standard system utilities' and the tasksel window.
#3 2017-06-21 20:18:19
pcalvert
Even Tiny Core Linux would be (way) too big for that ancient machine. The EPROM in that computer only holds 32 KB of data!
Have you seen this website?:
http://www.web8201.com/
Phil
Another one is called Luxxle.
#4 2017-06-22 14:47:03
mckaygerhard
this case its similar to the EeePC suft 2G : http://200.82.144.73/dokuwiki/doku.php? … -8g-laptop a temporali link for a temporally forum (yes in Devuan there lot of change until today)
