#1 2017-06-12 19:01:07
devur
[SOVELD] apt-get error
i get a error when i update white apt-get, i have Reade about the error in these forum threat
https://unix.stackexchange.com/question … of-insserv
but i doe not see any solution. are ther e some help to get?
the error line from terminal
 sudo apt-get update
Hit http://auto.mirror.devuan.org jessie InRelease
Hit http://auto.mirror.devuan.org jessie-updates InRelease
Hit http://auto.mirror.devuan.org jessie/main amd64 Packages
Hit http://auto.mirror.devuan.org jessie-updates/main amd64 Packages
Get:1 http://auto.mirror.devuan.org jessie-security InRelease [106 kB]
Ign http://auto.mirror.devuan.org jessie/main Translation-en
Ign http://auto.mirror.devuan.org jessie-updates/main Translation-en
Get:2 http://auto.mirror.devuan.org jessie-security/main amd64 Packages [382 kB]
Ign http://auto.mirror.devuan.org jessie-security/main Translation-en
Fetched 489 kB in 2s (169 kB/s)
sudo apt-get install devuan-keyring
Building dependency tree
devuan-keyring is already the newest version.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up cups-browsed (1.0.61-5+deb8u3) ...
insserv: warning: script 'K07smfpd' missing LSB tags and overrides
insserv: warning: script 'smfpd' missing LSB tags and overrides
insserv: There is a loop between service rmnologin and mountall if started
insserv:  loop involving service mountall at depth 5
insserv:  loop involving service checkfs at depth 4
insserv: There is a loop between service rmnologin and urandom if started
insserv:  loop involving service urandom at depth 6
insserv:  loop involving service networking at depth 9
insserv: There is a loop between service smfpd and mountall if started
insserv:  loop involving service mountall-bootclean at depth 9
insserv: There is a loop at service rmnologin if started
insserv: There is a loop between service smfpd and mountall-bootclean if started
insserv: Starting smfpd depends on rmnologin and therefore on system facility `$all' which can not be true!
insserv: Max recursions depth 99 reached
insserv:  loop involving service cups-browsed at depth 1
insserv: There is a loop between service smfpd and live-config if started
insserv:  loop involving service live-config at depth 1
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing package cups-browsed (--configure):
 subprocess installed post-installation script returned error exit status 1
 cups-browsed
my cups-browser file
#! /bin/sh
### BEGIN INIT INFO
# Provides:          cups-browsed
# Required-Start:    $syslog $remote_fs $network $named $time
# Required-Stop:     $syslog $remote_fs $network $named $time
# Should-Start:      avahi-daemon
# Should-Stop:       avahi-daemon
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: cups-browsed - Make remote CUPS printers available locally
# Description: This daemon browses Bonjour broadcasts of shared remote CUPS
#              printers and makes these printers available locally by creating
#              local CUPS queues pointing to the remote queues. This replaces
#              the CUPS browsing which was dropped in CUPS 1.6.1. For the end
#              the behavior is the same as with the old CUPS broadcasting/
#              browsing, but in the background the standard method for network
#              service announcement and discovery, Bonjour, is used.
### END INIT INFO
Laptop lenovo
Desktop XFCE
Os Devuan GNU/Linux
#2 2017-07-03 17:53:06
devur
Re: [SOVELD] apt-get error
i haw reinstall and that solved my problem
Laptop lenovo
Desktop XFCE
Os Devuan GNU/Linux
