#1 2024-09-19 10:57:37
samhain
Darkness - ISO Devuan Testing + TDE for AMD64
Latest iteration of my Devuan Testing + TDE Remaster for AMD64. And I finally gave it a name smile
What do you get:
- Devuan Testing
- TDE 14.2
- Openscad
- Zim Desktop Wiki
- most firmeware blobs
- firefox
- dark theme
UID / PWD:
user / user
root / toor
ISO: https://samhain.at/devuan_tde/darkness-20240918.iso
SHA256: https://samhain.at/devuan_tde/darkness- … iso.sha256
Note: default language is austrian german. Russian and englisch language packs are installed, too.
Screenshots:
Please test and report any issues you find here.
#2 2024-09-19 11:25:52
Re: Darkness - ISO Devuan Testing + TDE for AMD64
Hello.
Thank you for your work! How about iso, based of Devuan 5 (stable)?
#3 2024-09-19 12:09:42
samhain
Well, there are lots of "stable" remixes, but not a lot of "testing", e.g. "exegnulinux" is stable + TDE - so no need for another stable remix smile
#4 2024-09-19 15:41:45
Thanks for the reply.
Personally, I don't think using testig in production env is a good idea, so I'll refrain from testing your iso. Have a good day.
#5 2024-09-19 17:09:30
samhain
As the name says: "testing" is for testing. If don't want to test, then don't.
#6 2024-11-01 08:33:22
Tony45
I have just now downloaded and tested in RAM your ISO.
I think it's an excellent piece of work !
I really hope you carry on with it
The reason I tested in RAM is that it was << sort of >> confusing to install. Too technical for a beginner ( to understand ) and for an old fart like me ( 80 Years ) .
Or maybe just a bad day ?  ?  ?
However, special thanks for using Pulseaudio and keeping pipewire out of the installation-iso
The reason for saying so, is that PW makes each and every distro/DE on distrowatch crackle like hell when playing Midi-files. I tested 18 of them already for this issue
Please keep PA in the iso and PW in the repositories
Right now the sound is 127% Cristal-clear and distortion-free with Timidity
Will try install again soon
Hope to see more soon
Bye  !
#7 2024-11-01 09:31:03
FWIW, pipewire works just fine with fluidsynth (via ALSA sequencer port) here, and on every distro I've used that packages those.
Timidity OTOH, AFAICT has been pretty much a zombie project since 2004.
#8 2024-11-02 09:40:59
Tony45
I managed to install it on HD.
I have updated and installed a few dozen appz.
Everything seems to work very well and sound is perfect.
My experience is, on my hardware, timidity always works perfect--> if no PW is installed of course . If installed, it distorts Midi on Timidity
For testing, I use < Pianobooster > as this is the most sensitive app I know !
Midi files crackle on each and every distro that comes with PW inside the ISO
Removing PW does not solve the problem as the damage is done already to other parts of the setup
I tried more than 20 distros ( tde and cinnamon ) already....all same
There are of course a few PW-libraries which don't do damage
As I said, your TDE on my hardware , so far works perfect
I will keep on testing for a week .
Thanks
#9 2024-11-02 11:31:32
Hello.
TDE R14.1.3 has been released in 2024.10.27. Did you upgraded your install? If so, how did it go?
#10 2024-11-02 17:59:24
Ah yes, KDE3... the last kde that looks semi-good.
#11 2024-11-03 01:21:19
Tony45
There was no problem at all
#12 2024-11-04 12:34:46
Thank you for the info.
#13 2024-11-10 14:14:23
samhain
Thank you for testing. Refractainstaller is a bit tricky, but I did not find anything better yet so I stick with it smile
TDE14.2 (which I use) is the dev branche of TDE. Upgrades are usalluay very smooth without surprises.
#14 2025-03-02 19:04:38
samhain
March 2025 version is out!
What do you get:
- Devuan Testing
- TDE 14.2.0 (dev branch)
- Openscad
- Firefox v135
- Kernel 6.12.17
- most firmware blobs
- dark theme
I have removed Zim Desktop Wiki due to the vast number of dependencies it pulls in.
UID / PWD:
user / user
root / toor
ISO: https://samhain.at/devuan_tde/darkness-20250302.iso
#15 2025-03-03 12:58:15
Thank you for your project!. Runs very well!
#16 2025-03-06 19:23:35
samhain
Thank you for testing smile
#17 2025-03-30 01:02:22
deepforest
@samhain
Hi i am test some Darkness, feels snappy at my old PC, thanks.
Have few questions:
1. Konqueror have bit issue with authorization, launch via sudo. Solved - xhost +
2. Konqueror -  mount ntfs partitions error Error: TDE mediamanager is not running - Solved - dcop kded kded loadModule mediamanager
3. Konqueror - mounted ntfs partition do not show correctly cyrillic  names - not solved for me.
smile
pyzNi 3.14zDa! smile
#18 2025-04-02 17:55:22
samhain
You can run konqueror as root, but you should not. Anyway,
tdesu konqueror
does the job - and your way works probably the best.
I cannot comment on the ntfs issues (don't have anything M$ to test). When you search you'll find that this is a long standing problem with ntfs across distribution - and was apparently never solved.
#19 2025-04-25 21:50:01
pungentweasel
I love TDE, but the big issue I have with it is the lack of scaling support. It's almost impossible to read anything on a 2K+ display
Q4OS made their own tool called "q4os-screenscaler" that configures a few options to try to simulate screen scaling .. but Q4OS is probably the sketchiest project I've ever seen regarding source code access. I wasn't able to find the source for that utility in the short amount of time I looked for it. I think you have to extract it from a deb file, unless it's precompiled...
I wouldn't mind testing this one of these days. Need to figure out some solution for scaling though. Sure do wish the tde folks would prioritize this
Behold, I send you forth as sheep in the midst of wolves: be ye therefore wise as serpents, and harmless as doves. - Matthew 10:16
#20 2025-05-02 21:34:38
samhain
You can control scaling under "kcontrol -> Apparance & Themes -> Fonts":
- either change the DPI settings from 96 to e.g. 190
- or choose bugger fonts, e.g. "Adjust All Fonts" and the select 30px instead of 12px.
BTW, the latest stable TDE version got released the other day.
https://www.theregister.com/2025/05/01/ … eepreading
#21 2025-07-20 16:33:19
ext4
Great work! Runs perfectly! cool
I installed the ISO with the German language pack. Subsequently updated the packages and the kernel, run through without errors.
What is annoying are some Cyrillic characters in various areas, e.g. in the search field under “Programs, Tasks and Work Sessions”.
Best regards from Germany
Frank
There can be only one! - Es kann nur e1nen geben!
#22 2025-09-28 20:37:06
samhain
Autumn 2025 Version is out!
I just finished uploading the latest version of "darkness". Biggest changes:
- TDE 14.2-DEVELOPMENT
- Xlibre instead of Xorg - thanks to @callmetango
- new background images
- kernel 6.16.8
- own repository for darkness-specific packages (ATM a package for the repo and the wallpapers)
Issues solved:
- EFI installation on blank disk works now
- TDE language packs of unused languages are removed when booting from iso, so that translations of missing texts come from english and not from any other language pack
- deactivate 3D acceleration on Lenovo X61 / Intel GM965/GL960
Download (I got myself a bigger webspace):
- https://www.klepp.cn/darkness/iso/darkness-20250928.iso
- https://www.klepp.cn/darkness/iso/darkn … iso.sha256
Some Images:
Thumbnails of all new wallpapers:
Please feel free to download and try .. and post your experience wink
#23 2025-09-29 02:27:32
RedGreen925
So what is the TDE su password? Without it anything that requires it will not work, I can simulate an install using the user/user for the sudo never tried the root/root for anything yet as it has not asked for it. Looks reasonable enough in my light usage so far.
Edit: You can set the root password with sudo passwd root entering the user for the sudo password then whatever you want for the root. It worked to allow the setting of the timezone from the default CEST it uses.
#24 2025-09-29 06:06:30
samhain
Passwords are the same as in the first post:
user / user
root / toor
#25 2025-09-29 06:42:32
re: setting passwords/permissions/sudoers/etc
humble fyi: see man vipw, vigr, and visudo
